Hi i’m using Manjaro xfce.
I updated my system today (sudo pacman -Syyuu). After this update my Laptop screen always freeze when i plugin HDMI Cable.
I thought the fault can be the kernel, so i activate grub menu in /etc/default/grub → reboot the system and started in old LTS Kernel. After this it always start in cut off screen. I tried Kernel 5.10.63-1 (problem with HDMI), 5.4.144-1 and 5.12.19-1. On all Kernel the issue is the same.
Link to Picture: https:// www.dropbox .com/s/hzyhkd450c9wd8a/IMG-3136.jpg?dl=0
The double u makes it downgrade packages as well. You should have used sudo pacman -Syyu
instead.
Try this to see if it fixes anything
sudo pacman-mirrors -f 5
sudo pacman -Syyu
Also, you can also check the Display GUI to see if there’s anything there. I don’t use XFCE so I don’t know what that looks like personally.
there is nothing to do
Thanks for the quick answer, but it doesnt help.
I checked Display Settings, but i cant change here anything. Every content is the only one available.
I checked also all other GUI Settings with GUI. Sadly i cant found anything false.
PS: after problems with startup, i installed Manjaro KDE.
Thread can be closed.
