Hi,
I’m running Manjaro XFCE with LibreOffice 6.4.7.2 and have an issue with Impress. When I try to launch it e.g. using libreoffice --impress
, I get a message “Object not accessible. The object cannot be accessed due to insufficient user rights”. The weird thing is that all other LibreOffice apps (e.g. Writer, Calc, Draw, Math, Base) all launch properly. The problem only occurs with Impress. It was working previously but I don’t know which update broke it.
I guess it is a permission issue but I can’t find where the problem comes from. The folder ~/.config/libreoffice is own by me so I don’t think this is related to that. Also since only Impress is affected, it should be something more specific. Would you know how to troubleshoot this issue?
Thanks!
