Hello, I scored the very nice Lenovo E14 for dirt cheap I straight away install Manjaro and apparently the F1 to F9 keys wont work on this laptop with Linux. It’s a Lenovo issue and they do not want to do a thing about it! So after a lot of research I found maybe a solution… First solution is to put your system to sleep… Yeah no kidding if you put your laptop to sleep and woke it up all the keys function will work without any issue and you will even be able to close the lid and make it go to sleep…
But some legends apparently may have fix this issue on GitHub:
I guess the solution for Manjaro would be the Arch solution but I’m having issue to install it as I m fairly new to Linux here is the instruction that I need help with:
Arch
Make sure you have acpica installed (
pacman -S acpica
) and runthinkpad-e15-gen2-firmware-fix_arch.sh
instead. Tested with kernel5.12.10-arch1-1
. Normally the^M
aren’t present in this script, but if you get an error related to this then see above. NOTE: The script uses#!/usr/bin/bash
as a crunchbang since it’s the common Arch location for bash. You have to change it if you use another interpreter/it is located elsewhere!
I was able to install acpica and cd downloads git clone the folders but how do I run the thinkpad-e15-gen2-firmware-fix_arch.sh
Thanks you hopefully this may fix the horrible issues of the thinkpad E14!
