libmagic6 keeps updating, repeatedly, unending.
pamac is not detecting that the package has been updated, and so keeps updating it, …
Any suggestions/help?
Thanks.
Thanks.
Look at the log on AUR page. Was modified a couple of times https://aur.archlinux.org/cgit/aur.git/log/?h=imagemagick6 and Last Updated: 2021-08-05 18:33 so is not from the package itself right now, but do you need it?
Even if you update or reinstall it from terminal?
@Yochanan - something particular with this package?
Nope, Sounds like a corrupt build cache.
@john_coach
Remove the package’s build cache then try again. By default, it should be /var/tmp/pamac-build-<your-username>/imagemagick6/
've marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Our apologies, the post was closed automatically 24h after the solution was marked as such by a rather aggressive timer
In the mean time:
P.S. Thanks for bringing this to our attention.
