I decided to experiment with Hyprland. I installed it with yay
, made sure all my other system components were up to date, and rebooted. When I select Hyprland from ldm, after entering my password and press enter, I get a black screen with a white cursor in the top left. After about 10 seconds, ldm re-appears. It’s worth mentioning that swayfx
has the exact same issue. Although I am able to log into Wayland-based compositor Gnome / mutter as I write this forum thread.
When I search Google for ‘manjaro wayland won’t start’ (and similar), a lot of Wayland KDE Plasma issues turn up. Seems Plasma is more popular with Manjaro users.
What other information could I provide to help troubleshoot?
$ inxi -Fazy
Kernel: 6.6.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=d8f51c21-a5ce-4611-973c-b7d694ae22a1 rw apparmor=1
security=apparmor resume=UUID=6a544b3a-7b7d-4fc0-b121-0f55042fc081
udev.log_priority=3 video=vesafb:mode=3840x1600-32,mtrr:3,ywrap
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: LightDM
v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Mobo: ASUSTeK model: PRIME H670-PLUS D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2014
date: 10/14/2022
Info: model: 13th Gen Intel Core i5-13600K bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x11D
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 920 high: 1108 min/max: 800/5100:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1100
4: 800 5: 800 6: 1108 7: 1100 8: 800 9: 1100 10: 800 11: 1100 12: 1100
13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
bogomips: 139820
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:12
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: LG (GoldStar) HDR WQHD serial: <filter> built: 2018
res: 3840x1600 dpi: 111 gamma: 1.2 size: 879x366mm (34.61x14.41")
diag: 952mm (37.5") modes: max: 3840x1600 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 XT (navi23 LLVM
16.0.6 DRM 3.54 6.6.1-1-MANJARO) device-ID: 1002:73ff memory: 7.81 GiB
unified: no display-ID: :0.0
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.1-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.85 status: off with: pipewire-media-session
status: active tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.2.4:9 chip-ID: 0b05:190e
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 6.6 TiB used: 1.2 TiB (18.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
SN850X HS 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620311WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS200T2B0A-00SM50
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 20WD scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: M4-CT256M4SSD2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 000F scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 743.72 GiB size: 730.97 GiB (98.29%) used: 60.15 GiB (8.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.14 TiB (63.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: partition size: 187.5 GiB used: 0 KiB (0.0%)
priority: -3 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
mem: 30.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 469 Uptime: 15m wakeups: 0 Memory: total: 64 GiB
available: 62.55 GiB used: 9.07 GiB (14.5%) Init: systemd v: 254
Packages: 1901 pm: pacman pkgs: 1889 libs: 401
tools: gnome-software,pamac,yay pm: flatpak pkgs: 12 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.31
$ inxi -GSa
Host: <hostname> Kernel: 6.6.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: acpi_pm
class-ID: 0300
chip-ID: 046d:085c class-ID: 0102 serial: EB8FAF8F
Monitor-1: DP-3 model: LG (GoldStar) HDR WQHD serial: 520115 built: 2018
dmesg:
[ 0.000000] microcode: updated early: 0x10e -> 0x11d, date = 2023-08-29
[ 0.000000] Linux version 6.6.1-1-MANJARO (builduser@fv-az447-329) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Thu Nov 9 04:27:49 UTC 2023
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=d8f51c21-a5ce-4611-973c-b7d694ae22a1 rw apparmor=1 security=apparmor resume=UUID=6a544b3a-7b7d-4fc0-b121-0f55042fc081 udev.log_priority=3 video=vesafb:mode=3840x1600-32,mtrr:3,ywrap
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000063e4dfff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000063e4e000-0x0000000063e4efff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000063e4f000-0x0000000063e9bfff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000063e9c000-0x0000000063e9cfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000063e9d000-0x0000000070508fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000070509000-0x0000000074208fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000074209000-0x000000007451efff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007451f000-0x000000007471efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007471f000-0x0000000075f1efff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000075f1f000-0x0000000075ffefff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000075fff000-0x0000000075ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000076000000-0x0000000079ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a400000-0x000000007a7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007b000000-0x00000000807fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000107f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] efi: EFI v2.8 by American Megatrends
[ 0.000000] efi: ACPI=0x7451e000 ACPI 2.0=0x7451e014 TPMFinalLog=0x7464c000 SMBIOS=0x75d1d000 SMBIOS 3.0=0x75d1c000 MEMATTR=0x6bf8a018 ESRT=0x6dc78918
[ 0.000000] efi: Remove mem93: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xc0000000-0xcfffffff] reserved
[ 0.000000] efi: Not removing mem94: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[ 0.000000] efi: Not removing mem95: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem96: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem98: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem99: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[ 0.000000] SMBIOS 3.4.0 present.
[ 0.000000] DMI: ASUS System Product Name/PRIME H670-PLUS D4, BIOS 2014 10/14/2022
[ 0.000000] tsc: Detected 3500.000 MHz processor
[ 0.000000] tsc: Detected 3494.400 MHz TSC
[ 0.000657] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000659] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000664] last_pfn = 0x107f800 max_arch_pfn = 0x400000000
[ 0.000667] total RAM covered: 128960M
[ 0.000724] Found optimal setting for mtrr clean up
[ 0.000724] gran_size: 64K chunk_size: 128M num_reg: 7 lose cover RAM: 0G
[ 0.000726] MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
[ 0.000727] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001094] e820: update [mem 0x7c000000-0xffffffff] usable ==> reserved
[ 0.001096] last_pfn = 0x76000 max_arch_pfn = 0x400000000
[ 0.004658] esrt: Reserving ESRT space from 0x000000006dc78918 to 0x000000006dc789f0.
