(continued)
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <info> [1635734765.1663] manager: NetworkManager state is now DISCONNECTED
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <warn> [1635734765.1665] device (enp2s0): Activation: failed for connection 'Auto-Ethernet'
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <info> [1635734765.1668] device (enp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <info> [1635734765.1819] dhcp4 (enp2s0): state changed timeout -> terminated
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <info> [1635734765.1860] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <info> [1635734765.1869] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:05 Viviversum2 NetworkManager[2071]: <info> [1635734765.1881] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <warn> [1635734810.1547] dhcp4 (enp2s0): request timed out
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1547] dhcp4 (enp2s0): state changed unknown -> timeout
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1548] device (enp2s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1552] manager: NetworkManager state is now DISCONNECTED
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <warn> [1635734810.1555] device (enp2s0): Activation: failed for connection 'Auto-Ethernet'
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1557] device (enp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1812] dhcp4 (enp2s0): state changed timeout -> terminated
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1837] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1840] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:46:50 Viviversum2 NetworkManager[2071]: <info> [1635734810.1848] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <warn> [1635734855.1647] dhcp4 (enp2s0): request timed out
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <info> [1635734855.1647] dhcp4 (enp2s0): state changed unknown -> timeout
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <info> [1635734855.1648] device (enp2s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <info> [1635734855.1652] manager: NetworkManager state is now DISCONNECTED
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <warn> [1635734855.1655] device (enp2s0): Activation: failed for connection 'Auto-Ethernet'
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <info> [1635734855.1658] device (enp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 03:47:35 Viviversum2 NetworkManager[2071]: <info> [1635734855.1946] dhcp4 (enp2s0): state changed timeout -> terminated
Nov 01 03:50:04 Viviversum2 NetworkManager[2071]: <info> [1635735004.1597] device (wlp3s0): set-hw-addr: set MAC address to 3E:C5:39:44:0A:E2 (scanning)
Nov 01 03:50:04 Viviversum2 NetworkManager[2071]: <info> [1635735004.3994] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 03:50:04 Viviversum2 NetworkManager[2071]: <info> [1635735004.4592] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 03:52:35 Viviversum2 NetworkManager[2071]: <info> [1635735155.1667] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 03:52:35 Viviversum2 NetworkManager[2071]: <info> [1635735155.1672] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:52:35 Viviversum2 NetworkManager[2071]: <info> [1635735155.1682] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <warn> [1635735200.1660] dhcp4 (enp2s0): request timed out
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.1661] dhcp4 (enp2s0): state changed unknown -> timeout
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.1662] device (enp2s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.1666] manager: NetworkManager state is now DISCONNECTED
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <warn> [1635735200.1669] device (enp2s0): Activation: failed for connection 'Auto-Ethernet'
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.1671] device (enp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.2047] dhcp4 (enp2s0): state changed timeout -> terminated
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.2072] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.2079] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:53:20 Viviversum2 NetworkManager[2071]: <info> [1635735200.2087] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <warn> [1635735245.1652] dhcp4 (enp2s0): request timed out
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.1653] dhcp4 (enp2s0): state changed unknown -> timeout
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.1654] device (enp2s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.1658] manager: NetworkManager state is now DISCONNECTED
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <warn> [1635735245.1661] device (enp2s0): Activation: failed for connection 'Auto-Ethernet'
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.1664] device (enp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.1986] dhcp4 (enp2s0): state changed timeout -> terminated
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.2010] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.2014] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:54:05 Viviversum2 NetworkManager[2071]: <info> [1635735245.2022] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 03:54:30 Viviversum2 NetworkManager[2071]: <info> [1635735270.7082] dhcp4 (enp2s0): state changed unknown -> terminated
Nov 01 03:54:30 Viviversum2 NetworkManager[2071]: <info> [1635735270.7087] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 03:54:30 Viviversum2 NetworkManager[2071]: <info> [1635735270.7098] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 04:00:38 Viviversum2 NetworkManager[398]: <info> [1635735638.4005] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 04:00:38 Viviversum2 NetworkManager[398]: <info> [1635735638.4255] ovsdb: disconnected from ovsdb
Nov 01 04:00:38 Viviversum2 NetworkManager[398]: <info> [1635735638.7215] device (wlan0): driver supports Access Point (AP) mode
Nov 01 04:00:38 Viviversum2 NetworkManager[398]: <info> [1635735638.7222] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 04:00:38 Viviversum2 NetworkManager[398]: <info> [1635735638.9690] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 04:00:39 Viviversum2 NetworkManager[398]: <info> [1635735639.2241] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 04:00:39 Viviversum2 NetworkManager[398]: <info> [1635735639.2309] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 04:00:40 Viviversum2 NetworkManager[398]: <info> [1635735640.2153] device (wlp3s0): set-hw-addr: set MAC address to BE:0C:9F:77:A6:FD (scanning)
Nov 01 04:00:40 Viviversum2 NetworkManager[398]: <info> [1635735640.5774] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 04:00:40 Viviversum2 NetworkManager[398]: <info> [1635735640.5775] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.7113] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.7115] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.7149] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.9506] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.9512] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.9513] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.9529] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.9534] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 04:00:44 Viviversum2 NetworkManager[398]: <info> [1635735644.9541] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 04:00:45 Viviversum2 NetworkManager[398]: <info> [1635735645.0301] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 04:00:45 Viviversum2 NetworkManager[398]: <info> [1635735645.2508] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 04:00:49 Viviversum2 NetworkManager[398]: <info> [1635735649.5495] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 04:00:49 Viviversum2 NetworkManager[398]: <info> [1635735649.5567] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 04:00:49 Viviversum2 NetworkManager[398]: <info> [1635735649.8971] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 04:00:50 Viviversum2 NetworkManager[398]: <info> [1635735650.2143] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 04:00:54 Viviversum2 NetworkManager[398]: <info> [1635735654.3845] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 04:00:54 Viviversum2 NetworkManager[398]: <info> [1635735654.3881] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 04:00:54 Viviversum2 NetworkManager[398]: <info> [1635735654.7373] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 04:00:55 Viviversum2 NetworkManager[398]: <info> [1635735655.4576] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 04:00:59 Viviversum2 NetworkManager[398]: <info> [1635735659.6215] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 04:00:59 Viviversum2 NetworkManager[398]: <info> [1635735659.6536] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 04:01:00 Viviversum2 NetworkManager[398]: <info> [1635735660.0039] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 04:01:01 Viviversum2 NetworkManager[398]: <info> [1635735661.2209] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 04:01:05 Viviversum2 NetworkManager[398]: <info> [1635735665.3814] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 04:01:05 Viviversum2 NetworkManager[398]: <info> [1635735665.3948] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 04:01:05 Viviversum2 NetworkManager[398]: <info> [1635735665.7507] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <warn> [1635735670.1566] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.1567] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <warn> [1635735670.1572] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <warn> [1635735670.1576] device (wlp3s0): no secrets: No agents were available for this request.
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.1576] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.1580] manager: NetworkManager state is now DISCONNECTED
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.1596] device (wlp3s0): set-hw-addr: set MAC address to BE:DA:42:C8:9B:E5 (scanning)
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <warn> [1635735670.3955] device (wlp3s0): Activation: failed for connection 'Viviversum'
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.3974] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.3977] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 04:01:10 Viviversum2 NetworkManager[398]: <info> [1635735670.4515] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 04:08:06 Viviversum2 NetworkManager[398]: <info> [1635736086.1615] device (wlp3s0): set-hw-addr: set MAC address to 5A:15:F7:06:EE:FB (scanning)
Nov 01 04:08:06 Viviversum2 NetworkManager[398]: <info> [1635736086.4007] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 04:08:06 Viviversum2 NetworkManager[398]: <info> [1635736086.4514] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 04:15:02 Viviversum2 NetworkManager[398]: <info> [1635736502.1785] device (wlp3s0): set-hw-addr: set MAC address to EA:CB:DC:89:04:C5 (scanning)
Nov 01 04:15:02 Viviversum2 NetworkManager[398]: <info> [1635736502.4201] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 04:15:02 Viviversum2 NetworkManager[398]: <info> [1635736502.4750] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 04:21:42 Viviversum2 NetworkManager[398]: <info> [1635736902.6116] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 04:21:42 Viviversum2 NetworkManager[398]: <info> [1635736902.6126] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 05:23:23 Viviversum2 NetworkManager[398]: <info> [1635740603.4264] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 05:23:23 Viviversum2 NetworkManager[398]: <info> [1635740603.4509] ovsdb: disconnected from ovsdb
Nov 01 05:23:23 Viviversum2 NetworkManager[398]: <info> [1635740603.5393] device (wlan0): driver supports Access Point (AP) mode
Nov 01 05:23:23 Viviversum2 NetworkManager[398]: <info> [1635740603.5431] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 05:23:23 Viviversum2 NetworkManager[398]: <info> [1635740603.9512] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 05:23:24 Viviversum2 NetworkManager[398]: <info> [1635740604.1765] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 05:23:24 Viviversum2 NetworkManager[398]: <info> [1635740604.1819] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 05:23:25 Viviversum2 NetworkManager[398]: <info> [1635740605.1008] device (wlp3s0): set-hw-addr: set MAC address to 26:7A:7F:15:B5:A9 (scanning)
Nov 01 05:23:25 Viviversum2 NetworkManager[398]: <info> [1635740605.4216] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 05:23:25 Viviversum2 NetworkManager[398]: <info> [1635740605.4217] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.5598] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.5599] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.5615] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.7959] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.7963] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.7963] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.7997] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.8000] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.8003] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 05:23:29 Viviversum2 NetworkManager[398]: <info> [1635740609.8784] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 05:23:30 Viviversum2 NetworkManager[398]: <info> [1635740610.0999] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 05:23:34 Viviversum2 NetworkManager[398]: <info> [1635740614.3953] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:23:34 Viviversum2 NetworkManager[398]: <info> [1635740614.3987] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:23:34 Viviversum2 NetworkManager[398]: <info> [1635740614.7427] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:23:35 Viviversum2 NetworkManager[398]: <info> [1635740615.0598] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:23:39 Viviversum2 NetworkManager[398]: <info> [1635740619.2175] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:23:39 Viviversum2 NetworkManager[398]: <info> [1635740619.2388] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:23:39 Viviversum2 NetworkManager[398]: <info> [1635740619.5966] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:23:40 Viviversum2 NetworkManager[398]: <info> [1635740620.3149] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:23:44 Viviversum2 NetworkManager[398]: <info> [1635740624.4740] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:23:44 Viviversum2 NetworkManager[398]: <info> [1635740624.4810] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:23:44 Viviversum2 NetworkManager[398]: <info> [1635740624.8331] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:23:46 Viviversum2 NetworkManager[398]: <info> [1635740626.0498] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:23:50 Viviversum2 NetworkManager[398]: <info> [1635740630.2072] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:23:50 Viviversum2 NetworkManager[398]: <info> [1635740630.2107] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:23:50 Viviversum2 NetworkManager[398]: <info> [1635740630.5664] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:23:52 Viviversum2 NetworkManager[398]: <info> [1635740632.6871] device (wlp3s0): state change: config -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 05:23:52 Viviversum2 NetworkManager[398]: <info> [1635740632.6875] manager: NetworkManager state is now DISCONNECTING
Nov 01 05:23:52 Viviversum2 NetworkManager[398]: <warn> [1635740632.6893] dispatcher: (3) failed: Refusing activation, D-Bus is shutting down.
