Every so often, I accidentally drag the formula sub-menus, or whatever they’re called, off of Libre Office. I cannot for the life of me figure out how to pin them back to the application, like How Krita allows you to customize your window setup (toolbar on the left or right, etc).
Usually, you can just drag it into position like shown here.
Unfortunately, however, this isn’t possible in KDE plasma.
Maybe, you could file a bug?
until then, you can try the flatpak as KDE usually doesn’t override app title bars there
Best Regards, Julius
