Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c8fe489d-a5c4-4f6c-9d95-16f48c8aa4b0 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook 14_ASUS Laptop X407UA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X407UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X407UA.304 date: 05/31/2019
ID-1: BAT0 charge: 28.3 Wh (97.6%) condition: 29.0/33.2 Wh (87.5%)
volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 1081
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 600 min/max: 400/2000 scaling: driver: intel_pstate
governor: powersave cores: 1: 600 2: 600 3: 600 4: 600 bogomips: 16006
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b60d class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:4
chip-ID: 13d3:3506 class-ID: e001
Local Storage: total: 931.51 GiB used: 15.05 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-80Z10T2 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A04 scheme: GPT
ID-1: / raw-size: 161.49 GiB size: 157.89 GiB (97.77%)
used: 15.02 GiB (9.5%) fs: ext4 dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 25.9 MiB (10.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 45.0 C pch: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1900
Processes: 225 Uptime: 46m wakeups: 1 Memory: 11.58 GiB
used: 3.51 GiB (30.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1367 lib: 383 flatpak: 0
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
my laptop wifi so weak signal, i have try to update kernel
and search the manjaro archive forum
and it not working at all
i dual boot with windows
in windows it normal and on archcraft it normal too
but in MANJARO KDE my wifi so weak
