Hello,
after every start from Manjaro KDE my bluetooth is inactive. I could change it easy.
How can i change it to active after every boot.
thank you and best regards from Hamburg
psyc
sudo rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
// – edit
After several distributions I ended up back at Manjaro KDE and the problem with Bluetooth.
Here is a solid solution.
Issues & Assistance
KDE
System: Kernel: 6.3.6-273-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 parameters: intel_pstate=passive split_lock_detect=off intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-linux-tkg-bmq-generic_v3 ...
Reading time: 4 mins 🕑
Likes: 10 ❤
Maybe systemctl enable --now bluetooth.service
Hello mithrial,
the service was enabled and online after every reboot.
Due to another problem, I had briefly installed another distro and then reinstalled Manjaro KDE.
The problem has not reappeared.
Everything works like a charm.
Thanks for your help, I’ll close this question.
best regards
system
Closed
14 September 2023 10:50
4