[ 0.004662] e820: update [mem 0x6dc78000-0x6dc78fff] usable ==> reserved
[ 0.004673] Using GB pages for direct mapping
[ 0.004674] Incomplete global flushes, disabling PCID
[ 0.004967] Secure boot disabled
[ 0.004967] RAMDISK: [mem 0x353ff000-0x369f6fff]
[ 0.004970] ACPI: Early table checksum verification disabled
[ 0.004972] ACPI: RSDP 0x000000007451E014 000024 (v02 ALASKA)
[ 0.004975] ACPI: XSDT 0x000000007451D728 00011C (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004978] ACPI: FACP 0x000000007451B000 000114 (v06 ALASKA A M I 01072009 AMI 01000013)
[ 0.004981] ACPI: DSDT 0x00000000744A2000 07842B (v02 ALASKA A M I 01072009 INTL 20200717)
[ 0.004983] ACPI: FACS 0x000000007471E000 000040
[ 0.004984] ACPI: MCFG 0x000000007451C000 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.004986] ACPI: FIDT 0x00000000744A1000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004987] ACPI: SSDT 0x000000007449F000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[ 0.004989] ACPI: SSDT 0x0000000074499000 005D2C (v02 CpuRef CpuSsdt 00003000 INTL 20200717)
[ 0.004991] ACPI: SSDT 0x0000000074496000 002AA1 (v02 SaSsdt SaSsdt 00003000 INTL 20200717)
[ 0.004992] ACPI: SSDT 0x0000000074492000 003339 (v02 INTEL IgfxSsdt 00003000 INTL 20200717)
[ 0.004994] ACPI: HPET 0x0000000074491000 000038 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004995] ACPI: APIC 0x0000000074490000 0001DC (v05 ALASKA A M I 01072009 AMI 01000013)
[ 0.004997] ACPI: MCFG 0x000000007448F000 00003C (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004998] ACPI: SSDT 0x000000007448D000 001F1A (v02 ALASKA Ther_Rvp 00001000 INTL 20200717)
[ 0.005000] ACPI: NHLT 0x000000007448B000 00002D (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.005001] ACPI: LPIT 0x000000007448A000 0000CC (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.005003] ACPI: SSDT 0x0000000074486000 002357 (v02 ALASKA TbtTypeC 00000000 INTL 20200717)
[ 0.005004] ACPI: SSDT 0x0000000074483000 002A83 (v02 ALASKA PtidDevc 00001000 INTL 20200717)
[ 0.005006] ACPI: DBGP 0x0000000074482000 000034 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.005007] ACPI: DBG2 0x0000000074481000 000054 (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.005009] ACPI: SSDT 0x0000000074480000 000C1F (v02 ALASKA UsbCTabl 00001000 INTL 20200717)
[ 0.005010] ACPI: DMAR 0x000000007447F000 000050 (v02 INTEL EDK2 00000002 01000013)
[ 0.005012] ACPI: SSDT 0x000000007447D000 001DA0 (v02 INTEL xh_adls3 00000000 INTL 20200717)
[ 0.005013] ACPI: SSDT 0x0000000074479000 003AEA (v02 SocGpe SocGpe 00003000 INTL 20200717)
[ 0.005015] ACPI: SSDT 0x0000000074475000 0039DA (v02 SocCmn SocCmn 00003000 INTL 20200717)
[ 0.005017] ACPI: SSDT 0x0000000074474000 000144 (v02 Intel ADebTabl 00001000 INTL 20200717)
[ 0.005018] ACPI: VFCT 0x0000000074469000 00AC84 (v01 ALASKA A M I 00000001 AMD 31504F47)
[ 0.005020] ACPI: UEFI 0x000000007458E000 00063A (v01 INTEL RstVmdE 00000000 INTL 00000000)
[ 0.005021] ACPI: UEFI 0x000000007458D000 00005C (v01 INTEL RstVmdV 00000000 INTL 00000000)
[ 0.005023] ACPI: WPBT 0x000000007438A000 000040 (v01 ALASKA A M I 00000001 ASUS 00000001)
[ 0.005024] ACPI: TPM2 0x0000000074389000 00004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.005026] ACPI: PHAT 0x0000000074388000 000611 (v01 ALASKA A M I 00000005 MSFT 0100000D)
[ 0.005027] ACPI: WSMT 0x0000000074489000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.005029] ACPI: FPDT 0x0000000074387000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.005030] ACPI: Reserving FACP table memory at [mem 0x7451b000-0x7451b113]
[ 0.005031] ACPI: Reserving DSDT table memory at [mem 0x744a2000-0x7451a42a]
[ 0.005032] ACPI: Reserving FACS table memory at [mem 0x7471e000-0x7471e03f]
[ 0.005032] ACPI: Reserving MCFG table memory at [mem 0x7451c000-0x7451c03b]
[ 0.005032] ACPI: Reserving FIDT table memory at [mem 0x744a1000-0x744a109b]
[ 0.005033] ACPI: Reserving SSDT table memory at [mem 0x7449f000-0x7449f38b]
[ 0.005033] ACPI: Reserving SSDT table memory at [mem 0x74499000-0x7449ed2b]
[ 0.005034] ACPI: Reserving SSDT table memory at [mem 0x74496000-0x74498aa0]
[ 0.005034] ACPI: Reserving SSDT table memory at [mem 0x74492000-0x74495338]
[ 0.005034] ACPI: Reserving HPET table memory at [mem 0x74491000-0x74491037]
[ 0.005035] ACPI: Reserving APIC table memory at [mem 0x74490000-0x744901db]
[ 0.005035] ACPI: Reserving MCFG table memory at [mem 0x7448f000-0x7448f03b]
[ 0.005036] ACPI: Reserving SSDT table memory at [mem 0x7448d000-0x7448ef19]
[ 0.005036] ACPI: Reserving NHLT table memory at [mem 0x7448b000-0x7448b02c]
[ 0.005036] ACPI: Reserving LPIT table memory at [mem 0x7448a000-0x7448a0cb]
[ 0.005037] ACPI: Reserving SSDT table memory at [mem 0x74486000-0x74488356]
[ 0.005037] ACPI: Reserving SSDT table memory at [mem 0x74483000-0x74485a82]
[ 0.005038] ACPI: Reserving DBGP table memory at [mem 0x74482000-0x74482033]
[ 0.005038] ACPI: Reserving DBG2 table memory at [mem 0x74481000-0x74481053]
[ 0.005038] ACPI: Reserving SSDT table memory at [mem 0x74480000-0x74480c1e]
[ 0.005039] ACPI: Reserving DMAR table memory at [mem 0x7447f000-0x7447f04f]
[ 0.005039] ACPI: Reserving SSDT table memory at [mem 0x7447d000-0x7447ed9f]
[ 0.005040] ACPI: Reserving SSDT table memory at [mem 0x74479000-0x7447cae9]
[ 0.005040] ACPI: Reserving SSDT table memory at [mem 0x74475000-0x744789d9]
[ 0.005040] ACPI: Reserving SSDT table memory at [mem 0x74474000-0x74474143]
[ 0.005041] ACPI: Reserving VFCT table memory at [mem 0x74469000-0x74473c83]
[ 0.005041] ACPI: Reserving UEFI table memory at [mem 0x7458e000-0x7458e639]
[ 0.005042] ACPI: Reserving UEFI table memory at [mem 0x7458d000-0x7458d05b]
[ 0.005042] ACPI: Reserving WPBT table memory at [mem 0x7438a000-0x7438a03f]
[ 0.005043] ACPI: Reserving TPM2 table memory at [mem 0x74389000-0x7438904b]
[ 0.005043] ACPI: Reserving PHAT table memory at [mem 0x74388000-0x74388610]
[ 0.005043] ACPI: Reserving WSMT table memory at [mem 0x74489000-0x74489027]
[ 0.005044] ACPI: Reserving FPDT table memory at [mem 0x74387000-0x74387043]
[ 0.005203] No NUMA configuration found
[ 0.005204] Faking a node at [mem 0x0000000000000000-0x000000107f7fffff]
[ 0.005205] NODE_DATA(0) allocated [mem 0x107f7fb000-0x107f7fffff]
[ 0.005237] Zone ranges:
[ 0.005237] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.005238] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.005239] Normal [mem 0x0000000100000000-0x000000107f7fffff]
[ 0.005240] Device empty
[ 0.005240] Movable zone start for each node
[ 0.005241] Early memory node ranges
[ 0.005241] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.005242] node 0: [mem 0x000000000009f000-0x000000000009ffff]
[ 0.005242] node 0: [mem 0x0000000000100000-0x0000000063e4dfff]
[ 0.005243] node 0: [mem 0x0000000063e4f000-0x0000000063e9bfff]
