I’m running on the KDE Plasma Desktop (X11) up-to-date as of the stable update of 4/5/25.
It seems that LibreOffice has changed it’s behaviour as regards the “save as” option. Formerly when I opened a file and then select “save as” the default behaviour was to save back in the same directory (IMO the only sane choice), but now it has changed to save wherever I last saved a file.
How can I restore the sensible behaviour?
I have libreoffice-fresh 25.2.2-1, plasma-desktop 6.3.4-1
it’s a regression in LibreOffice (probably introduced in version 25.2.2) that should be fixed in version 25.2.3, which is currently in the Unstable branch (package libreoffice-fresh).
After reading through #165917, issue seems clear; and apparently fixed with LibreOffice v25.2.3.2 (Fresh) and v24.8.7 (Still).
It’s now just a question of waiting for the respective versions to filter down to Stable branch. If you’re using Unstable you might take time to console others that the solution is in hand.