Nov 01 05:23:52 Viviversum2 NetworkManager[398]: <info> [1635740632.6895] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Nov 01 05:23:52 Viviversum2 NetworkManager[398]: <info> [1635740632.6919] manager: NetworkManager state is now DISCONNECTED
Nov 01 05:25:22 Viviversum2 NetworkManager[412]: <info> [1635740722.3951] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 05:25:22 Viviversum2 NetworkManager[412]: <info> [1635740722.4193] ovsdb: disconnected from ovsdb
Nov 01 05:25:22 Viviversum2 NetworkManager[412]: <info> [1635740722.5832] device (wlan0): driver supports Access Point (AP) mode
Nov 01 05:25:22 Viviversum2 NetworkManager[412]: <info> [1635740722.5838] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 05:25:22 Viviversum2 NetworkManager[412]: <info> [1635740722.9012] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 05:25:23 Viviversum2 NetworkManager[412]: <info> [1635740723.1107] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 05:25:23 Viviversum2 NetworkManager[412]: <info> [1635740723.1110] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 05:25:24 Viviversum2 NetworkManager[412]: <info> [1635740724.0800] device (wlp3s0): set-hw-addr: set MAC address to 0A:98:B2:25:33:B6 (scanning)
Nov 01 05:25:24 Viviversum2 NetworkManager[412]: <info> [1635740724.3899] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 05:25:24 Viviversum2 NetworkManager[412]: <info> [1635740724.3899] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.5251] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.5252] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.5268] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.7606] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.7610] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.7610] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.7633] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.7635] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.7637] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 05:25:28 Viviversum2 NetworkManager[412]: <info> [1635740728.8598] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 05:25:29 Viviversum2 NetworkManager[412]: <info> [1635740729.0808] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 05:25:33 Viviversum2 NetworkManager[412]: <info> [1635740733.4235] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:25:33 Viviversum2 NetworkManager[412]: <info> [1635740733.4305] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:25:33 Viviversum2 NetworkManager[412]: <info> [1635740733.7781] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:25:34 Viviversum2 NetworkManager[412]: <info> [1635740734.0948] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:25:38 Viviversum2 NetworkManager[412]: <info> [1635740738.2491] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:25:38 Viviversum2 NetworkManager[412]: <info> [1635740738.2558] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:25:38 Viviversum2 NetworkManager[412]: <info> [1635740738.6118] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:25:39 Viviversum2 NetworkManager[412]: <info> [1635740739.3303] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:25:43 Viviversum2 NetworkManager[412]: <info> [1635740743.4856] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:25:43 Viviversum2 NetworkManager[412]: <info> [1635740743.5374] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:25:43 Viviversum2 NetworkManager[412]: <info> [1635740743.8848] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:25:45 Viviversum2 NetworkManager[412]: <info> [1635740745.1015] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:25:49 Viviversum2 NetworkManager[412]: <info> [1635740749.2617] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:25:49 Viviversum2 NetworkManager[412]: <info> [1635740749.2651] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:25:49 Viviversum2 NetworkManager[412]: <info> [1635740749.6176] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <warn> [1635740754.1570] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.1571] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <warn> [1635740754.1576] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <warn> [1635740754.1579] device (wlp3s0): no secrets: No agents were available for this request.
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.1580] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.1584] manager: NetworkManager state is now DISCONNECTED
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.1596] device (wlp3s0): set-hw-addr: set MAC address to 76:B6:ED:B9:04:5C (scanning)
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <warn> [1635740754.3885] device (wlp3s0): Activation: failed for connection 'Viviversum'
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.3912] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.3916] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 05:25:54 Viviversum2 NetworkManager[412]: <info> [1635740754.4087] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 05:25:55 Viviversum2 NetworkManager[412]: <info> [1635740755.5497] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 05:25:55 Viviversum2 NetworkManager[412]: <info> [1635740755.5519] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 05:37:06 Viviversum2 NetworkManager[406]: <info> [1635741426.4161] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 05:37:06 Viviversum2 NetworkManager[406]: <info> [1635741426.4419] ovsdb: disconnected from ovsdb
Nov 01 05:37:06 Viviversum2 NetworkManager[406]: <info> [1635741426.5663] device (wlan0): driver supports Access Point (AP) mode
Nov 01 05:37:06 Viviversum2 NetworkManager[406]: <info> [1635741426.5672] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 05:37:06 Viviversum2 NetworkManager[406]: <info> [1635741426.8491] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 05:37:07 Viviversum2 NetworkManager[406]: <info> [1635741427.0577] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 05:37:07 Viviversum2 NetworkManager[406]: <info> [1635741427.0578] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 05:37:07 Viviversum2 NetworkManager[406]: <info> [1635741427.9826] device (wlp3s0): set-hw-addr: set MAC address to E6:53:20:CB:69:A3 (scanning)
Nov 01 05:37:08 Viviversum2 NetworkManager[406]: <info> [1635741428.2845] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 05:37:08 Viviversum2 NetworkManager[406]: <info> [1635741428.2846] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.4169] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.4171] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.4185] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.6515] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.6519] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.6519] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.6548] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.6551] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.6555] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.7241] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 05:37:12 Viviversum2 NetworkManager[406]: <info> [1635741432.9458] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 05:37:17 Viviversum2 NetworkManager[406]: <info> [1635741437.2442] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:37:17 Viviversum2 NetworkManager[406]: <info> [1635741437.2503] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:37:17 Viviversum2 NetworkManager[406]: <info> [1635741437.6020] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:37:17 Viviversum2 NetworkManager[406]: <info> [1635741437.9188] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 05:37:22 Viviversum2 NetworkManager[406]: <info> [1635741442.0762] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 05:37:22 Viviversum2 NetworkManager[406]: <info> [1635741442.0927] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 05:37:22 Viviversum2 NetworkManager[406]: <info> [1635741442.4467] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 05:37:23 Viviversum2 NetworkManager[406]: <info> [1635741443.1637] device (wlp3s0): state change: config -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 05:37:23 Viviversum2 NetworkManager[406]: <info> [1635741443.1641] manager: NetworkManager state is now DISCONNECTING
Nov 01 05:37:23 Viviversum2 NetworkManager[406]: <warn> [1635741443.1656] dispatcher: (3) failed: Refusing activation, D-Bus is shutting down.
Nov 01 05:37:23 Viviversum2 NetworkManager[406]: <info> [1635741443.1658] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Nov 01 05:37:23 Viviversum2 NetworkManager[406]: <info> [1635741443.1712] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:07:11 Viviversum2 NetworkManager[391]: <info> [1635743231.4035] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 06:07:11 Viviversum2 NetworkManager[391]: <info> [1635743231.4260] ovsdb: disconnected from ovsdb
Nov 01 06:07:11 Viviversum2 NetworkManager[391]: <info> [1635743231.6318] device (wlan0): driver supports Access Point (AP) mode
Nov 01 06:07:11 Viviversum2 NetworkManager[391]: <info> [1635743231.6326] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 06:07:11 Viviversum2 NetworkManager[391]: <info> [1635743231.8549] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:07:12 Viviversum2 NetworkManager[391]: <info> [1635743232.0342] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 06:07:12 Viviversum2 NetworkManager[391]: <info> [1635743232.0410] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:07:12 Viviversum2 NetworkManager[391]: <info> [1635743232.9578] device (wlp3s0): set-hw-addr: set MAC address to 0E:25:29:E0:A2:17 (scanning)
Nov 01 06:07:13 Viviversum2 NetworkManager[391]: <info> [1635743233.2576] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 06:07:13 Viviversum2 NetworkManager[391]: <info> [1635743233.2577] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.3867] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.3868] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.3881] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.6188] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.6194] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.6195] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.6225] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.6231] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.6234] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.7245] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:07:17 Viviversum2 NetworkManager[391]: <info> [1635743237.9442] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:07:22 Viviversum2 NetworkManager[391]: <info> [1635743242.2286] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:07:22 Viviversum2 NetworkManager[391]: <info> [1635743242.2324] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:07:22 Viviversum2 NetworkManager[391]: <info> [1635743242.5766] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:07:22 Viviversum2 NetworkManager[391]: <info> [1635743242.8907] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:07:25 Viviversum2 NetworkManager[391]: <info> [1635743245.7441] device (wlp3s0): state change: config -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 06:07:25 Viviversum2 NetworkManager[391]: <info> [1635743245.7444] manager: NetworkManager state is now DISCONNECTING
Nov 01 06:07:25 Viviversum2 NetworkManager[391]: <warn> [1635743245.7454] dispatcher: (3) failed: Refusing activation, D-Bus is shutting down.