[ 0.005243] node 0: [mem 0x0000000063e9d000-0x0000000070508fff]
[ 0.005243] node 0: [mem 0x0000000075fff000-0x0000000075ffffff]
[ 0.005244] node 0: [mem 0x0000000100000000-0x000000107f7fffff]
[ 0.005246] Initmem setup node 0 [mem 0x0000000000001000-0x000000107f7fffff]
[ 0.005248] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005249] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005261] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.006626] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.006949] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.007093] On node 0, zone DMA32: 23286 pages in unavailable ranges
[ 0.078668] On node 0, zone Normal: 8192 pages in unavailable ranges
[ 0.078680] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.079131] ACPI: PM-Timer IO Port: 0x1808
[ 0.079136] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.079137] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.079137] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.079138] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.079138] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.079138] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.079139] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.079139] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.079140] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.079140] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.079140] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.079141] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.079141] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.079141] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.079142] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.079142] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.079142] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[ 0.079143] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[ 0.079143] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[ 0.079143] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[ 0.079144] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[ 0.079144] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[ 0.079144] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[ 0.079145] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.079184] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.079186] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.079187] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.079189] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.079190] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.079191] TSC deadline timer available
[ 0.079192] smpboot: Allowing 20 CPUs, 0 hotplug CPUs
[ 0.079203] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.079204] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.079205] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.079205] PM: hibernation: Registered nosave memory: [mem 0x63e4e000-0x63e4efff]
[ 0.079206] PM: hibernation: Registered nosave memory: [mem 0x63e9c000-0x63e9cfff]
[ 0.079207] PM: hibernation: Registered nosave memory: [mem 0x6dc78000-0x6dc78fff]
[ 0.079208] PM: hibernation: Registered nosave memory: [mem 0x70509000-0x74208fff]
[ 0.079208] PM: hibernation: Registered nosave memory: [mem 0x74209000-0x7451efff]
[ 0.079208] PM: hibernation: Registered nosave memory: [mem 0x7451f000-0x7471efff]
[ 0.079209] PM: hibernation: Registered nosave memory: [mem 0x7471f000-0x75f1efff]
[ 0.079209] PM: hibernation: Registered nosave memory: [mem 0x75f1f000-0x75ffefff]
[ 0.079210] PM: hibernation: Registered nosave memory: [mem 0x76000000-0x79ffffff]
[ 0.079210] PM: hibernation: Registered nosave memory: [mem 0x7a000000-0x7a3fffff]
[ 0.079210] PM: hibernation: Registered nosave memory: [mem 0x7a400000-0x7a7fffff]
[ 0.079211] PM: hibernation: Registered nosave memory: [mem 0x7a800000-0x7affffff]
[ 0.079211] PM: hibernation: Registered nosave memory: [mem 0x7b000000-0x807fffff]
[ 0.079211] PM: hibernation: Registered nosave memory: [mem 0x80800000-0xfdffffff]
[ 0.079212] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.079212] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.079212] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.079212] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.079213] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.079213] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed1ffff]
[ 0.079213] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ 0.079214] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfedfffff]
[ 0.079214] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.079214] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[ 0.079215] [mem 0x80800000-0xfdffffff] available for PCI devices
[ 0.079216] Booting paravirtualized kernel on bare hardware
[ 0.079217] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.082263] setup_percpu: NR_CPUS:320 nr_cpumask_bits:20 nr_cpu_ids:20 nr_node_ids:1
[ 0.082793] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[ 0.082796] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[ 0.082798] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.082802] pcpu-alloc: [0] 16 17 18 19 -- -- -- --
[ 0.082811] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=d8f51c21-a5ce-4611-973c-b7d694ae22a1 rw apparmor=1 security=apparmor resume=UUID=6a544b3a-7b7d-4fc0-b121-0f55042fc081 udev.log_priority=3 video=vesafb:mode=3840x1600-32,mtrr:3,ywrap
[ 0.082852] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64", will be passed to user space.
[ 0.082865] random: crng init done
[ 0.082866] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.082866] printk: log_buf_len total cpu_extra contributions: 77824 bytes
[ 0.082866] printk: log_buf_len min size: 131072 bytes
[ 0.082959] printk: log_buf_len: 262144 bytes
[ 0.082960] printk: early log buf free: 113824(86%)
[ 0.087515] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.089803] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.089924] Fallback order for Node 0: 0
[ 0.089926] Built 1 zonelists, mobility grouping on. Total pages: 16449555
[ 0.089927] Policy zone: Normal
[ 0.090080] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.090086] software IO TLB: area num 32.
[ 0.184993] Memory: 65465140K/66843288K available (16384K kernel code, 2150K rwdata, 13140K rodata, 3420K init, 3792K bss, 1377888K reserved, 0K cma-reserved)
[ 0.185134] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=20, Nodes=1
[ 0.185151] ftrace: allocating 48975 entries in 192 pages
[ 0.188994] ftrace: allocated 192 pages with 2 groups
[ 0.189036] Dynamic Preempt: full
[ 0.189075] rcu: Preemptible hierarchical RCU implementation.
[ 0.189075] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=20.
[ 0.189076] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.189076] Trampoline variant of Tasks RCU enabled.
