I am using GNOME 43.2 with two monitors. When I click on the terminal or file browser using keyboard or icon click it is opened in the same monitor as of cursor but it is not followed by other third party application (mainly all the electron apps like VSCode) and the Brave browser.
Anything that is pre shipped while installation is following the cursor curent monitor location but not the application installed after installation.
$ inxi -Fazzy
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=3f67f741-326c-49e8-a0b6-5f36f8bcb332 rw udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505GT.311 date: 02/08/2021
ID-1: BAT0 charge: 33.0 Wh (97.1%) condition: 34.0/48.1 Wh (70.8%)
volts: 12.2 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: not charging cycles: 41
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2300 high: 2600 min/max: 800/2600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 2600 3: 2600
4: 2600 5: 800 6: 2600 7: 2600 8: 2600 9: 2600 10: 2600 11: 800 12: 2600
bogomips: 62431
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 120 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-90fc01994b1a state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 279.36 GiB (19.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK
lanes: 4 type: SSD serial: <filter> rev: P1MA0V4 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-11Z10T0
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw-size: 185.55 GiB size: 181.58 GiB (97.86%)
used: 25.79 GiB (14.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 320 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 283.38 GiB size: 277.87 GiB (98.06%)
used: 13.37 GiB (4.8%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 35.0 C pch: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 321 Uptime: 23m wakeups: 22140 Memory: 15.48 GiB
used: 4.19 GiB (27.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages:
pm: pacman pkgs: 1107 libs: 280 tools: gnome-software,pamac,yay Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.24
