I mentioned already in my “reopening”-post, that this did not help. It worked once, and that was it. Why it worked this one time, I don’t know. After restarting the computer, it was back to downsizing everything, and changing the settings for Legacy applications didn’t end it, no matter what it was set to.
Regarding the reopening, I am sorry, I wasn’t aware of the option to ask a moderator. It may be a good idea to mention that in the closing message, I guess. The sentence “New replies are no longer allowed” gives the impression that there is no option to reopen the issue. I would of course have preferred to continue discussing this issue here.
Regarding the other info (inxi…), I’ll get that and post it in a few moments (I hope).
Here is the inxi-Information:
Kernel: 6.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
root=UUID=ec6cf098-6a61-40fd-aa92-49cc5fef7f26 rw quiet apparmor=1
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
wm: kwin_wayland tools: avail: swayidle,swaylock vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: X470 GAMING PRO (MS-7B79) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.L4 date: 07/17/2024
System RAM: total: 64 GiB available: 62.72 GiB used: 13.28 GiB (21.2%)
(unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2Z3600C18 serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3186 min/max: 1550/3400 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 3186 2: 3186 3: 3186
4: 3186 5: 3186 6: 3186 7: 3186 8: 3186 9: 3186 10: 3186 11: 3186 12: 3186
bogomips: 81603
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: Sapphire driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1,HDMI-A-2
empty: DP-1,DP-2,DVI-D-1 bus-ID: 27:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 51.0 C
Device-2: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4.1.2.3:11
chip-ID: 0c45:636b class-ID: 0102
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5760x3240
display-ID: 0
Monitor-1: HDMI-A-1 pos: top-right model: HP 24o serial: <filter>
built: 2017 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
chroma: red: x: 0.655 y: 0.333 green: x: 0.314 y: 0.620 blue: x: 0.149
y: 0.063 white: x: 0.314 y: 0.329 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
Monitor-2: HDMI-A-2 pos: bottom-l model: Samsung LU28R55 serial: <filter>
built: 2024 res: mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440
dpi: 154 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green: x: 0.267
y: 0.620 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
size: 632x360mm (24.88x14.17") diag: 727mm (28.6") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
832x624, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 ACO DRM 3.64 6.17.9-1-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 1 device: 0 type: discrete-gpu name: AMD
Radeon RX 570 Series (RADV POLARIS10) driver: mesa radv v: 25.2.7-arch1.1
device-ID: 1002:67df surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: radeontop wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] vendor: Sapphire driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 27:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.17.9-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: jack_control
Server-3: PipeWire v: 1.4.9 status: off with: pipewire-media-session
status: active tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-93-gbe2efb status: active with:
tools: pacat,pactl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: httpd,NetworkManager
Local Storage: total: 11.48 TiB used: 4.08 TiB (35.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD30EZRX-00SPEB0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30EZRX-00D8PB0 size: 2.73 TiB block-size: physical: 4096 B
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 Series
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 6B0Q scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST6000DM003-2CY186
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7191S rev: 1.00
dev-links: cdrom
Features: speed: 94 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 152.09 GiB size: 152.09 GiB (100.00%)
used: 115.42 GiB (75.9%) fs: f2fs dev: /dev/sde4 maj-min: 8:68
label: Dateisystem f2fs auf der Partition
\xe2\x80\x9e/dev/sde4\xe2\x80\x9c erstellen
uuid: ec6cf098-6a61-40fd-aa92-49cc5fef7f26
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 1.8 MiB (0.7%) fs: vfat dev: /dev/sde2 maj-min: 8:66 label: ESP