[ 0.189077] Rude variant of Tasks RCU enabled.
[ 0.189077] Tracing variant of Tasks RCU enabled.
[ 0.189077] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.189078] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=20
[ 0.190275] NR_IRQS: 20736, nr_irqs: 2216, preallocated irqs: 16
[ 0.190556] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.190791] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.190812] Console: colour dummy device 80x25
[ 0.190813] printk: console [tty0] enabled
[ 0.190838] ACPI: Core revision 20230628
[ 0.191028] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.191029] APIC: Switch to symmetric I/O mode setup
[ 0.191029] DMAR: Host address width 39
[ 0.191030] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.191034] DMAR: dmar0: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
[ 0.191036] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 0
[ 0.191037] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.191037] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.192443] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.192444] x2apic enabled
[ 0.192489] APIC: Switched APIC routing to: cluster x2apic
[ 0.196732] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x325ea749ca1, max_idle_ns: 440795373125 ns
[ 0.196737] Calibrating delay loop (skipped), value calculated using timer frequency.. 6991.00 BogoMIPS (lpj=11648000)
[ 0.196774] x86/tme: not enabled by BIOS
[ 0.196780] CPU0: Thermal monitoring enabled (TM1)
[ 0.196781] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.196888] process: using mwait in idle threads
[ 0.196889] CET detected: Indirect Branch Tracking enabled
[ 0.196890] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.196890] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.196892] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.196894] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.196894] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.196894] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.196895] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.196896] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.196902] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.196902] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.196903] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.196903] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.196904] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[ 0.196904] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.196905] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.196905] x86/fpu: xstate_offset[11]: 840, xstate_sizes[11]: 16
[ 0.196906] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
[ 0.200069] Freeing SMP alternatives memory: 40K
[ 0.200069] pid_max: default: 32768 minimum: 301
[ 0.200069] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor,integrity
[ 0.200069] landlock: Up and running.
[ 0.200069] Yama: becoming mindful.
[ 0.200069] LSM support for eBPF active
[ 0.200069] AppArmor: AppArmor initialized
[ 0.200069] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.200069] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.200069] smpboot: CPU0: 13th Gen Intel(R) Core(TM) i5-13600K (family: 0x6, model: 0xb7, stepping: 0x1)
[ 0.200069] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.200069] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.200069] RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.200069] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline, AnyThread deprecated, Alderlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.200069] core: cpu_core PMU driver:
[ 0.200069] ... version: 5
[ 0.200069] ... bit width: 48
[ 0.200069] ... generic registers: 8
[ 0.200069] ... value mask: 0000ffffffffffff
[ 0.200069] ... max period: 00007fffffffffff
[ 0.200069] ... fixed-purpose events: 4
[ 0.200069] ... event mask: 0001000f000000ff
[ 0.200069] signal: max sigframe size: 3632
[ 0.200069] Estimated ratio of average max frequency by base frequency (times 1024): 1492
[ 0.200069] rcu: Hierarchical SRCU implementation.
[ 0.200069] rcu: Max phase no-delay instances is 1000.
[ 0.200069] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.200069] smp: Bringing up secondary CPUs ...
[ 0.200069] smpboot: x86: Booting SMP configuration:
[ 0.200069] .... node #0, CPUs: #2 #4 #6 #8 #10 #12 #13 #14 #15 #16 #17 #18 #19
[ 0.009329] core: cpu_atom PMU driver: PEBS-via-PT
[ 0.009329] ... version: 5
[ 0.009329] ... bit width: 48
[ 0.009329] ... generic registers: 6
[ 0.009329] ... value mask: 0000ffffffffffff
[ 0.009329] ... max period: 00007fffffffffff
[ 0.009329] ... fixed-purpose events: 3
[ 0.009329] ... event mask: 000000070000003f
[ 0.206787] #1 #3 #5 #7 #9 #11
[ 0.211086] smp: Brought up 1 node, 20 CPUs
[ 0.211086] smpboot: Max logical packages: 1
[ 0.211086] smpboot: Total of 20 processors activated (139831.00 BogoMIPS)
[ 0.214486] devtmpfs: initialized
[ 0.214486] x86/mm: Memory block size: 2048MB
[ 0.214486] ACPI: PM: Registering ACPI NVS region [mem 0x7451f000-0x7471efff] (2097152 bytes)
[ 0.214486] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.214486] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.214486] pinctrl core: initialized pinctrl subsystem
[ 0.214486] PM: RTC time: 02:19:52, date: 2023-11-28
[ 0.214486] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.214486] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.214486] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.214603] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.214611] audit: initializing netlink subsys (disabled)
[ 0.214628] audit: type=2000 audit(1701137992.016:1): state=initialized audit_enabled=0 res=1
[ 0.214628] thermal_sys: Registered thermal governor 'fair_share'
