Hi I just want to report that pamac is not updating the pkgbuild files properly when updates are pushed out on the AUR. I am a developer and I have checksum keys on my applications bin files from my Gitlab repo which I will always update every time I push a update but when pamac sees I pushed a update it wont properly update the makepkg build file causing a checksum failed to verify message until I go into pamac’s settings and clear the 3rd party AUR cache which is really annoying and will be a pain for people using my software and I have had to do this multiple times.
Here to report issues:
That’s a totally different issue, it shows the update does it but the checksum keys on the pkgbuild file don’t get updated.
You still go there to report issue.
Alright, I will make a report and link it here.
Issue link: Pamac pkgbuild checksum issues on updates (#1088) · Issues · Applications / pamac · GitLab
helper update only if you set un pkgbuild a new version , change only chechsum is not enough
I know and I do but it still think it’s using a old checksum even if I have it updated to a new version with a new checksum.
