Hello,
I’m having trouble with my HDMI projector.
- If I plug it directly on my laptop (Lenovo P14s gen2) : the image is just a mush of grey pixels
- If I plug it via an USB-C hub, the image is fine
- Using a Windows laptop, the image is fine
Of course, I’d like to plug it directly.
What could be the cause of this?
Here is the output of xrandr:
Directly:
HDMI-1 connected 1920x1080+3200+0 (normal left inverted right x axis y axis) 1600mm x 900mm
3840x2160 30.00 + 25.00 24.00 29.97 23.98
4096x2160 24.00 23.98
1920x1080 60.00* 50.00 59.94 30.00 24.00 29.97 23.98
1920x1080i 60.00 50.00 59.94
1280x720 60.00 50.00 59.94
1440x576 50.00
1440x480 60.00 59.94
720x576 50.00
720x576i 50.00
720x480 60.00 59.94
720x480i 60.00 59.94
640x480 60.00 59.94
via USB-C hub:
DP-3 connected 1920x1080+3200+0 (normal left inverted right x axis y axis) 1600mm x 900mm
4096x2160 30.00 24.00 29.97 23.98
1440x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
Thank you very much.