[ 0.214628] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.214628] thermal_sys: Registered thermal governor 'step_wise'
[ 0.214628] thermal_sys: Registered thermal governor 'user_space'
[ 0.214628] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.214628] cpuidle: using governor ladder
[ 0.214628] cpuidle: using governor menu
[ 0.214630] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.214630] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.214630] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ 0.214630] PCI: not using MMCONFIG
[ 0.214630] PCI: Using configuration type 1 for base access
[ 0.214630] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.216787] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.216805] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.216806] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.216807] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.216807] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.217049] ACPI: Added _OSI(Module Device)
[ 0.217050] ACPI: Added _OSI(Processor Device)
[ 0.217050] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.217051] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.300666] ACPI: 13 ACPI AML tables successfully acquired and loaded
[ 0.310919] ACPI: Dynamic OEM Table Load:
[ 0.310926] ACPI: SSDT 0xFFFF949A014B6C00 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20200717)
[ 0.311764] ACPI: Dynamic OEM Table Load:
[ 0.311769] ACPI: SSDT 0xFFFF949A014A1800 0006AA (v02 PmRef Cpu0Ist 00003000 INTL 20200717)
[ 0.312643] ACPI: Dynamic OEM Table Load:
[ 0.312647] ACPI: SSDT 0xFFFF949A01F86800 0001AB (v02 PmRef Cpu0Psd 00003000 INTL 20200717)
[ 0.313432] ACPI: Dynamic OEM Table Load:
[ 0.313436] ACPI: SSDT 0xFFFF949A014A3800 0004BA (v02 PmRef Cpu0Hwp 00003000 INTL 20200717)
[ 0.314556] ACPI: Dynamic OEM Table Load:
[ 0.314564] ACPI: SSDT 0xFFFF949A01492000 001BAF (v02 PmRef ApIst 00003000 INTL 20200717)
[ 0.315957] ACPI: Dynamic OEM Table Load:
[ 0.315963] ACPI: SSDT 0xFFFF949A02C50000 001038 (v02 PmRef ApHwp 00003000 INTL 20200717)
[ 0.317173] ACPI: Dynamic OEM Table Load:
[ 0.317179] ACPI: SSDT 0xFFFF949A02C54000 001349 (v02 PmRef ApPsd 00003000 INTL 20200717)
[ 0.318447] ACPI: Dynamic OEM Table Load:
[ 0.318452] ACPI: SSDT 0xFFFF949A014AD000 000FBB (v02 PmRef ApCst 00003000 INTL 20200717)
[ 0.325952] ACPI: _OSC evaluated successfully for all CPUs
[ 0.326979] ACPI: Interpreter enabled
[ 0.327026] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.327027] ACPI: Using IOAPIC for interrupt routing
[ 0.328021] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ 0.329524] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved as ACPI motherboard resource
[ 0.329531] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.329532] PCI: Using E820 reservations for host bridge windows
[ 0.330680] ACPI: Enabled 6 GPEs in block 00 to 7F
[ 0.333461] ACPI: \_SB_.PC00.LPCB.UAR1.DRP1: New power resource
[ 0.348218] ACPI: \_SB_.PC00.XHCI.RHUB.HS14.PRBT: New power resource
[ 0.354370] ACPI: \_SB_.PC00.CNVW.WRST: New power resource
[ 0.362022] ACPI: \_TZ_.FN00: New power resource
[ 0.362067] ACPI: \_TZ_.FN01: New power resource
[ 0.362111] ACPI: \_TZ_.FN02: New power resource
[ 0.362154] ACPI: \_TZ_.FN03: New power resource
[ 0.362197] ACPI: \_TZ_.FN04: New power resource
[ 0.362622] ACPI: \PIN_: New power resource
[ 0.362928] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
[ 0.362932] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.366286] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.366287] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.367571] PCI host bridge to bus 0000:00
[ 0.367572] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.367574] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.367575] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.367576] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff window]
[ 0.367577] pci_bus 0000:00: root bus resource [mem 0x80800000-0xbfffffff window]
[ 0.367578] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.367579] pci_bus 0000:00: root bus resource [bus 00-e0]
[ 0.367607] pci 0000:00:00.0: [8086:a704] type 00 class 0x060000
[ 0.367692] pci 0000:00:01.0: [8086:a70d] type 01 class 0x060400
[ 0.367730] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.367743] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[ 0.368287] pci 0000:00:0a.0: [8086:a77d] type 00 class 0x118000
[ 0.368293] pci 0000:00:0a.0: reg 0x10: [mem 0x4212210000-0x4212217fff 64bit]
[ 0.368307] pci 0000:00:0a.0: enabling Extended Tags
[ 0.368402] pci 0000:00:0e.0: [8086:a77f] type 00 class 0x010400
[ 0.368414] pci 0000:00:0e.0: reg 0x10: [mem 0x4210000000-0x4211ffffff 64bit]
[ 0.368419] pci 0000:00:0e.0: reg 0x18: [mem 0x82000000-0x83ffffff]
[ 0.368432] pci 0000:00:0e.0: reg 0x20: [mem 0x4212100000-0x42121fffff 64bit]
[ 0.368653] pci 0000:00:14.0: [8086:7ae0] type 00 class 0x0c0330
[ 0.368669] pci 0000:00:14.0: reg 0x10: [mem 0x4212200000-0x421220ffff 64bit]
[ 0.368735] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.368966] pci 0000:00:14.2: [8086:7aa7] type 00 class 0x050000
[ 0.368984] pci 0000:00:14.2: reg 0x10: [mem 0x421221c000-0x421221ffff 64bit]
[ 0.368996] pci 0000:00:14.2: reg 0x18: [mem 0x4212224000-0x4212224fff 64bit]
[ 0.369195] pci 0000:00:15.0: [8086:7acc] type 00 class 0x0c8000
[ 0.369230] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.369659] pci 0000:00:15.2: [8086:7ace] type 00 class 0x0c8000
[ 0.369689] pci 0000:00:15.2: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.370032] pci 0000:00:16.0: [8086:7ae8] type 00 class 0x078000
[ 0.370053] pci 0000:00:16.0: reg 0x10: [mem 0x4212221000-0x4212221fff 64bit]
[ 0.370127] pci 0000:00:16.0: PME# supported from D3hot
[ 0.370596] pci 0000:00:17.0: [8086:7ae2] type 00 class 0x010601