Nov 01 06:07:25 Viviversum2 NetworkManager[391]: <info> [1635743245.7455] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Nov 01 06:07:25 Viviversum2 NetworkManager[391]: <info> [1635743245.7486] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:07:42 Viviversum2 NetworkManager[418]: <info> [1635743262.4171] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 06:07:42 Viviversum2 NetworkManager[418]: <info> [1635743262.4612] ovsdb: disconnected from ovsdb
Nov 01 06:07:42 Viviversum2 NetworkManager[418]: <info> [1635743262.5318] device (wlan0): driver supports Access Point (AP) mode
Nov 01 06:07:42 Viviversum2 NetworkManager[418]: <info> [1635743262.5324] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 06:07:42 Viviversum2 NetworkManager[418]: <info> [1635743262.8334] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:07:43 Viviversum2 NetworkManager[418]: <info> [1635743263.0051] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 06:07:43 Viviversum2 NetworkManager[418]: <info> [1635743263.0053] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:07:43 Viviversum2 NetworkManager[418]: <info> [1635743263.9499] device (wlp3s0): set-hw-addr: set MAC address to B2:12:27:50:75:89 (scanning)
Nov 01 06:07:44 Viviversum2 NetworkManager[418]: <info> [1635743264.2687] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 06:07:44 Viviversum2 NetworkManager[418]: <info> [1635743264.2688] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.4039] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.4040] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.4055] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6387] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6390] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6391] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6403] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6404] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6406] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.6988] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:07:48 Viviversum2 NetworkManager[418]: <info> [1635743268.9201] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:07:53 Viviversum2 NetworkManager[418]: <info> [1635743273.2258] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:07:53 Viviversum2 NetworkManager[418]: <info> [1635743273.2309] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:07:53 Viviversum2 NetworkManager[418]: <info> [1635743273.5836] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:07:53 Viviversum2 NetworkManager[418]: <info> [1635743273.9020] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:07:58 Viviversum2 NetworkManager[418]: <info> [1635743278.0542] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:07:58 Viviversum2 NetworkManager[418]: <info> [1635743278.0575] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:07:58 Viviversum2 NetworkManager[418]: <info> [1635743278.4168] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:07:59 Viviversum2 NetworkManager[418]: <info> [1635743279.1379] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:08:01 Viviversum2 NetworkManager[418]: <info> [1635743281.9422] device (wlp3s0): state change: config -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 06:08:01 Viviversum2 NetworkManager[418]: <info> [1635743281.9425] manager: NetworkManager state is now DISCONNECTING
Nov 01 06:08:01 Viviversum2 NetworkManager[418]: <warn> [1635743281.9445] dispatcher: (3) failed: Refusing activation, D-Bus is shutting down.
Nov 01 06:08:01 Viviversum2 NetworkManager[418]: <info> [1635743281.9447] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Nov 01 06:08:01 Viviversum2 NetworkManager[418]: <info> [1635743281.9482] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:18:32 Viviversum2 NetworkManager[405]: <info> [1635743912.4223] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 06:18:32 Viviversum2 NetworkManager[405]: <info> [1635743912.4475] ovsdb: disconnected from ovsdb
Nov 01 06:18:32 Viviversum2 NetworkManager[405]: <info> [1635743912.5062] device (wlan0): driver supports Access Point (AP) mode
Nov 01 06:18:32 Viviversum2 NetworkManager[405]: <info> [1635743912.5066] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 06:18:32 Viviversum2 NetworkManager[405]: <info> [1635743912.9179] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:18:33 Viviversum2 NetworkManager[405]: <info> [1635743913.1659] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 06:18:33 Viviversum2 NetworkManager[405]: <info> [1635743913.1697] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.0953] device (wlp3s0): set-hw-addr: set MAC address to C2:45:E1:7E:42:93 (scanning)
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.4310] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.4310] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.7099] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.7118] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.7123] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:34 Viviversum2 NetworkManager[405]: <info> [1635743914.7131] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.5721] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.5722] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.5737] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8041] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8044] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8045] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8077] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8081] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8084] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:18:38 Viviversum2 NetworkManager[405]: <info> [1635743918.8542] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:18:39 Viviversum2 NetworkManager[405]: <info> [1635743919.0742] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:18:43 Viviversum2 NetworkManager[405]: <info> [1635743923.3547] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:18:43 Viviversum2 NetworkManager[405]: <info> [1635743923.3586] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:18:43 Viviversum2 NetworkManager[405]: <info> [1635743923.7121] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:18:44 Viviversum2 NetworkManager[405]: <info> [1635743924.0288] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:18:48 Viviversum2 NetworkManager[405]: <info> [1635743928.1862] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:18:48 Viviversum2 NetworkManager[405]: <info> [1635743928.1897] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:18:48 Viviversum2 NetworkManager[405]: <info> [1635743928.5388] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:18:49 Viviversum2 NetworkManager[405]: <info> [1635743929.2561] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:18:53 Viviversum2 NetworkManager[405]: <info> [1635743933.4128] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:18:53 Viviversum2 NetworkManager[405]: <info> [1635743933.4163] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:18:53 Viviversum2 NetworkManager[405]: <info> [1635743933.7655] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:18:54 Viviversum2 NetworkManager[405]: <info> [1635743934.9820] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:18:59 Viviversum2 NetworkManager[405]: <info> [1635743939.0675] dhcp6 (enp2s0): state changed unknown -> bound
Nov 01 06:18:59 Viviversum2 NetworkManager[405]: <info> [1635743939.1395] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:18:59 Viviversum2 NetworkManager[405]: <info> [1635743939.1429] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:18:59 Viviversum2 NetworkManager[405]: <info> [1635743939.4987] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:19:00 Viviversum2 NetworkManager[405]: <info> [1635743940.1857] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 01 06:19:00 Viviversum2 NetworkManager[405]: <info> [1635743940.2005] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 01 06:19:00 Viviversum2 NetworkManager[405]: <info> [1635743940.2009] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <warn> [1635743944.1591] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <info> [1635743944.1592] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <warn> [1635743944.1597] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <warn> [1635743944.1600] device (wlp3s0): no secrets: No agents were available for this request.
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <info> [1635743944.1600] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <info> [1635743944.1616] device (wlp3s0): set-hw-addr: set MAC address to 06:CB:CA:3A:1B:53 (scanning)
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <warn> [1635743944.3949] device (wlp3s0): Activation: failed for connection 'Viviversum'
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <info> [1635743944.3966] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <info> [1635743944.3969] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 06:19:04 Viviversum2 NetworkManager[405]: <info> [1635743944.4664] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:19:08 Viviversum2 NetworkManager[405]: <info> [1635743948.8601] dhcp4 (enp2s0): state changed unknown -> bound, address=192.168.1.207
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.1053] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.1054] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.1064] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3342] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3345] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3345] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3355] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3364] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3365] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3367] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.3994] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:20:28 Viviversum2 NetworkManager[405]: <info> [1635744028.6203] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:20:32 Viviversum2 NetworkManager[405]: <info> [1635744032.7835] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:20:32 Viviversum2 NetworkManager[405]: <info> [1635744032.7880] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:20:33 Viviversum2 NetworkManager[405]: <info> [1635744033.1624] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:20:43 Viviversum2 NetworkManager[405]: <info> [1635744043.3887] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:20:47 Viviversum2 NetworkManager[405]: <info> [1635744047.4990] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:20:47 Viviversum2 NetworkManager[405]: <info> [1635744047.5030] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:20:47 Viviversum2 NetworkManager[405]: <info> [1635744047.8514] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:20:53 Viviversum2 NetworkManager[405]: <warn> [1635744053.1589] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:20:53 Viviversum2 NetworkManager[405]: <info> [1635744053.1590] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:53 Viviversum2 NetworkManager[405]: <warn> [1635744053.1596] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:20:57 Viviversum2 NetworkManager[405]: <info> [1635744057.6933] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:57 Viviversum2 NetworkManager[405]: <info> [1635744057.6938] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:20:57 Viviversum2 NetworkManager[405]: <info> [1635744057.6942] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:20:57 Viviversum2 NetworkManager[405]: <info> [1635744057.9255] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:21:02 Viviversum2 NetworkManager[405]: <info> [1635744062.0295] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:21:02 Viviversum2 NetworkManager[405]: <info> [1635744062.0331] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:21:02 Viviversum2 NetworkManager[405]: <info> [1635744062.3786] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:21:12 Viviversum2 NetworkManager[405]: <info> [1635744072.6016] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:21:16 Viviversum2 NetworkManager[405]: <info> [1635744076.7230] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:21:16 Viviversum2 NetworkManager[405]: <info> [1635744076.7259] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:21:17 Viviversum2 NetworkManager[405]: <info> [1635744077.0723] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:21:23 Viviversum2 NetworkManager[405]: <warn> [1635744083.1591] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:21:23 Viviversum2 NetworkManager[405]: <info> [1635744083.1592] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:21:23 Viviversum2 NetworkManager[405]: <warn> [1635744083.1598] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <warn> [1635744085.4839] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <info> [1635744085.4840] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <info> [1635744085.4859] device (wlp3s0): set-hw-addr: set MAC address to 26:BC:6C:69:95:C7 (scanning)
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <warn> [1635744085.7250] device (wlp3s0): Activation: failed for connection 'Viviversum'
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <info> [1635744085.7288] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <info> [1635744085.7290] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 06:21:25 Viviversum2 NetworkManager[405]: <info> [1635744085.7991] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:28:18 Viviversum2 NetworkManager[405]: <info> [1635744498.1889] device (wlp3s0): set-hw-addr: set MAC address to 02:41:26:0C:21:16 (scanning)
Nov 01 06:28:18 Viviversum2 NetworkManager[405]: <info> [1635744498.4247] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:28:18 Viviversum2 NetworkManager[405]: <info> [1635744498.4928] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:35:13 Viviversum2 NetworkManager[405]: <info> [1635744913.1761] device (wlp3s0): set-hw-addr: set MAC address to 46:B5:A9:86:B9:C3 (scanning)
Nov 01 06:35:13 Viviversum2 NetworkManager[405]: <info> [1635744913.4142] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:35:13 Viviversum2 NetworkManager[405]: <info> [1635744913.4528] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:40:49 Viviversum2 NetworkManager[405]: <info> [1635745249.9183] dhcp4 (enp2s0): state changed bound -> terminated
Nov 01 06:40:49 Viviversum2 NetworkManager[405]: <info> [1635745249.9184] dhcp6 (enp2s0): state changed bound -> terminated
Nov 01 06:40:49 Viviversum2 NetworkManager[405]: <info> [1635745249.9191] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 06:40:49 Viviversum2 NetworkManager[405]: <info> [1635745249.9202] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 06:41:17 Viviversum2 NetworkManager[421]: <info> [1635745277.4441] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 06:41:17 Viviversum2 NetworkManager[421]: <info> [1635745277.4731] ovsdb: disconnected from ovsdb
Nov 01 06:41:17 Viviversum2 NetworkManager[421]: <info> [1635745277.6171] device (wlan0): driver supports Access Point (AP) mode
Nov 01 06:41:17 Viviversum2 NetworkManager[421]: <info> [1635745277.6177] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 06:41:17 Viviversum2 NetworkManager[421]: <info> [1635745277.9360] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:41:18 Viviversum2 NetworkManager[421]: <info> [1635745278.1974] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 06:41:18 Viviversum2 NetworkManager[421]: <info> [1635745278.2026] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:41:19 Viviversum2 NetworkManager[421]: <info> [1635745279.1180] device (wlp3s0): set-hw-addr: set MAC address to 36:94:6C:B8:25:9A (scanning)
Nov 01 06:41:19 Viviversum2 NetworkManager[421]: <info> [1635745279.4554] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 06:41:19 Viviversum2 NetworkManager[421]: <info> [1635745279.4555] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.5875] device (wlp3s0): Activation: starting connection 'Viviversum' (a0853823-357a-45d1-b512-647b18f5e71f)
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.5875] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.5890] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8223] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8228] device (wlp3s0): Activation: (wifi) access point 'Viviversum' has security, but secrets are required.
