Dear all,
I’m on a fresh install of Manjaro lxqt and one of the first thing I did after a full update is to install the libreoffice-fresh package.
However, one strange thing (according to me anyway) is that the current version of the fresh package on my system is 6.4.5.2
When I look at this page, the current version of libreoffice-fresh is 7.0.
How is this possible? Thanks in advance!
Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=2807799f-dc3d-426c-bb0e-550ca60af665 rw quiet udev.log_priority=3
Desktop: LXQt 0.15.1 tk: Qt 5.15.0 info: lxqt-panel wm: kwin_x11
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: HP product: HP ENVY Laptop 13-ad1xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83A7 v: KBC Version 39.33 serial: <filter> UEFI: Insyde
v: F.18 date: 11/02/2017
ID-1: BAT0 charge: 48.8 Wh condition: 48.8/48.8 Wh (100%) volts: 8.7/7.7
model: HP Primary type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Illuminated Keyboard K800
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: D6
L2 cache: 6144 KiB
bogomips: 28808
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 757 2: 748 3: 750
4: 793 5: 718 6: 749 7: 751 8: 702
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 04f2:b5ed
Display: x11 server: X.org 1.20.8 compositor: compton driver: intel
resolution: <xdpyinfo missing>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.1-3-MANJARO
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3040
bus ID: 02:00.0 chip ID: 8086:095a
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 2-2:2 chip ID: 0bda:8153 serial: <filter>
IF: enp0s20f0u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 476.94 GiB used: 376.46 GiB (78.9%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: AAHA4102 scheme: GPT
ID-1: / raw size: 40.00 GiB size: 39.12 GiB (97.81%) used: 11.79 GiB (30.1%)
fs: ext4 dev: /dev/nvme0n1p6
ID-1: swap-1 type: partition size: 12.00 GiB used: 38.8 MiB (0.3%)
priority: -2 dev: /dev/nvme0n1p10
System Temperatures: cpu: 48.0 C mobo: 0.0 C
Processes: 253 Uptime: 5h 14m Memory: 7.54 GiB used: 4.15 GiB (55.1%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1100 lib: 313
Shell: Zsh v: 5.8 running in: qterminal inxi: 3.1.05