[ 0.370608] pci 0000:00:17.0: reg 0x10: [mem 0x85900000-0x85901fff]
[ 0.370615] pci 0000:00:17.0: reg 0x14: [mem 0x85903000-0x859030ff]
[ 0.370622] pci 0000:00:17.0: reg 0x18: [io 0x7050-0x7057]
[ 0.370629] pci 0000:00:17.0: reg 0x1c: [io 0x7040-0x7043]
[ 0.370636] pci 0000:00:17.0: reg 0x20: [io 0x7020-0x703f]
[ 0.370642] pci 0000:00:17.0: reg 0x24: [mem 0x85902000-0x859027ff]
[ 0.370678] pci 0000:00:17.0: PME# supported from D3hot
[ 0.370953] pci 0000:00:1a.0: [8086:7ac8] type 01 class 0x060400
[ 0.371051] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.371598] pci 0000:00:1b.0: [8086:7ac0] type 01 class 0x060400
[ 0.371686] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.372227] pci 0000:00:1c.0: [8086:7ab8] type 01 class 0x060400
[ 0.372303] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.372819] pci 0000:00:1c.2: [8086:7aba] type 01 class 0x060400
[ 0.372910] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.372942] pci 0000:00:1c.2: PTM enabled (root), 4ns granularity
[ 0.373498] pci 0000:00:1d.0: [8086:7ab4] type 01 class 0x060400
[ 0.373597] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.373635] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.374204] pci 0000:00:1f.0: [8086:7a85] type 00 class 0x060100
[ 0.374508] pci 0000:00:1f.3: [8086:7ad0] type 00 class 0x040300
[ 0.374548] pci 0000:00:1f.3: reg 0x10: [mem 0x4212218000-0x421221bfff 64bit]
[ 0.374600] pci 0000:00:1f.3: reg 0x20: [mem 0x4212000000-0x42120fffff 64bit]
[ 0.374700] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.375185] pci 0000:00:1f.4: [8086:7aa3] type 00 class 0x0c0500
[ 0.375207] pci 0000:00:1f.4: reg 0x10: [mem 0x4212220000-0x42122200ff 64bit]
[ 0.375234] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.375449] pci 0000:00:1f.5: [8086:7aa4] type 00 class 0x0c8000
[ 0.375466] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.375600] pci 0000:01:00.0: [1002:1478] type 01 class 0x060400
[ 0.375610] pci 0000:01:00.0: reg 0x10: [mem 0x85600000-0x85603fff]
[ 0.375683] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.375934] pci 0000:00:01.0: PCI bridge to [bus 01-03]
[ 0.375936] pci 0000:00:01.0: bridge window [io 0x6000-0x6fff]
[ 0.375937] pci 0000:00:01.0: bridge window [mem 0x85400000-0x856fffff]
[ 0.375939] pci 0000:00:01.0: bridge window [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.375971] pci 0000:02:00.0: [1002:1479] type 01 class 0x060400
[ 0.376053] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.376155] pci 0000:01:00.0: PCI bridge to [bus 02-03]
[ 0.376159] pci 0000:01:00.0: bridge window [io 0x6000-0x6fff]
[ 0.376161] pci 0000:01:00.0: bridge window [mem 0x85400000-0x855fffff]
[ 0.376165] pci 0000:01:00.0: bridge window [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.376195] pci 0000:03:00.0: [1002:73ff] type 00 class 0x030000
[ 0.376207] pci 0000:03:00.0: reg 0x10: [mem 0x4000000000-0x41ffffffff 64bit pref]
[ 0.376216] pci 0000:03:00.0: reg 0x18: [mem 0x4200000000-0x420fffffff 64bit pref]
[ 0.376221] pci 0000:03:00.0: reg 0x20: [io 0x6000-0x60ff]
[ 0.376227] pci 0000:03:00.0: reg 0x24: [mem 0x85400000-0x854fffff]
[ 0.376232] pci 0000:03:00.0: reg 0x30: [mem 0x85500000-0x8551ffff pref]
[ 0.376250] pci 0000:03:00.0: BAR 0: assigned to efifb
[ 0.376297] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.376355] pci 0000:03:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.376408] pci 0000:03:00.1: [1002:ab28] type 00 class 0x040300
[ 0.376416] pci 0000:03:00.1: reg 0x10: [mem 0x85520000-0x85523fff]
[ 0.376481] pci 0000:03:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.376554] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.376558] pci 0000:02:00.0: bridge window [io 0x6000-0x6fff]
[ 0.376560] pci 0000:02:00.0: bridge window [mem 0x85400000-0x855fffff]
[ 0.376563] pci 0000:02:00.0: bridge window [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.376630] pci 0000:00:1a.0: PCI bridge to [bus 04]
[ 0.376643] pci 0000:00:1a.0: bridge window [io 0x5000-0x5fff]
[ 0.376650] pci 0000:00:1a.0: bridge window [mem 0x84a00000-0x853fffff]
[ 0.376698] pci 0000:00:1b.0: PCI bridge to [bus 05]
[ 0.376735] pci 0000:00:1c.0: PCI bridge to [bus 06]
[ 0.376738] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.376740] pci 0000:00:1c.0: bridge window [mem 0x84000000-0x849fffff]
[ 0.376806] pci 0000:07:00.0: [10ec:8125] type 00 class 0x020000
[ 0.376824] pci 0000:07:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.376847] pci 0000:07:00.0: reg 0x18: [mem 0x85800000-0x8580ffff 64bit]
[ 0.376862] pci 0000:07:00.0: reg 0x20: [mem 0x85810000-0x85813fff 64bit]
[ 0.376984] pci 0000:07:00.0: supports D1 D2
[ 0.376984] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.377218] pci 0000:00:1c.2: PCI bridge to [bus 07]
[ 0.377221] pci 0000:00:1c.2: bridge window [io 0x3000-0x3fff]
[ 0.377223] pci 0000:00:1c.2: bridge window [mem 0x85800000-0x858fffff]
[ 0.377274] pci 0000:08:00.0: [15b7:5030] type 00 class 0x010802
[ 0.377293] pci 0000:08:00.0: reg 0x10: [mem 0x85700000-0x85703fff 64bit]
[ 0.377568] pci 0000:00:1d.0: PCI bridge to [bus 08]
[ 0.377572] pci 0000:00:1d.0: bridge window [mem 0x85700000-0x857fffff]
[ 0.379046] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.379139] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.379231] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.379323] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.379414] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.379506] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.379597] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.379689] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.386986] iommu: Default domain type: Translated
[ 0.386986] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.386986] SCSI subsystem initialized
[ 0.386986] libata version 3.00 loaded.
