I have libreoffice-fresh 7.0.0-1 installed. Everything used to work just fine. From a few days ago (IDK what exactly caused this as I don’t use it that regularly), it started freezing and crashing randomly. It’d freeze whenever I select a large chunk of text, do anything else other than typing. It’d crash randomly. Has anyone else faced this issue? What to do?
I am far from being an expert but can you confirm the way you installed the package? Is it from the repos or a flatpak?
Also you might want to try installing a newer kernel. If you want to stay on an LTS kernel, 5.4 is the current one. You can do it via the Manjaro Settings, thereafter don’t forget to reboot and let us know if that changes anything.
Ok, so I guess you checked the availability for a newer graphics driver series for your graphics setup as well? I am not too proficient when it comes to that.
When you run libreoffice from terminal, does that throw any output when it crashes?
I’ve tried several things but couldn’t solve that issue.
The only output I get is this:
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Some problems have been reported with libreoffice-fresh, yes. The advice given from upstream is to replace it with libreoffice-still if the problems persist.
Does anyone know if libreoffice provides some kind of logging system that can be used to finding out the error? EDIT: The issue doesn’t seem to happen if I write all the text from scratch. It only happens when I copy-paste something (even as unformatted text).
I don’t think it logs anything in and of itself ─ I could be wrong ─ but crashes would normally show up in the system log itself. Try looking for it with journalctl.
I would backup your current config and try a new one. Others have reported issues when updating to this version and using the old configuration file for LO 6… Or remove the Manjaro/Arch LO and give libreoffice-fresh-rpm from the AUR a try with a new configuration. That version builds directly from the rpm files from The Document Foundation. I have been using that one for a long time already with none of the issues that I had with the Manjaro/Arch spin.
I’ve already reset my profile. So that won’t help. I’ll maybe try switching to AUR, I don’t want to as it is a pretty big package, but I’ll do that if turning off java doesn’t help.
None of these worked, sadly. At this point, can anyone suggest some alternatives? I’m stuck using Google Docs for the time being. I can’t use OnlyOffice, as it doesn’t support ligatures and my mothertongue is full of ligatures.