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8228] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8249] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8251] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8254] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:41:23 Viviversum2 NetworkManager[421]: <info> [1635745283.8715] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:41:24 Viviversum2 NetworkManager[421]: <info> [1635745284.0978] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:41:28 Viviversum2 NetworkManager[421]: <info> [1635745288.3931] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:41:28 Viviversum2 NetworkManager[421]: <info> [1635745288.3963] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:41:28 Viviversum2 NetworkManager[421]: <info> [1635745288.7507] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:41:29 Viviversum2 NetworkManager[421]: <info> [1635745289.0710] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:41:33 Viviversum2 NetworkManager[421]: <info> [1635745293.2245] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:41:33 Viviversum2 NetworkManager[421]: <info> [1635745293.2314] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:41:33 Viviversum2 NetworkManager[421]: <info> [1635745293.5906] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:41:34 Viviversum2 NetworkManager[421]: <info> [1635745294.3110] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:41:38 Viviversum2 NetworkManager[421]: <info> [1635745298.4814] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:41:38 Viviversum2 NetworkManager[421]: <info> [1635745298.4854] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:41:38 Viviversum2 NetworkManager[421]: <info> [1635745298.8306] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:41:40 Viviversum2 NetworkManager[421]: <info> [1635745300.0461] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:41:44 Viviversum2 NetworkManager[421]: <info> [1635745304.2015] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:41:44 Viviversum2 NetworkManager[421]: <info> [1635745304.2092] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:41:44 Viviversum2 NetworkManager[421]: <info> [1635745304.5508] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:41:49 Viviversum2 NetworkManager[421]: <warn> [1635745309.1584] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:41:49 Viviversum2 NetworkManager[421]: <info> [1635745309.1585] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:49 Viviversum2 NetworkManager[421]: <warn> [1635745309.1596] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:41:49 Viviversum2 NetworkManager[421]: <info> [1635745309.5506] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:41:55 Viviversum2 NetworkManager[421]: <info> [1635745315.5991] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:55 Viviversum2 NetworkManager[421]: <info> [1635745315.5995] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:41:55 Viviversum2 NetworkManager[421]: <info> [1635745315.5999] device (wlp3s0): Activation: (wifi) connection 'Viviversum' has security, and secrets exist. No new secrets needed.
Nov 01 06:41:55 Viviversum2 NetworkManager[421]: <info> [1635745315.8343] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:41:59 Viviversum2 NetworkManager[421]: <info> [1635745319.9414] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:41:59 Viviversum2 NetworkManager[421]: <info> [1635745319.9449] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:42:00 Viviversum2 NetworkManager[421]: <info> [1635745320.2972] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:42:10 Viviversum2 NetworkManager[421]: <info> [1635745330.5177] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:42:14 Viviversum2 NetworkManager[421]: <info> [1635745334.6282] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:42:14 Viviversum2 NetworkManager[421]: <info> [1635745334.6317] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:42:14 Viviversum2 NetworkManager[421]: <info> [1635745334.9774] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:42:21 Viviversum2 NetworkManager[421]: <warn> [1635745341.1569] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:42:21 Viviversum2 NetworkManager[421]: <info> [1635745341.1569] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:42:21 Viviversum2 NetworkManager[421]: <warn> [1635745341.1576] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:42:24 Viviversum2 NetworkManager[421]: <info> [1635745344.9811] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <warn> [1635745461.1654] device (wlp3s0): no secrets: No agents were available for this request.
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <info> [1635745461.1655] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <info> [1635745461.1660] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <info> [1635745461.1677] device (wlp3s0): set-hw-addr: set MAC address to 5E:40:63:C2:B7:7A (scanning)
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <warn> [1635745461.4087] device (wlp3s0): Activation: failed for connection 'Viviversum'
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <info> [1635745461.4125] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <info> [1635745461.4129] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 06:44:21 Viviversum2 NetworkManager[421]: <info> [1635745461.4789] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.0315] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.0324] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.0348] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.2752] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.2758] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.2758] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.2796] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:47:35 Viviversum2 NetworkManager[421]: <info> [1635745655.3630] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:48:12 Viviversum2 NetworkManager[421]: <info> [1635745692.8652] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:48:12 Viviversum2 NetworkManager[421]: <info> [1635745692.8659] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:48:12 Viviversum2 NetworkManager[421]: <info> [1635745692.8664] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 06:48:13 Viviversum2 NetworkManager[421]: <info> [1635745693.0995] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:48:17 Viviversum2 NetworkManager[421]: <info> [1635745697.2144] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:48:17 Viviversum2 NetworkManager[421]: <info> [1635745697.2190] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:48:17 Viviversum2 NetworkManager[421]: <info> [1635745697.5775] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:48:27 Viviversum2 NetworkManager[421]: <info> [1635745707.8030] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:48:31 Viviversum2 NetworkManager[421]: <info> [1635745711.9081] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:48:31 Viviversum2 NetworkManager[421]: <info> [1635745711.9115] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:48:32 Viviversum2 NetworkManager[421]: <info> [1635745712.2575] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:48:38 Viviversum2 NetworkManager[421]: <warn> [1635745718.1578] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:48:38 Viviversum2 NetworkManager[421]: <info> [1635745718.1579] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:48:38 Viviversum2 NetworkManager[421]: <warn> [1635745718.1588] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <warn> [1635745721.5829] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <info> [1635745721.5830] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <info> [1635745721.5836] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <info> [1635745721.5857] device (wlp3s0): set-hw-addr: set MAC address to CA:03:57:00:38:96 (scanning)
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <warn> [1635745721.8251] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <info> [1635745721.8294] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <info> [1635745721.8299] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 06:48:41 Viviversum2 NetworkManager[421]: <info> [1635745721.8616] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:52:34 Viviversum2 NetworkManager[421]: <info> [1635745954.9147] device (wlp3s0): Activation: starting connection 'OnePlus Nord' (baeb1149-e03f-4e5d-bc14-30645bd17428)
Nov 01 06:52:34 Viviversum2 NetworkManager[421]: <info> [1635745954.9152] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:34 Viviversum2 NetworkManager[421]: <info> [1635745954.9169] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 06:52:35 Viviversum2 NetworkManager[421]: <info> [1635745955.1534] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:35 Viviversum2 NetworkManager[421]: <info> [1635745955.1538] device (wlp3s0): Activation: (wifi) access point 'OnePlus Nord' has security, but secrets are required.
Nov 01 06:52:35 Viviversum2 NetworkManager[421]: <info> [1635745955.1538] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:35 Viviversum2 NetworkManager[421]: <info> [1635745955.1571] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:52:35 Viviversum2 NetworkManager[421]: <info> [1635745955.2000] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:52:45 Viviversum2 NetworkManager[421]: <info> [1635745965.9205] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:45 Viviversum2 NetworkManager[421]: <info> [1635745965.9211] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:45 Viviversum2 NetworkManager[421]: <info> [1635745965.9219] device (wlp3s0): Activation: (wifi) connection 'OnePlus Nord' has security, and secrets exist. No new secrets needed.