[ 0.386986] ACPI: bus type USB registered
[ 0.386986] usbcore: registered new interface driver usbfs
[ 0.386986] usbcore: registered new interface driver hub
[ 0.386986] usbcore: registered new device driver usb
[ 0.386986] pps_core: LinuxPPS API ver. 1 registered
[ 0.386986] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.386986] PTP clock support registered
[ 0.386986] EDAC MC: Ver: 3.0.0
[ 0.386986] efivars: Registered efivars operations
[ 0.386986] NetLabel: Initializing
[ 0.386986] NetLabel: domain hash size = 128
[ 0.386986] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.386986] NetLabel: unlabeled traffic allowed by default
[ 0.386986] mctp: management component transport protocol core
[ 0.386986] NET: Registered PF_MCTP protocol family
[ 0.386986] PCI: Using ACPI for IRQ routing
[ 0.407052] PCI: pci_cache_line_size set to 64 bytes
[ 0.407149] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ 0.407245] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.407246] e820: reserve RAM buffer [mem 0x63e4e000-0x63ffffff]
[ 0.407247] e820: reserve RAM buffer [mem 0x63e9c000-0x63ffffff]
[ 0.407247] e820: reserve RAM buffer [mem 0x6dc78000-0x6fffffff]
[ 0.407248] e820: reserve RAM buffer [mem 0x70509000-0x73ffffff]
[ 0.407249] e820: reserve RAM buffer [mem 0x76000000-0x77ffffff]
[ 0.407249] e820: reserve RAM buffer [mem 0x107f800000-0x107fffffff]
[ 0.407272] pci 0000:03:00.0: vgaarb: setting as boot VGA device
[ 0.407272] pci 0000:03:00.0: vgaarb: bridge control possible
[ 0.407272] pci 0000:03:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.407272] vgaarb: loaded
[ 0.407895] clocksource: Switched to clocksource tsc-early
[ 0.408676] VFS: Disk quotas dquot_6.6.0
[ 0.408684] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.408755] AppArmor: AppArmor Filesystem Enabled
[ 0.408777] pnp: PnP ACPI init
[ 0.408957] system 00:00: [io 0x0290-0x029f] has been reserved
[ 0.409406] pnp 00:01: [dma 0 disabled]
[ 0.409499] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.409499] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.409499] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.409499] system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.409499] system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ 0.409499] system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ 0.409499] system 00:04: [mem 0xc0000000-0xcfffffff] has been reserved
[ 0.409499] system 00:04: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 0.409499] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.409499] system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.409499] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.410064] system 00:05: [io 0x2000-0x20fe] has been reserved
[ 0.410786] pnp: PnP ACPI: found 7 devices
[ 0.415929] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.415972] NET: Registered PF_INET protocol family
[ 0.416181] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.418280] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.418333] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.418722] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.419139] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.419203] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.419467] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 0.419632] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.419807] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.419890] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.419895] NET: Registered PF_XDP protocol family
[ 0.419899] pci 0000:00:1a.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
[ 0.419902] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 06] add_size 200000 add_align 100000
[ 0.419908] pci 0000:00:1a.0: BAR 15: assigned [mem 0x4212300000-0x42124fffff 64bit pref]
[ 0.419910] pci 0000:00:1c.0: BAR 15: assigned [mem 0x4212500000-0x42126fffff 64bit pref]
[ 0.419912] pci 0000:00:15.0: BAR 0: assigned [mem 0x4212222000-0x4212222fff 64bit]
[ 0.419967] pci 0000:00:15.2: BAR 0: assigned [mem 0x4212223000-0x4212223fff 64bit]
[ 0.419981] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[ 0.419982] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[ 0.419983] pci 0000:00:1f.5: BAR 0: assigned [mem 0x80800000-0x80800fff]
[ 0.419994] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.420000] pci 0000:02:00.0: bridge window [io 0x6000-0x6fff]
[ 0.420003] pci 0000:02:00.0: bridge window [mem 0x85400000-0x855fffff]
[ 0.420005] pci 0000:02:00.0: bridge window [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.420008] pci 0000:01:00.0: PCI bridge to [bus 02-03]
[ 0.420010] pci 0000:01:00.0: bridge window [io 0x6000-0x6fff]
[ 0.420013] pci 0000:01:00.0: bridge window [mem 0x85400000-0x855fffff]
[ 0.420015] pci 0000:01:00.0: bridge window [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.420018] pci 0000:00:01.0: PCI bridge to [bus 01-03]
[ 0.420019] pci 0000:00:01.0: bridge window [io 0x6000-0x6fff]
[ 0.420021] pci 0000:00:01.0: bridge window [mem 0x85400000-0x856fffff]
[ 0.420022] pci 0000:00:01.0: bridge window [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.420025] pci 0000:00:1a.0: PCI bridge to [bus 04]
[ 0.420036] pci 0000:00:1a.0: bridge window [io 0x5000-0x5fff]
[ 0.420040] pci 0000:00:1a.0: bridge window [mem 0x84a00000-0x853fffff]
[ 0.420047] pci 0000:00:1a.0: bridge window [mem 0x4212300000-0x42124fffff 64bit pref]
[ 0.420056] pci 0000:00:1b.0: PCI bridge to [bus 05]
[ 0.420069] pci 0000:00:1c.0: PCI bridge to [bus 06]
[ 0.420070] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.420073] pci 0000:00:1c.0: bridge window [mem 0x84000000-0x849fffff]
[ 0.420076] pci 0000:00:1c.0: bridge window [mem 0x4212500000-0x42126fffff 64bit pref]
[ 0.420081] pci 0000:00:1c.2: PCI bridge to [bus 07]
[ 0.420082] pci 0000:00:1c.2: bridge window [io 0x3000-0x3fff]
[ 0.420085] pci 0000:00:1c.2: bridge window [mem 0x85800000-0x858fffff]
[ 0.420091] pci 0000:00:1d.0: PCI bridge to [bus 08]
[ 0.420094] pci 0000:00:1d.0: bridge window [mem 0x85700000-0x857fffff]
[ 0.420100] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.420102] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.420102] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.420103] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000effff window]
[ 0.420104] pci_bus 0000:00: resource 8 [mem 0x80800000-0xbfffffff window]
[ 0.420105] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[ 0.420106] pci_bus 0000:01: resource 0 [io 0x6000-0x6fff]
[ 0.420107] pci_bus 0000:01: resource 1 [mem 0x85400000-0x856fffff]
[ 0.420107] pci_bus 0000:01: resource 2 [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.420108] pci_bus 0000:02: resource 0 [io 0x6000-0x6fff]
[ 0.420109] pci_bus 0000:02: resource 1 [mem 0x85400000-0x855fffff]
[ 0.420110] pci_bus 0000:02: resource 2 [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.420110] pci_bus 0000:03: resource 0 [io 0x6000-0x6fff]
[ 0.420111] pci_bus 0000:03: resource 1 [mem 0x85400000-0x855fffff]
[ 0.420112] pci_bus 0000:03: resource 2 [mem 0x4000000000-0x420fffffff 64bit pref]
[ 0.420113] pci_bus 0000:04: resource 0 [io 0x5000-0x5fff]
[ 0.420114] pci_bus 0000:04: resource 1 [mem 0x84a00000-0x853fffff]
[ 0.420114] pci_bus 0000:04: resource 2 [mem 0x4212300000-0x42124fffff 64bit pref]
[ 0.420115] pci_bus 0000:06: resource 0 [io 0x4000-0x4fff]
[ 0.420116] pci_bus 0000:06: resource 1 [mem 0x84000000-0x849fffff]
[ 0.420117] pci_bus 0000:06: resource 2 [mem 0x4212500000-0x42126fffff 64bit pref]
[ 0.420117] pci_bus 0000:07: resource 0 [io 0x3000-0x3fff]
[ 0.420118] pci_bus 0000:07: resource 1 [mem 0x85800000-0x858fffff]
[ 0.420119] pci_bus 0000:08: resource 1 [mem 0x85700000-0x857fffff]
[ 0.420552] pci 0000:03:00.1: D0 power state depends on 0000:03:00.0
[ 0.420568] PCI: CLS 64 bytes, default 64
[ 0.420577] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.420578] software IO TLB: mapped [mem 0x0000000067503000-0x000000006b503000] (64MB)
[ 0.420588] Trying to unpack rootfs image as initramfs...
