Lenovo Legion 5 not waking up after sleep
Hi, my laptop is not waking up after sleep.
The cursor is visible.
If I try ctrl+f2, only the lenovo logo comes up.
End of journalctl -b -2
jún 02 09:31:08 el3-manjaro kded5[924]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
jún 02 09:31:08 el3-manjaro dbus-daemon[706]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-di>
jún 02 09:31:08 el3-manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
jún 02 09:31:08 el3-manjaro dbus-daemon[706]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
jún 02 09:31:08 el3-manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
jún 02 09:31:08 el3-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/>
jún 02 09:31:08 el3-manjaro kernel: audit: type=1130 audit(1685698268.306:100): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatch>
jún 02 09:31:08 el3-manjaro kernel: wlp0s20f3: deauthenticating from 9c:c9:eb:4d:b0:e7 by local choice (Reason: 3=DEAUTH_LEAVING)
jún 02 09:31:08 el3-manjaro kwin_x11[925]: kwin_core: XCB error: 152 (BadDamage), sequence: 25900, resource id: 16779311, major code: 143 (DAMAGE), minor co>
jún 02 09:31:08 el3-manjaro kscreenlocker_greet[1798]: Qt: Session management error: networkIdsList argument is NULL
jún 02 09:31:08 el3-manjaro wpa_supplicant[786]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=9c:c9:eb:4d:b0:e7 reason=3 locally_generated=1
jún 02 09:31:08 el3-manjaro wpa_supplicant[786]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.4652] device (wlp0s20f3): supplicant interface state: completed -> disconnected
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.4653] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping'>
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.4948] dhcp4 (wlp0s20f3): canceled DHCP transaction
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.4948] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.4948] dhcp4 (wlp0s20f3): state changed no lease
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.5263] device (wlp0s20f3): set-hw-addr: set MAC address to F6:E5:13:F1:4C:C8 (scanning)
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.5454] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', s>
jún 02 09:31:08 el3-manjaro NetworkManager[719]: <info>  [1685698268.6827] device (wlp0s20f3): set-hw-addr: reset MAC address to 7C:B5:66:44:CA:0F (unmanage)
jún 02 09:31:08 el3-manjaro wpa_supplicant[786]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
jún 02 09:31:08 el3-manjaro wpa_supplicant[786]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
jún 02 09:31:08 el3-manjaro wpa_supplicant[786]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
jún 02 09:31:08 el3-manjaro kscreenlocker_greet[1798]: kf.kirigami: Failed to find a Kirigami platform plugin
jún 02 09:31:09 el3-manjaro systemd[1]: Reached target Sleep.
jún 02 09:31:09 el3-manjaro dbus-daemon[706]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service>
jún 02 09:31:09 el3-manjaro systemd[1]: Starting System Suspend...
jún 02 09:31:09 el3-manjaro dbus-daemon[706]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedeskto>
jún 02 09:31:09 el3-manjaro kscreenlocker_greet[1798]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service n>
jún 02 09:31:09 el3-manjaro systemd-sleep[1823]: Entering sleep state 'suspend'...
jún 02 09:31:09 el3-manjaro kernel: PM: suspend entry (deep)
jún 02 09:31:09 el3-manjaro kernel: Filesystems sync: 0.005 seconds
And
    ~  inxi -Fazy         ✔  38s 
  Kernel: 6.1.31-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=5d63e99b-2c5a-4d21-b0a9-eab0653576f0 rw quiet splash
    resume=UUID=a5e44d12-d073-4f3b-a308-2918822f24ed udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 82RB v: Legion 5 15IAH7H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 15IAH7H
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> UEFI: LENOVO v: J2CN40WW date: 04/15/2022
  ID-1: BAT0 charge: 80.6 Wh (96.1%) condition: 83.9/80.0 Wh (104.9%)
    volts: 17.3 min: 15.4 model: SMP L21M4PC2 type: Li-poly serial: <filter>
    status: full cycles: 5
  Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x429
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 2485 high: 2700 min/max: 400/4600:4700:3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2700 2: 2700 3: 2700
    4: 2700 5: 501 6: 2700 7: 610 8: 2700 9: 2700 10: 2700 11: 2700 12: 2700
    13: 2700 14: 2700 15: 2700 16: 2700 17: 2700 18: 2700 19: 2700 20: 2700
    bogomips: 107560
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2560 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
    s-diag: 391mm (15.39")
  Monitor-1: DP-4 res: 1920x1080 hz: 144 dpi: 142
    size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 3060
    Laptop GPU/PCIe/SSE2 direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  API: ALSA v: k6.1.31-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 31:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp49s0 state: down mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033 class-ID: e001
  Local Storage: total: 476.94 GiB used: 69.88 GiB (14.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZAL4512HBLU-00BL2
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 7L1QHXC7 temp: 26.9 C
    scheme: GPT
  ID-1: / raw-size: 459.68 GiB size: 451.4 GiB (98.20%) used: 69.87 GiB (15.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 4.4 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 36 C
  Processes: 365 Uptime: 34m wakeups: 1 Memory: available: 15.42 GiB
  used: 2.98 GiB (19.4%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1156 libs: 336 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
Probably that issue: https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Suspend/hibernate_does_not_work,_or_does_not_work_consistently ?
