Problem
- libreoffice can save / open files with Chinese chars in path
Env
- Manjaor: Updated on 2020/7/7
- LibreOffice: Installed on 2020/7/7
If this is what you actually mean, then I don’t see it as a bug, that it can save files.
If you actually mean “can’t”, then yeah it would be a bug.
It can not.
What version of LibreOffice? fresh, still, dev? installed 2021/7/7? If this is, in fact, a bug, it would be a LibreOffice bug and not an issue that Manjaro devs can fix.
In LibreOffice Fresh 7.1.3-2 everything works fine.
I tried three different situations
/home/documents/文件.odt
/home/documents/文件/文件.odt
/home/documents/文件/test/文件.odt
and everything saved as it should be.
I had a similar problem with French characters. it was due to bad config of Locale (complex stuff in Manjaro, all was not very clear to me)
