Some issues i have seen today. Libreoffice splash screen appear for a second but app does not start/load.
Via terminal:
$ libreoffice --writer %U
/usr/lib/libreoffice/program/soffice.bin: error while loading shared libraries: libicuuc.so.68: cannot open shared object file: No such file or directory
$ pacman -F libicuuc.so
warning: database file for ‘DEB_Arch_Extra’ does not exist (use ‘-Fy’ to download)
core/icu 69.1-1 [installed]
usr/lib/libicuuc.so
community/onlyoffice-desktopeditors 6.3.1-1
opt/onlyoffice/desktopeditors/libicuuc.so
community/synology-drive-client 3.0.1.12667-1
opt/Synology/SynologyDrive/lib/libicuuc.so
opt/Synology/SynologyDrive/package/cloudstation/lib/libicuuc.so
multilib/lib32-icu 69.1-1 [installed]
usr/lib32/libicuuc.so
$ pacman -Qo /usr/lib/libicuuc.so
warning: database file for ‘DEB_Arch_Extra’ does not exist (use ‘-Sy’ to download)
/usr/lib/libicuuc.so is owned by icu 69.1-1
sudo nano /etc/pacman.conf
remove libreoffice from ign0red packages.
pacman -S libreoffice-fresh-cs # i am using czech version
it gets updated
/usr/lib/libreoffice/program/soffice.bin: symbol lookup error: /usr/lib/libreoffice/program/libskialo.so: undefined symbol: FT_Get_Paint
$ pacman -F libskialo.so
extra/libreoffice-fresh 7.2.0-1 [installed: 7.2.0-2]
extra/libreoffice-still 7.1.5-1
I am unsure if i understand. “pacman -Syy” possibly refreshed my package databases and now:
$ sudo pacman -S libreoffice-fresh-cs libreoffice-fresh
warning: libreoffice-fresh-cs-7.2.0-1 is up to date – reinstalling
warning: libreoffice-fresh-7.2.0-2 is up to date – reinstalling
resolving dependencies…
If you don’t know what branch you’re on, you’re most likely on stable.
This probably left you with partial updates which are unsupported. You should consider a full update of the system and not partial upgrades of specific (libreoffice) packages.
If you don’t need the features in latest LibreOffice 7.2 (libreoffice-fresh-7.2.0-2), try installing libreoffice-still-7.1.5-2 in pacmac. It will replace libreoffice-fresh-7.2.0-2 with libreoffice-still-7.1.5-2 .
(You can reinstall 7.2 later on, once the dependencies issue is fixed.)
You can find your current branch from /etc/pacman.d/mirrorlist.
FT_Get_Paint should come from package freetype2. Make sure it is at latest version. What version of freetype2 are you using? Are you holding back any other packages?