Nov 01 06:52:46 Viviversum2 NetworkManager[421]: <info> [1635745966.1552] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.3967] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.4029] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.4283] device (wlp3s0): supplicant interface state: associating -> associated
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.4404] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.5718] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.5720] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "OnePlus Nord"
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.5722] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.5728] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.6104] dhcp4 (wlp3s0): state changed unknown -> bound, address=192.168.13.47
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.6129] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.6274] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.6277] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.6304] policy: set 'OnePlus Nord' (wlp3s0) as default for IPv4 routing and DNS
Nov 01 06:52:50 Viviversum2 NetworkManager[421]: <info> [1635745970.6343] device (wlp3s0): Activation: successful, device activated.
Nov 01 06:55:57 Viviversum2 NetworkManager[421]: <info> [1635746157.3477] device (wlp3s0): supplicant interface state: completed -> disconnected
Nov 01 06:55:57 Viviversum2 NetworkManager[421]: <info> [1635746157.6684] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:56:01 Viviversum2 NetworkManager[421]: <info> [1635746161.8815] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:56:01 Viviversum2 NetworkManager[421]: <info> [1635746161.9907] device (wlp3s0): supplicant interface state: authenticating -> disconnected
Nov 01 06:56:02 Viviversum2 NetworkManager[421]: <info> [1635746162.7107] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <warn> [1635746172.1575] device (wlp3s0): link timed out.
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.1577] device (wlp3s0): state change: activated -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.1582] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.1617] device (wlp3s0): set-hw-addr: set MAC address to 2E:71:72:8B:D7:11 (scanning)
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <warn> [1635746172.4179] device (wlp3s0): Activation: failed for connection 'OnePlus Nord'
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.4215] device (wlp3s0): supplicant interface state: scanning -> interface_disabled
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.4224] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.4637] dhcp4 (wlp3s0): canceled DHCP transaction
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.4637] dhcp4 (wlp3s0): state changed bound -> terminated
Nov 01 06:56:12 Viviversum2 NetworkManager[421]: <info> [1635746172.5050] device (wlp3s0): supplicant interface state: interface_disabled -> scanning
Nov 01 06:56:16 Viviversum2 NetworkManager[421]: <info> [1635746176.8163] device (wlp3s0): supplicant interface state: scanning -> disconnected
Nov 01 06:56:20 Viviversum2 NetworkManager[421]: <info> [1635746180.6779] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 06:58:19 Viviversum2 NetworkManager[421]: <info> [1635746299.1336] device (enp2s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 06:58:19 Viviversum2 NetworkManager[421]: <info> [1635746299.3580] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 06:58:19 Viviversum2 NetworkManager[421]: <info> [1635746299.3596] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 06:58:28 Viviversum2 NetworkManager[421]: <info> [1635746308.0256] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:58:28 Viviversum2 NetworkManager[421]: <info> [1635746308.2082] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 06:58:28 Viviversum2 NetworkManager[421]: <info> [1635746308.2101] manager: NetworkManager state is now DISCONNECTED
Nov 01 06:58:28 Viviversum2 NetworkManager[421]: <info> [1635746308.2817] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 06:58:28 Viviversum2 NetworkManager[421]: <info> [1635746308.2818] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 06:58:29 Viviversum2 NetworkManager[421]: <info> [1635746309.7024] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Nov 01 06:58:29 Viviversum2 NetworkManager[421]: <info> [1635746309.7053] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:29 Viviversum2 NetworkManager[421]: <info> [1635746309.7060] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:29 Viviversum2 NetworkManager[421]: <info> [1635746309.7076] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3334] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3335] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3337] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3340] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3340] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3361] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3363] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.3371] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.7728] device (wlp3s0): supplicant interface state: disconnected -> authenticating
Nov 01 06:58:32 Viviversum2 NetworkManager[421]: <info> [1635746312.7767] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:58:33 Viviversum2 NetworkManager[421]: <info> [1635746313.1237] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:58:33 Viviversum2 NetworkManager[421]: <info> [1635746313.4438] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:58:37 Viviversum2 NetworkManager[421]: <info> [1635746317.5513] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:58:37 Viviversum2 NetworkManager[421]: <info> [1635746317.5548] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:58:37 Viviversum2 NetworkManager[421]: <info> [1635746317.9080] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:58:38 Viviversum2 NetworkManager[421]: <info> [1635746318.6311] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:58:42 Viviversum2 NetworkManager[421]: <info> [1635746322.7411] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:58:42 Viviversum2 NetworkManager[421]: <info> [1635746322.7443] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:58:43 Viviversum2 NetworkManager[421]: <info> [1635746323.0973] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:58:44 Viviversum2 NetworkManager[421]: <info> [1635746324.3163] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:58:48 Viviversum2 NetworkManager[421]: <info> [1635746328.4247] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 06:58:48 Viviversum2 NetworkManager[421]: <info> [1635746328.4282] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 06:58:48 Viviversum2 NetworkManager[421]: <info> [1635746328.7772] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 06:58:53 Viviversum2 NetworkManager[421]: <info> [1635746333.9948] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 06:58:55 Viviversum2 NetworkManager[421]: <info> [1635746335.4116] dhcp6 (enp2s0): state changed unknown -> bound
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <warn> [1635746337.1579] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <info> [1635746337.1580] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <warn> [1635746337.1587] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <info> [1635746337.1839] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <info> [1635746337.1870] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <info> [1635746337.1874] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 01 06:58:57 Viviversum2 NetworkManager[421]: <info> [1635746337.8299] device (wlp3s0): supplicant interface state: scanning -> inactive
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <warn> [1635746341.1360] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <info> [1635746341.1361] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <info> [1635746341.1384] device (wlp3s0): set-hw-addr: set MAC address to 4E:1D:68:BD:38:F5 (scanning)
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <warn> [1635746341.3787] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <info> [1635746341.3806] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <info> [1635746341.3811] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 06:59:01 Viviversum2 NetworkManager[421]: <info> [1635746341.4226] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 06:59:04 Viviversum2 NetworkManager[421]: <info> [1635746344.1010] dhcp4 (enp2s0): state changed unknown -> bound, address=192.168.1.207
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.4872] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.4879] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.4915] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7303] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7310] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7311] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7354] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7372] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7379] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7386] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 07:02:06 Viviversum2 NetworkManager[421]: <info> [1635746526.7979] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:02:07 Viviversum2 NetworkManager[421]: <info> [1635746527.0296] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 07:02:11 Viviversum2 NetworkManager[421]: <info> [1635746531.1415] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:02:11 Viviversum2 NetworkManager[421]: <info> [1635746531.1512] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:02:11 Viviversum2 NetworkManager[421]: <info> [1635746531.5107] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:02:21 Viviversum2 NetworkManager[421]: <info> [1635746541.7282] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 07:02:25 Viviversum2 NetworkManager[421]: <info> [1635746545.8511] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:02:25 Viviversum2 NetworkManager[421]: <info> [1635746545.8604] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:02:26 Viviversum2 NetworkManager[421]: <info> [1635746546.2037] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:02:32 Viviversum2 NetworkManager[421]: <warn> [1635746552.1578] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 07:02:32 Viviversum2 NetworkManager[421]: <info> [1635746552.1578] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:32 Viviversum2 NetworkManager[421]: <warn> [1635746552.1585] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 07:02:36 Viviversum2 NetworkManager[421]: <info> [1635746556.2079] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 07:02:45 Viviversum2 NetworkManager[421]: <info> [1635746565.3956] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:45 Viviversum2 NetworkManager[421]: <info> [1635746565.3960] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:02:45 Viviversum2 NetworkManager[421]: <info> [1635746565.3968] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 07:02:45 Viviversum2 NetworkManager[421]: <info> [1635746565.6282] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 07:02:49 Viviversum2 NetworkManager[421]: <info> [1635746569.7379] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:02:49 Viviversum2 NetworkManager[421]: <info> [1635746569.7471] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:02:50 Viviversum2 NetworkManager[421]: <info> [1635746570.1052] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:03:00 Viviversum2 NetworkManager[421]: <info> [1635746580.3330] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 07:03:04 Viviversum2 NetworkManager[421]: <info> [1635746584.4382] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:03:04 Viviversum2 NetworkManager[421]: <info> [1635746584.4477] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:03:04 Viviversum2 NetworkManager[421]: <info> [1635746584.8037] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:03:10 Viviversum2 NetworkManager[421]: <warn> [1635746590.1600] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 07:03:10 Viviversum2 NetworkManager[421]: <info> [1635746590.1601] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:03:10 Viviversum2 NetworkManager[421]: <warn> [1635746590.1607] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <warn> [1635746593.0932] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <info> [1635746593.0933] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <info> [1635746593.0954] device (wlp3s0): set-hw-addr: set MAC address to 76:31:03:08:8B:26 (scanning)
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <warn> [1635746593.3359] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <info> [1635746593.3375] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <info> [1635746593.3377] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 07:03:13 Viviversum2 NetworkManager[421]: <info> [1635746593.3981] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.0441] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.0444] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.0473] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2806] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2811] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2811] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2814] sup-iface[d62fe0465b1f0e51,1,wlp3s0]: wps: type pbc start...
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2833] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2843] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2845] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.2850] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.3315] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:04:06 Viviversum2 NetworkManager[421]: <info> [1635746646.5593] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 07:04:10 Viviversum2 NetworkManager[421]: <info> [1635746650.8365] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:04:10 Viviversum2 NetworkManager[421]: <info> [1635746650.8451] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:04:11 Viviversum2 NetworkManager[421]: <info> [1635746651.1946] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:04:21 Viviversum2 NetworkManager[421]: <info> [1635746661.4162] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 07:04:25 Viviversum2 NetworkManager[421]: <info> [1635746665.5540] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:04:25 Viviversum2 NetworkManager[421]: <info> [1635746665.5635] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:04:25 Viviversum2 NetworkManager[421]: <info> [1635746665.9194] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:04:31 Viviversum2 NetworkManager[421]: <warn> [1635746671.1573] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 07:04:31 Viviversum2 NetworkManager[421]: <info> [1635746671.1574] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:31 Viviversum2 NetworkManager[421]: <info> [1635746671.1576] sup-iface[d62fe0465b1f0e51,1,wlp3s0]: wps: type pbc start...
