This is some bug that is happening since 2 months or so. I wonder if that is something on my machine, or maybe a widespread issue.
Namely, when I try copy-pasting anything from the (any) browser with no formatting (ctrl+shift+v) I get the error, that there is no clipboard available. To be precise, it says:
“Requested clipboard format is not available.”
When I try to choose html formatting - the same issue. Copy-pasting with formatting works, but is a disaster to work with.
I switched from libreoffice-fresh to still and the issue remains.
When I try to paste to any other app, like kwriter, there is no issue, all pastes correctly.
To bypass the problem, I need to past anything into the system text editor and then copy-paste it again. When I’m working and doing a lot of such operations, it gets VERY TEDIOUS VERY FAST.
Any ideas if that is fixable? At this point, I’m taking into account changing my office suite, but I have no comparable choice… Libreoffice is the absolute minimum what I need for work.
It also may be a Plasma or Arch issue:
EDIT: Yeap, that is probably Arch packaging issue. I installed flatpack version and it works as intended. The problem with is, flatpack was launched without any personalizations, vanilla state and I am confused… There is no global menu, style is not following my system (looks odd) and without appmenu, I have no access to menu, so I can’t even configure it… This is a disaster.