uuid: E7F1-3B24
ID-3: /data raw-size: 994.85 GiB size: 978.17 GiB (98.32%)
used: 16.26 GiB (1.7%) fs: ext4 dev: /dev/sdd2 maj-min: 8:50 label: network
uuid: 36b02e3e-a948-43de-b32a-343ffe2e57d6
ID-4: /home raw-size: 4.49 TiB size: 4.45 TiB (99.19%)
used: 2.42 TiB (54.4%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: Home
uuid: 576c77a0-e6e4-4e3e-9bdc-fdf47c0a0cf2
ID-5: /home/<filter>/Bilder raw-size: 2.73 TiB size: 2.69 TiB (98.42%)
used: 1.53 TiB (57.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Fotos
uuid: 9eec6b6b-033e-4ad2-979d-df407491ec3f
Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default)
zswap: yes compressor: zstd max-pool: 20%
ID-1: swap-1 type: zram size: 12 GiB used: 238.5 MiB (1.9%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
ID-1: /dev/sda1 maj-min: 8:1 size: 1.85 TiB fs: ext4 label: home-DRM
uuid: 83b6baa8-b6bf-40d8-939f-a8215c548bd1
ID-2: /dev/sda2 maj-min: 8:2 size: 586.69 GiB fs: ext4 label: Musik
uuid: 4406a5c8-ff25-4485-b189-fa9ea3b6f649
ID-3: /dev/sda3 maj-min: 8:3 size: 6.26 GiB fs: swap label: Swap
uuid: a452f55a-acf3-4379-a4e6-f44665d53b4b
ID-4: /dev/sda4 maj-min: 8:4 size: 77.33 GiB fs: ext4 label: Testsys1
uuid: 4d4d7d9c-6456-4713-9ead-66ed221a2af4
ID-5: /dev/sda5 maj-min: 8:5 size: 85.85 GiB fs: ext4 label: Testsys2
uuid: f3f24a40-14e3-48e3-970d-23326f2ecc73
ID-6: /dev/sda6 maj-min: 8:6 size: 81.91 GiB fs: ext4 label: Testsys3
uuid: b119b06a-d9ad-4ae8-baf3-86090a56f007
ID-7: /dev/sdc1 maj-min: 8:33 size: 37.41 GiB fs: ext4 label: N/A
uuid: 41944751-3661-44e7-918a-ea6d5e515311
ID-8: /dev/sdc2 maj-min: 8:34 size: 73.82 GiB fs: ext4 label: Manjaro
uuid: c5303561-8dbd-4c72-87a3-4789eacda253
ID-9: /dev/sdc3 maj-min: 8:35 size: 570 MiB fs: vfat label: ESP
uuid: 64A4-C845
ID-10: /dev/sde1 maj-min: 8:65 size: 151.37 GiB fs: f2fs label: N/A
uuid: 0d0931b9-c791-49b1-aef6-3ea0d65766c8
ID-11: /dev/sde3 maj-min: 8:67 size: 162.05 GiB fs: f2fs label: System3
uuid: ec3d7801-185e-4251-b653-3c291f4f31e6
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-13:6 info: -- USB keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 260d:0021 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Brother Industries MFC-J6920DW
type: printer,mass storage driver: usb-storage,usblp interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 04f9:02f5 class-ID: 0806 serial: <filter>
Device-2: 5-2:3 info: Frys MEC0003 type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 0001:0000 class-ID: 0300
Device-3: 5-3:4 info: PERIMICE-520 type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 260d:1019 class-ID: 0301
Hub-6: 5-4:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Hub-7: 5-4.1:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Hub-8: 5-4.1.2:7 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Device-1: 5-4.1.2.2:10 info: Genesys Logic microSD Card Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 98mA
chip-ID: 05e3:0751 class-ID: 0806
Device-2: 5-4.1.2.3:11 info: Microdia USB 2.0 Camera type: video,audio
Hub-9: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-10: 6-4:2 info: Realtek Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-11: 6-4.1:3 info: Realtek Hub ports: 4 rev: 3.0
Device-1: 6-4.3:4 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 990
Packages: 3257 pm: pacman pkgs: 3204 libs: 588 tools: octopi,pamac,yay
pm: flatpak pkgs: 53
1: https://manjaro.kurdy.org/testing/$repo/$arch
2: https://mirror.23m.com/manjaro/testing/$repo/$arch
3: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 470
1: cpu: 116% command: gs pid: 26580 mem: 26.9 MiB (0.0%)
2: cpu: 100% command: ps pid: 26588 mem: 4.45 MiB (0.0%)
3: cpu: 15.0% command: thumbnail.so started-by: kioworker pid: 3744
mem: 507.7 MiB (0.7%)
4: cpu: 10.4% command: firefox pid: 6475 mem: 817.4 MiB (1.2%)
5: cpu: 9.8% command: baloo_file_extractor pid: 4344 mem: 71.8 MiB (0.1%)
Memory top: 5 of 470
1: mem: 1031.0 MiB (1.6%) command: kwin_wayland pid: 1331 cpu: 4.0%
2: mem: 899.2 MiB (1.4%) command: thunderbird pid: 3559 cpu: 3.8%
3: mem: 886.9 MiB (1.3%) command: firefox pid: 6874 cpu: 3.5%
4: mem: 817.4 MiB (1.2%) command: firefox pid: 6475 cpu: 10.4%
5: mem: 617.5 MiB (0.9%) command: soffice.bin pid: 7614 cpu: 0.4%
Processes: 470 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 258 default: graphical tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.3
running-in: konsole inxi: 3.3.40