Nov 01 07:04:31 Viviversum2 NetworkManager[421]: <warn> [1635746671.1581] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 07:04:31 Viviversum2 NetworkManager[421]: <info> [1635746671.3817] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 07:04:40 Viviversum2 NetworkManager[421]: <warn> [1635746680.7667] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 07:04:40 Viviversum2 NetworkManager[421]: <info> [1635746680.7668] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 07:04:40 Viviversum2 NetworkManager[421]: <info> [1635746680.7687] device (wlp3s0): set-hw-addr: set MAC address to B2:30:D7:83:EA:A6 (scanning)
Nov 01 07:04:41 Viviversum2 NetworkManager[421]: <warn> [1635746681.0105] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 07:04:41 Viviversum2 NetworkManager[421]: <info> [1635746681.0115] device (wlp3s0): supplicant interface state: scanning -> interface_disabled
Nov 01 07:04:41 Viviversum2 NetworkManager[421]: <info> [1635746681.0116] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 07:04:41 Viviversum2 NetworkManager[421]: <info> [1635746681.0784] device (wlp3s0): supplicant interface state: interface_disabled -> scanning
Nov 01 07:04:45 Viviversum2 NetworkManager[421]: <info> [1635746685.3410] device (wlp3s0): supplicant interface state: scanning -> disconnected
Nov 01 07:04:49 Viviversum2 NetworkManager[421]: <info> [1635746689.1609] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 07:11:10 Viviversum2 NetworkManager[421]: <info> [1635747070.6229] device (wlp3s0): set-hw-addr: set MAC address to 02:26:BA:93:68:E6 (scanning)
Nov 01 07:11:10 Viviversum2 NetworkManager[421]: <info> [1635747070.8641] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:11:10 Viviversum2 NetworkManager[421]: <info> [1635747070.9447] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.6196] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.6205] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.6246] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8620] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8623] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8624] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8626] sup-iface[d62fe0465b1f0e51,1,wlp3s0]: wps: type pbc start...
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8653] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8670] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8676] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.8683] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 07:11:18 Viviversum2 NetworkManager[421]: <info> [1635747078.9448] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:11:19 Viviversum2 NetworkManager[421]: <info> [1635747079.1794] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 07:11:23 Viviversum2 NetworkManager[421]: <info> [1635747083.3080] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:11:23 Viviversum2 NetworkManager[421]: <info> [1635747083.3179] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:11:23 Viviversum2 NetworkManager[421]: <info> [1635747083.6608] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:11:33 Viviversum2 NetworkManager[421]: <info> [1635747093.8839] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 07:11:38 Viviversum2 NetworkManager[421]: <info> [1635747098.0276] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 07:11:38 Viviversum2 NetworkManager[421]: <info> [1635747098.0385] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 07:11:38 Viviversum2 NetworkManager[421]: <info> [1635747098.3861] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 07:11:44 Viviversum2 NetworkManager[421]: <warn> [1635747104.1576] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 07:11:44 Viviversum2 NetworkManager[421]: <info> [1635747104.1577] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 07:11:44 Viviversum2 NetworkManager[421]: <info> [1635747104.1580] sup-iface[d62fe0465b1f0e51,1,wlp3s0]: wps: type pbc start...
Nov 01 07:11:44 Viviversum2 NetworkManager[421]: <warn> [1635747104.1587] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 07:11:44 Viviversum2 NetworkManager[421]: <info> [1635747104.3858] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <warn> [1635747224.1669] device (wlp3s0): no secrets: No agents were available for this request.
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <info> [1635747224.1670] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <info> [1635747224.1710] device (wlp3s0): set-hw-addr: set MAC address to 86:E5:76:C2:76:7F (scanning)
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <warn> [1635747224.4119] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <info> [1635747224.4194] device (wlp3s0): supplicant interface state: scanning -> interface_disabled
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <info> [1635747224.4197] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 07:13:44 Viviversum2 NetworkManager[421]: <info> [1635747224.4784] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:20:36 Viviversum2 NetworkManager[421]: <info> [1635747636.1910] device (wlp3s0): set-hw-addr: set MAC address to 2E:3B:1A:1F:D4:97 (scanning)
Nov 01 07:20:36 Viviversum2 NetworkManager[421]: <info> [1635747636.4236] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:20:36 Viviversum2 NetworkManager[421]: <info> [1635747636.4648] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:27:31 Viviversum2 NetworkManager[421]: <info> [1635748051.1590] device (wlp3s0): set-hw-addr: set MAC address to CE:B2:1D:8D:37:57 (scanning)
Nov 01 07:27:31 Viviversum2 NetworkManager[421]: <info> [1635748051.4026] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:27:31 Viviversum2 NetworkManager[421]: <info> [1635748051.4648] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:34:24 Viviversum2 NetworkManager[421]: <info> [1635748464.1653] device (wlp3s0): set-hw-addr: set MAC address to 9E:34:21:9F:C9:6A (scanning)
Nov 01 07:34:24 Viviversum2 NetworkManager[421]: <info> [1635748464.4046] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:34:24 Viviversum2 NetworkManager[421]: <info> [1635748464.4391] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:41:19 Viviversum2 NetworkManager[421]: <info> [1635748879.1613] device (wlp3s0): set-hw-addr: set MAC address to 9E:DB:71:C9:54:5F (scanning)
Nov 01 07:41:19 Viviversum2 NetworkManager[421]: <info> [1635748879.4035] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:41:19 Viviversum2 NetworkManager[421]: <info> [1635748879.4647] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:48:13 Viviversum2 NetworkManager[421]: <info> [1635749293.1847] device (wlp3s0): set-hw-addr: set MAC address to 0A:CC:D8:CA:8E:35 (scanning)
Nov 01 07:48:13 Viviversum2 NetworkManager[421]: <info> [1635749293.4185] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:48:13 Viviversum2 NetworkManager[421]: <info> [1635749293.4780] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 07:55:06 Viviversum2 NetworkManager[421]: <info> [1635749706.1688] device (wlp3s0): set-hw-addr: set MAC address to A6:0E:0B:E2:E8:F7 (scanning)
Nov 01 07:55:06 Viviversum2 NetworkManager[421]: <info> [1635749706.4057] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 07:55:06 Viviversum2 NetworkManager[421]: <info> [1635749706.4480] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:02:02 Viviversum2 NetworkManager[421]: <info> [1635750122.1697] device (wlp3s0): set-hw-addr: set MAC address to 92:14:36:0C:2B:C1 (scanning)
Nov 01 08:02:02 Viviversum2 NetworkManager[421]: <info> [1635750122.4105] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:02:02 Viviversum2 NetworkManager[421]: <info> [1635750122.4779] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:08:56 Viviversum2 NetworkManager[421]: <info> [1635750536.1686] device (wlp3s0): set-hw-addr: set MAC address to EE:C8:70:57:BA:E8 (scanning)
Nov 01 08:08:56 Viviversum2 NetworkManager[421]: <info> [1635750536.4110] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:08:56 Viviversum2 NetworkManager[421]: <info> [1635750536.4647] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:15:47 Viviversum2 NetworkManager[421]: <info> [1635750947.1590] device (wlp3s0): set-hw-addr: set MAC address to 8A:CA:B6:EA:A4:04 (scanning)
Nov 01 08:15:47 Viviversum2 NetworkManager[421]: <info> [1635750947.4000] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:15:47 Viviversum2 NetworkManager[421]: <info> [1635750947.4645] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:22:36 Viviversum2 NetworkManager[421]: <info> [1635751356.1588] device (wlp3s0): set-hw-addr: set MAC address to F2:B9:F7:F1:A3:A4 (scanning)
Nov 01 08:22:36 Viviversum2 NetworkManager[421]: <info> [1635751356.4014] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:22:36 Viviversum2 NetworkManager[421]: <info> [1635751356.4645] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:29:25 Viviversum2 NetworkManager[421]: <info> [1635751765.1723] device (wlp3s0): set-hw-addr: set MAC address to 1A:AA:B8:7D:40:14 (scanning)
Nov 01 08:29:25 Viviversum2 NetworkManager[421]: <info> [1635751765.4142] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:29:25 Viviversum2 NetworkManager[421]: <info> [1635751765.4643] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:36:15 Viviversum2 NetworkManager[421]: <info> [1635752175.1605] device (wlp3s0): set-hw-addr: set MAC address to 96:9C:E8:4C:01:3E (scanning)
Nov 01 08:36:15 Viviversum2 NetworkManager[421]: <info> [1635752175.3994] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:36:15 Viviversum2 NetworkManager[421]: <info> [1635752175.4510] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:43:05 Viviversum2 NetworkManager[421]: <info> [1635752585.1589] device (wlp3s0): set-hw-addr: set MAC address to EA:A2:D9:5C:73:25 (scanning)
Nov 01 08:43:05 Viviversum2 NetworkManager[421]: <info> [1635752585.4079] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:43:05 Viviversum2 NetworkManager[421]: <info> [1635752585.4643] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:49:56 Viviversum2 NetworkManager[421]: <info> [1635752996.1594] device (wlp3s0): set-hw-addr: set MAC address to 5E:E5:2E:4F:1D:38 (scanning)
Nov 01 08:49:56 Viviversum2 NetworkManager[421]: <info> [1635752996.4040] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:49:56 Viviversum2 NetworkManager[421]: <info> [1635752996.4645] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 08:56:46 Viviversum2 NetworkManager[421]: <info> [1635753406.1662] device (wlp3s0): set-hw-addr: set MAC address to E2:57:91:7E:84:01 (scanning)
Nov 01 08:56:46 Viviversum2 NetworkManager[421]: <info> [1635753406.4071] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 08:56:46 Viviversum2 NetworkManager[421]: <info> [1635753406.4647] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 09:03:37 Viviversum2 NetworkManager[421]: <info> [1635753817.1598] device (wlp3s0): set-hw-addr: set MAC address to 8A:4F:0D:D8:31:E4 (scanning)
Nov 01 09:03:37 Viviversum2 NetworkManager[421]: <info> [1635753817.4005] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 09:03:37 Viviversum2 NetworkManager[421]: <info> [1635753817.4508] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 09:10:27 Viviversum2 NetworkManager[421]: <info> [1635754227.1588] device (wlp3s0): set-hw-addr: set MAC address to 62:29:AC:C8:C7:B8 (scanning)
Nov 01 09:10:27 Viviversum2 NetworkManager[421]: <info> [1635754227.3996] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 09:10:27 Viviversum2 NetworkManager[421]: <info> [1635754227.4510] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 09:17:17 Viviversum2 NetworkManager[421]: <info> [1635754637.1592] device (wlp3s0): set-hw-addr: set MAC address to 72:66:E1:0A:0B:A0 (scanning)
