zeus1
January 25, 2023, 9:27pm
#1
I installed lib32 to run games and now I can’t update the system
Preparing...
Synchronizing package database...
Warning: installing libpcap (1.10.3-1) breaks dependency 'libpcap=1.10.1' required by lib32-libpc
ap
Add lib32-libpcap to remove
Warning: installing libsndfile (1.2.0-1) breaks dependency 'libsndfile=1.1.0' required by lib32-l
ibsndfile
Add lib32-libsndfile to remove
Warning: installing ncurses (6.4-1) breaks dependency 'ncurses=6.3' required by lib32-ncurses
Add lib32-ncurses to remove
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing lib32-ncurses breaks dependency 'lib32-ncurses' required by lib32-llvm-libs
Resolving dependencies...
Checking inter-conflicts...
It appears you are in an unsupported upgrade state. Please make sure you are fully up to date.
Please see:
zeus1:
I installed lib32
You installed what exactly and why? There are many lib32-XXX
packages.
This is an obvious XY Problem : You’re asking about your attempted solution rather than your actual problem . This leads to enormous amounts of wasted time and energy, both on the part of people asking for help, and on the part of those providing help.
We do not have enough information to help you.
Please see:
zeus1
January 25, 2023, 11:07pm
#3
sudo pacman -Sy --asdeps --needed zenity faudio lib32-faudio libpulse lib32-libpulse alsa-plugins lib32-alsa-plugins lib32-gst-plugins-base-libs gst-plugins-base-libs lib32-v4l-utils v4l-utils lib32-vkd3d vkd3d lib32-ocl-icd ocl-icd lib32-glu glu acl lib32-acl lib32-attr attr gettext lib32-gettext lib32-libnl libnl lib32-libpcap libcap lib32-sdl2_image sdl2_image lib32-sdl2_ttf sdl2_ttf lib32-sdl2_mixer sdl_mixer sdl2_net lib32-libidn11 libidn11 lib32-libva libva lib32-libxslt libxslt lib32-libxss libxss lib32-openal openal lib32-vulkan-intel vulkan-intel lib32-vulkan-radeon vulkan-radeon lib32-vulkan-validation-layers vulkan-validation-layers
when installing any lib I get this error:
dependencies could not be satisfied:
zeus1:
sudo pacman -Sy
Never do that. Always use -u
with -y
. See System Maintenance - Manjaro
Make sure your mirrors are up to date, perform a full update and try again. See Pacman-mirrors - Manjaro
zeus1
January 25, 2023, 11:58pm
#5
output from the command sudo pacman -Syyu
core 161.7 KiB 370 KiB/s 00:00 [###############################] 100%
extra 1857.9 KiB 2.15 MiB/s 00:01 [###############################] 100%
community 7.5 MiB 4.23 MiB/s 00:02 [###############################] 100%
:: Replace nerd-fonts-noto-sans-mono with community/ttf-noto-nerd? [Y/n] y
resolving dependencies...
:: installing libpcap (1.10.3-1) breaks dependency 'libpcap=1.10.1' required by lib32-libpcap
:: installing libsndfile (1.2.0-1) breaks dependency 'libsndfile=1.1.0' required by lib32-libsndfile
:: installing ncurses (6.4-1) breaks dependency 'ncurses=6.3' required by lib32-ncurses
You don’t have the multilib repo enabled, but have multilib packages installed.
See the default /etc/pacman.conf
and make changes accordingly, then update.
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
Include = /etc/pacman.d/mirrorlist
system
Closed
January 28, 2023, 2:40pm
#8
