have tried for a while to update Libmagic6 and ended up in uninstalling it after all else I could find on forums failed.
Now on Package Manager I get “Failed to generate libmagick6 information”.
In terminal I get:
sudo pamac install libmagick6
Warning: libmagick6 is only available from AUR
Preparing...
Checking libmagick6 dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
libmagick6 6.9.12.67-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building imagemagick6...
Running as unit: run-u171.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: imagemagick6 6.9.12.67-1 (sön 13 nov 2022 11:37:41)
==> Retrieving sources...
-> Found ImageMagick-6.9.12-67.tar.gz
-> Found ImageMagick-6.9.12-67.tar.gz.asc
-> Found arch-fonts.diff
ImageMagick-6.9.12-67.tar.gz ... Passed
ImageMagick-6.9.12-67.tar.gz.asc ... Skipped
arch-fonts.diff ... Passed
==> Verifying source file signatures with gpg...
ImageMagick-6.9.12-67.tar.gz ... cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Finished with result: exit-code
Main processes terminated with: code=exited/status=1
Service runtime: 1.077s
CPU time consumed: 1.225s
Error: Failed to build imagemagick6
I cannot find any info on how to fix the issue with the “Broken pipe”. Please help.
Theanks! This seems to do the trick, at least in the sense that it made me ralize that I tried to have imagemagick6 installed while the system all the time had the next version: 7.
sudo pacman -S imagemagick
warning: imagemagick-7.1.0.51-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) imagemagick-7.1.0.51-1
Total Installed Size: 10,92 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [##############################################] 100%
(1/1) checking package integrity [##############################################] 100%
(1/1) loading package files [##############################################] 100%
(1/1) checking for file conflicts [##############################################] 100%
(1/1) checking available disk space [##############################################] 100%
(1/1) reinstalling imagemagick [##############################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Warn about old perl modules
The issue is that I have an update to do on python2 that needs imagemagick6…
You are the 102. user to raise the issue of python2.
Woh! Always figured that that there are still some legacy system dependencies that use python2 although I have personally moved on to Python 3.+ since many years back.
Anyway, removed python2 now as you instructed. So far so good. Thanks a bunch!