Nov 01 09:17:17 Viviversum2 NetworkManager[421]: <info> [1635754637.3999] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 09:17:17 Viviversum2 NetworkManager[421]: <info> [1635754637.4508] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 09:24:06 Viviversum2 NetworkManager[421]: <info> [1635755046.1591] device (wlp3s0): set-hw-addr: set MAC address to 0A:13:01:A6:B0:CB (scanning)
Nov 01 09:24:06 Viviversum2 NetworkManager[421]: <info> [1635755046.3986] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 09:24:06 Viviversum2 NetworkManager[421]: <info> [1635755046.4506] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 09:30:57 Viviversum2 NetworkManager[421]: <info> [1635755457.1591] device (wlp3s0): set-hw-addr: set MAC address to 7A:28:D7:B5:B0:69 (scanning)
Nov 01 09:30:57 Viviversum2 NetworkManager[421]: <info> [1635755457.4010] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 09:30:57 Viviversum2 NetworkManager[421]: <info> [1635755457.4506] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 09:34:01 Viviversum2 NetworkManager[421]: <info> [1635755641.2894] dhcp4 (enp2s0): state changed bound -> terminated
Nov 01 09:34:01 Viviversum2 NetworkManager[421]: <info> [1635755641.2895] dhcp6 (enp2s0): state changed bound -> terminated
Nov 01 09:34:01 Viviversum2 NetworkManager[421]: <info> [1635755641.2905] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Nov 01 09:34:01 Viviversum2 NetworkManager[421]: <info> [1635755641.2921] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 14:02:46 Viviversum2 NetworkManager[403]: <info> [1635771766.4397] hostname: hostname changed from (none) to "Viviversum2"
Nov 01 14:02:46 Viviversum2 NetworkManager[403]: <info> [1635771766.4664] ovsdb: disconnected from ovsdb
Nov 01 14:02:46 Viviversum2 NetworkManager[403]: <info> [1635771766.5449] device (wlan0): driver supports Access Point (AP) mode
Nov 01 14:02:46 Viviversum2 NetworkManager[403]: <info> [1635771766.5454] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Nov 01 14:02:46 Viviversum2 NetworkManager[403]: <info> [1635771766.9137] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 14:02:47 Viviversum2 NetworkManager[403]: <info> [1635771767.1430] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp3s0'
Nov 01 14:02:47 Viviversum2 NetworkManager[403]: <info> [1635771767.1484] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 14:02:48 Viviversum2 NetworkManager[403]: <info> [1635771768.0636] device (wlp3s0): set-hw-addr: set MAC address to 32:AB:58:17:78:79 (scanning)
Nov 01 14:02:48 Viviversum2 NetworkManager[403]: <info> [1635771768.3771] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 14:02:48 Viviversum2 NetworkManager[403]: <info> [1635771768.3772] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.5098] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.5100] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.5116] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7508] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7512] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7512] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7513] sup-iface[aa47521cfe2d0d0a,0,wlp3s0]: wps: type pbc start...
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7530] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7533] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:02:52 Viviversum2 NetworkManager[403]: <info> [1635771772.7535] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 14:02:53 Viviversum2 NetworkManager[403]: <info> [1635771773.0700] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:02:57 Viviversum2 NetworkManager[403]: <info> [1635771777.4087] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:02:57 Viviversum2 NetworkManager[403]: <info> [1635771777.4560] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:02:57 Viviversum2 NetworkManager[403]: <info> [1635771777.8030] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:02:58 Viviversum2 NetworkManager[403]: <info> [1635771778.1187] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:03:02 Viviversum2 NetworkManager[403]: <info> [1635771782.2737] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:03:02 Viviversum2 NetworkManager[403]: <info> [1635771782.3011] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:03:02 Viviversum2 NetworkManager[403]: <info> [1635771782.6562] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:03:03 Viviversum2 NetworkManager[403]: <info> [1635771783.3765] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:03:07 Viviversum2 NetworkManager[403]: <info> [1635771787.5368] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:03:07 Viviversum2 NetworkManager[403]: <info> [1635771787.5484] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:03:07 Viviversum2 NetworkManager[403]: <info> [1635771787.8963] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:03:09 Viviversum2 NetworkManager[403]: <info> [1635771789.1167] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:03:13 Viviversum2 NetworkManager[403]: <info> [1635771793.2837] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:03:13 Viviversum2 NetworkManager[403]: <info> [1635771793.3135] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:03:13 Viviversum2 NetworkManager[403]: <info> [1635771793.6697] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <warn> [1635771798.1576] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.1577] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.1579] sup-iface[aa47521cfe2d0d0a,0,wlp3s0]: wps: type pbc start...
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <warn> [1635771798.1583] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <warn> [1635771798.1588] device (wlp3s0): no secrets: No agents were available for this request.
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.1588] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.1592] manager: NetworkManager state is now DISCONNECTED
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.1606] device (wlp3s0): set-hw-addr: set MAC address to E6:21:5F:2C:AE:EF (scanning)
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <warn> [1635771798.3999] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.4011] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.4013] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 14:03:18 Viviversum2 NetworkManager[403]: <info> [1635771798.4643] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:03:22 Viviversum2 NetworkManager[403]: <info> [1635771802.9199] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 14:03:26 Viviversum2 NetworkManager[403]: <info> [1635771806.7825] device (wlp3s0): supplicant interface state: scanning -> inactive
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.4488] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.4489] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.4505] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6856] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6860] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6860] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6863] sup-iface[aa47521cfe2d0d0a,0,wlp3s0]: wps: type pbc start...
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6884] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6897] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6902] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.6907] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.7608] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:05:42 Viviversum2 NetworkManager[403]: <info> [1635771942.9938] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 14:05:47 Viviversum2 NetworkManager[403]: <info> [1635771947.1475] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:05:47 Viviversum2 NetworkManager[403]: <info> [1635771947.1564] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:05:47 Viviversum2 NetworkManager[403]: <info> [1635771947.5241] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:05:57 Viviversum2 NetworkManager[403]: <info> [1635771957.7489] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:06:01 Viviversum2 NetworkManager[403]: <info> [1635771961.9072] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:06:01 Viviversum2 NetworkManager[403]: <info> [1635771961.9251] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:06:02 Viviversum2 NetworkManager[403]: <info> [1635771962.2763] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:06:08 Viviversum2 NetworkManager[403]: <warn> [1635771968.1571] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 14:06:08 Viviversum2 NetworkManager[403]: <info> [1635771968.1572] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:06:08 Viviversum2 NetworkManager[403]: <info> [1635771968.1575] sup-iface[aa47521cfe2d0d0a,0,wlp3s0]: wps: type pbc start...
Nov 01 14:06:08 Viviversum2 NetworkManager[403]: <warn> [1635771968.1580] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 14:06:08 Viviversum2 NetworkManager[403]: <info> [1635771968.3839] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <warn> [1635771971.4789] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <info> [1635771971.4790] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <info> [1635771971.4794] manager: NetworkManager state is now DISCONNECTED
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <info> [1635771971.4827] device (wlp3s0): set-hw-addr: set MAC address to AE:A0:A6:8E:85:8C (scanning)
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <warn> [1635771971.7227] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <info> [1635771971.7253] device (wlp3s0): supplicant interface state: scanning -> interface_disabled
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <info> [1635771971.7259] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 14:06:11 Viviversum2 NetworkManager[403]: <info> [1635771971.7784] device (wlp3s0): supplicant interface state: interface_disabled -> scanning
Nov 01 14:06:16 Viviversum2 NetworkManager[403]: <info> [1635771976.0886] device (wlp3s0): supplicant interface state: scanning -> disconnected
Nov 01 14:06:19 Viviversum2 NetworkManager[403]: <info> [1635771979.9498] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 14:08:27 Viviversum2 NetworkManager[403]: <info> [1635772107.6358] device (enp2s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 14:08:27 Viviversum2 NetworkManager[403]: <info> [1635772107.8602] device (wlp3s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 14:08:27 Viviversum2 NetworkManager[403]: <info> [1635772107.8619] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (unmanage)
Nov 01 14:08:32 Viviversum2 NetworkManager[403]: <info> [1635772112.6818] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 14:08:32 Viviversum2 NetworkManager[403]: <info> [1635772112.8904] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 14:08:32 Viviversum2 NetworkManager[403]: <info> [1635772112.8923] manager: NetworkManager state is now DISCONNECTED
Nov 01 14:08:33 Viviversum2 NetworkManager[403]: <info> [1635772113.0009] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 14:08:33 Viviversum2 NetworkManager[403]: <info> [1635772113.0010] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 14:08:34 Viviversum2 NetworkManager[403]: <info> [1635772114.3862] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Nov 01 14:08:34 Viviversum2 NetworkManager[403]: <info> [1635772114.3889] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:34 Viviversum2 NetworkManager[403]: <info> [1635772114.3899] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:34 Viviversum2 NetworkManager[403]: <info> [1635772114.3913] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1082] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1084] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1091] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1098] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1098] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1101] sup-iface[51039eadb8252d8f,1,wlp3s0]: wps: type pbc start...
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1130] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1138] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.1143] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.3383] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.6439] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:08:37 Viviversum2 NetworkManager[403]: <info> [1635772117.6880] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:08:38 Viviversum2 NetworkManager[403]: <info> [1635772118.0545] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:08:38 Viviversum2 NetworkManager[403]: <info> [1635772118.3734] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:08:42 Viviversum2 NetworkManager[403]: <info> [1635772122.5303] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:08:42 Viviversum2 NetworkManager[403]: <info> [1635772122.5443] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:08:42 Viviversum2 NetworkManager[403]: <info> [1635772122.9040] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:08:43 Viviversum2 NetworkManager[403]: <info> [1635772123.6232] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:08:45 Viviversum2 NetworkManager[403]: <info> [1635772125.5631] device (wlp3s0): state change: config -> unavailable (reason 'none', sys-iface-state: 'managed')
Nov 01 14:08:45 Viviversum2 NetworkManager[403]: <info> [1635772125.5647] device (wlp3s0): set-hw-addr: set MAC address to BA:CB:E7:96:AA:B6 (scanning)
Nov 01 14:09:08 Viviversum2 NetworkManager[403]: <info> [1635772148.5413] dhcp4 (enp2s0): state changed unknown -> bound, address=192.168.1.207
Nov 01 14:09:08 Viviversum2 NetworkManager[403]: <info> [1635772148.5434] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:08 Viviversum2 NetworkManager[403]: <info> [1635772148.5576] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:08 Viviversum2 NetworkManager[403]: <info> [1635772148.5578] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:19 Viviversum2 NetworkManager[403]: <info> [1635772159.6019] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Nov 01 14:09:19 Viviversum2 NetworkManager[403]: <info> [1635772159.6021] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.6981] device (wlp3s0): Activation: starting connection 'Viviversum_Netz' (b3624c68-cdd5-4aac-bf2c-df7fd6bacf37)
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.6984] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.7005] device (wlp3s0): set-hw-addr: reset MAC address to CC:6B:1E:18:3B:87 (preserve)
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9372] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9377] device (wlp3s0): Activation: (wifi) access point 'Viviversum_Netz' has security, but secrets are required.
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9378] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9382] sup-iface[cbabf206d2dcfa6e,2,wlp3s0]: wps: type pbc start...
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9413] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9428] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9434] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9439] device (wlp3s0): Activation: (wifi) connection 'Viviversum_Netz' has security, and secrets exist. No new secrets needed.
Nov 01 14:09:23 Viviversum2 NetworkManager[403]: <info> [1635772163.9705] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:09:24 Viviversum2 NetworkManager[403]: <info> [1635772164.2020] device (wlp3s0): supplicant interface state: inactive -> scanning
Nov 01 14:09:28 Viviversum2 NetworkManager[403]: <info> [1635772168.3569] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:09:28 Viviversum2 NetworkManager[403]: <info> [1635772168.3674] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:09:28 Viviversum2 NetworkManager[403]: <info> [1635772168.7163] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:09:29 Viviversum2 NetworkManager[403]: <info> [1635772169.0331] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:09:33 Viviversum2 NetworkManager[403]: <info> [1635772173.1899] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:09:33 Viviversum2 NetworkManager[403]: <info> [1635772173.1995] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:09:33 Viviversum2 NetworkManager[403]: <info> [1635772173.5494] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:09:34 Viviversum2 NetworkManager[403]: <info> [1635772174.2700] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:09:38 Viviversum2 NetworkManager[403]: <info> [1635772178.4437] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:09:38 Viviversum2 NetworkManager[403]: <info> [1635772178.4627] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:09:38 Viviversum2 NetworkManager[403]: <info> [1635772178.8195] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:09:40 Viviversum2 NetworkManager[403]: <info> [1635772180.0399] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:09:44 Viviversum2 NetworkManager[403]: <info> [1635772184.2072] device (wlp3s0): supplicant interface state: scanning -> authenticating
Nov 01 14:09:44 Viviversum2 NetworkManager[403]: <info> [1635772184.2176] device (wlp3s0): supplicant interface state: authenticating -> associating
Nov 01 14:09:44 Viviversum2 NetworkManager[403]: <info> [1635772184.5764] device (wlp3s0): supplicant interface state: associating -> disconnected
Nov 01 14:09:49 Viviversum2 NetworkManager[403]: <warn> [1635772189.1571] device (wlp3s0): Activation: (wifi) association took too long
Nov 01 14:09:49 Viviversum2 NetworkManager[403]: <info> [1635772189.1572] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:49 Viviversum2 NetworkManager[403]: <info> [1635772189.1575] sup-iface[cbabf206d2dcfa6e,2,wlp3s0]: wps: type pbc start...
Nov 01 14:09:49 Viviversum2 NetworkManager[403]: <warn> [1635772189.1579] device (wlp3s0): Activation: (wifi) asking for new secrets
Nov 01 14:09:49 Viviversum2 NetworkManager[403]: <info> [1635772189.3837] device (wlp3s0): supplicant interface state: disconnected -> scanning
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <warn> [1635772191.6824] device (wlp3s0): no secrets: User canceled the secrets request.
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <info> [1635772191.6824] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <info> [1635772191.6854] device (wlp3s0): set-hw-addr: set MAC address to A2:52:3B:8E:11:04 (scanning)
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <warn> [1635772191.9275] device (wlp3s0): Activation: failed for connection 'Viviversum_Netz'
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <info> [1635772191.9295] device (wlp3s0): supplicant interface state: scanning -> interface_disabled
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <info> [1635772191.9298] device (wlp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 14:09:51 Viviversum2 NetworkManager[403]: <info> [1635772191.9974] device (wlp3s0): supplicant interface state: interface_disabled -> scanning
Nov 01 14:09:56 Viviversum2 NetworkManager[403]: <info> [1635772196.3120] device (wlp3s0): supplicant interface state: scanning -> disconnected
Nov 01 14:10:00 Viviversum2 NetworkManager[403]: <info> [1635772200.1767] device (wlp3s0): supplicant interface state: disconnected -> inactive
Nov 01 14:16:51 Viviversum2 NetworkManager[403]: <info> [1635772611.1674] device (wlp3s0): set-hw-addr: set MAC address to DA:21:80:9A:49:EC (scanning)
Nov 01 14:16:51 Viviversum2 NetworkManager[403]: <info> [1635772611.4071] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:16:51 Viviversum2 NetworkManager[403]: <info> [1635772611.4506] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:23:47 Viviversum2 NetworkManager[403]: <info> [1635773027.1616] device (wlp3s0): set-hw-addr: set MAC address to 06:39:27:5B:BF:C1 (scanning)
Nov 01 14:23:47 Viviversum2 NetworkManager[403]: <info> [1635773027.3991] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:23:47 Viviversum2 NetworkManager[403]: <info> [1635773027.4582] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:30:42 Viviversum2 NetworkManager[403]: <info> [1635773442.2504] device (wlp3s0): set-hw-addr: set MAC address to 2A:7E:F3:49:C2:3D (scanning)
Nov 01 14:30:42 Viviversum2 NetworkManager[403]: <info> [1635773442.4882] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:30:42 Viviversum2 NetworkManager[403]: <info> [1635773442.5572] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:37:36 Viviversum2 NetworkManager[403]: <info> [1635773856.1923] device (wlp3s0): set-hw-addr: set MAC address to 42:EF:54:15:29:9F (scanning)
Nov 01 14:37:36 Viviversum2 NetworkManager[403]: <info> [1635773856.4319] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:37:36 Viviversum2 NetworkManager[403]: <info> [1635773856.4505] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:44:30 Viviversum2 NetworkManager[403]: <info> [1635774270.1787] device (wlp3s0): set-hw-addr: set MAC address to D6:06:AD:07:E0:51 (scanning)
Nov 01 14:44:30 Viviversum2 NetworkManager[403]: <info> [1635774270.4162] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:44:30 Viviversum2 NetworkManager[403]: <info> [1635774270.4844] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:51:26 Viviversum2 NetworkManager[403]: <info> [1635774686.1837] device (wlp3s0): set-hw-addr: set MAC address to A6:19:60:40:D3:6C (scanning)
Nov 01 14:51:26 Viviversum2 NetworkManager[403]: <info> [1635774686.4260] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:51:26 Viviversum2 NetworkManager[403]: <info> [1635774686.4857] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 14:58:22 Viviversum2 NetworkManager[403]: <info> [1635775102.1577] device (wlp3s0): set-hw-addr: set MAC address to 2E:20:EB:26:96:B1 (scanning)
Nov 01 14:58:22 Viviversum2 NetworkManager[403]: <info> [1635775102.3997] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 14:58:22 Viviversum2 NetworkManager[403]: <info> [1635775102.4580] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 15:05:14 Viviversum2 NetworkManager[403]: <info> [1635775514.2099] device (wlp3s0): set-hw-addr: set MAC address to 1A:AD:5B:2F:2E:9C (scanning)
Nov 01 15:05:14 Viviversum2 NetworkManager[403]: <info> [1635775514.4509] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 15:05:14 Viviversum2 NetworkManager[403]: <info> [1635775514.5037] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
Nov 01 15:12:03 Viviversum2 NetworkManager[403]: <info> [1635775923.1966] device (wlp3s0): set-hw-addr: set MAC address to 2E:BD:54:8F:19:3A (scanning)
Nov 01 15:12:03 Viviversum2 NetworkManager[403]: <info> [1635775923.4363] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
Nov 01 15:12:03 Viviversum2 NetworkManager[403]: <info> [1635775923.4902] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