[ 0.420612] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x325ea749ca1, max_idle_ns: 440795373125 ns
[ 0.420637] clocksource: Switched to clocksource tsc
[ 0.420650] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.430233] Initialise system trusted keyrings
[ 0.430240] Key type blacklist registered
[ 0.430255] workingset: timestamp_bits=41 max_order=24 bucket_order=0
[ 0.430259] zbud: loaded
[ 0.430395] integrity: Platform Keyring initialized
[ 0.430397] integrity: Machine keyring initialized
[ 0.435772] Key type asymmetric registered
[ 0.435773] Asymmetric key parser 'x509' registered
[ 0.435784] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.435808] io scheduler mq-deadline registered
[ 0.435809] io scheduler kyber registered
[ 0.435815] io scheduler bfq registered
[ 0.437768] pcieport 0000:00:01.0: PME: Signaling with IRQ 121
[ 0.437796] pcieport 0000:00:01.0: AER: enabled with IRQ 121
[ 0.437897] pcieport 0000:00:1a.0: PME: Signaling with IRQ 122
[ 0.437922] pcieport 0000:00:1a.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.438070] pcieport 0000:00:1b.0: PME: Signaling with IRQ 123
[ 0.438160] pcieport 0000:00:1c.0: PME: Signaling with IRQ 124
[ 0.438173] pcieport 0000:00:1c.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.438364] pcieport 0000:00:1c.2: PME: Signaling with IRQ 125
[ 0.438402] pcieport 0000:00:1c.2: AER: enabled with IRQ 125
[ 0.438598] pcieport 0000:00:1d.0: PME: Signaling with IRQ 126
[ 0.438636] pcieport 0000:00:1d.0: AER: enabled with IRQ 126
[ 0.438909] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.439090] Monitor-Mwait will be used to enter C-1 state
[ 0.439094] Monitor-Mwait will be used to enter C-2 state
[ 0.439098] Monitor-Mwait will be used to enter C-3 state
[ 0.439100] ACPI: \_SB_.PR00: Found 3 idle states
[ 0.439488] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.439500] ACPI: button: Sleep Button [SLPB]
[ 0.439518] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.439528] ACPI: button: Power Button [PWRB]
[ 0.439545] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.439578] ACPI: button: Power Button [PWRF]
[ 0.443274] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.443275] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.443405] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.443693] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.446114] hpet_acpi_add: no address or irqs in _CRS
[ 0.446143] Non-volatile memory driver v1.3
[ 0.446144] Linux agpgart interface v0.103
[ 0.452797] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.452821] ACPI: bus type drm_connector registered
[ 0.453943] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 0.456560] fbcon: Deferring console take-over
[ 0.456563] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.457478] ahci 0000:00:17.0: version 3.0
[ 0.457742] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 4 ports 6 Gbps 0xf0 impl SATA mode
[ 0.457744] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds
[ 0.486638] scsi host0: ahci
[ 0.486999] scsi host1: ahci
[ 0.487233] scsi host2: ahci
[ 0.487383] scsi host3: ahci
[ 0.487470] scsi host4: ahci
[ 0.487582] scsi host5: ahci
[ 0.487636] scsi host6: ahci
[ 0.487682] scsi host7: ahci
[ 0.487701] ata1: DUMMY
[ 0.487702] ata2: DUMMY
[ 0.487703] ata3: DUMMY
[ 0.487703] ata4: DUMMY
[ 0.487709] ata5: SATA max UDMA/133 abar m2048@0x85902000 port 0x85902300 irq 128
[ 0.487710] ata6: SATA max UDMA/133 abar m2048@0x85902000 port 0x85902380 irq 128
[ 0.487712] ata7: SATA max UDMA/133 abar m2048@0x85902000 port 0x85902400 irq 128
[ 0.487713] ata8: SATA max UDMA/133 abar m2048@0x85902000 port 0x85902480 irq 128
[ 0.487784] usbcore: registered new interface driver usbserial_generic
[ 0.487787] usbserial: USB Serial support registered for generic
[ 0.487855] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.490079] rtc_cmos rtc_cmos: registered as rtc0
[ 0.490260] rtc_cmos rtc_cmos: setting system clock to 2023-11-28T02:19:53 UTC (1701137993)
[ 0.490294] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.492946] intel_pstate: Intel P-state driver initializing
[ 0.493998] intel_pstate: HWP enabled
[ 0.496280] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.496418] hid: raw HID events driver (C) Jiri Kosina
[ 0.496471] intel_pmc_core INT33A1:00: initialized
[ 0.496550] drop_monitor: Initializing network drop monitor service
[ 0.501763] Initializing XFRM netlink socket
[ 0.501783] NET: Registered PF_INET6 protocol family
[ 0.540679] Freeing initrd memory: 22496K
[ 0.545493] Segment Routing with IPv6
[ 0.545495] RPL Segment Routing with IPv6
[ 0.545504] In-situ OAM (IOAM) with IPv6
[ 0.545527] NET: Registered PF_PACKET protocol family
[ 0.547426] microcode: Microcode Update Driver: v2.2.
[ 0.547430] IPI shorthand broadcast: enabled
[ 0.548098] sched_clock: Marking stable (541426891, 5996409)->(572989860, -25566560)
[ 0.548405] registered taskstats version 1
[ 0.549259] Loading compiled-in X.509 certificates
[ 0.550498] Loaded X.509 cert 'Build time autogenerated kernel key: 8917c996db5ddd5e9f604a2942d3e421536f97ab'
[ 0.553616] zswap: loaded using pool zstd/zsmalloc
[ 0.554282] Key type .fscrypt registered
[ 0.554283] Key type fscrypt-provisioning registered
[ 0.554300] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.554542] integrity: Loading X.509 certificate: UEFI:db
[ 0.554639] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[ 0.554639] integrity: Loading X.509 certificate: UEFI:db
[ 0.554703] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[ 0.554704] integrity: Loading X.509 certificate: UEFI:db
[ 0.554712] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.554712] integrity: Loading X.509 certificate: UEFI:db
[ 0.554718] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.554718] integrity: Loading X.509 certificate: UEFI:db
[ 0.554783] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 0.555190] PM: Magic number: 15:615:309
[ 0.555217] tty tty38: hash matches
[ 0.556811] RAS: Correctable Errors collector initialized.
[ 0.796251] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.797095] ata5.00: ATA-11: WDC WDS200T2B0A-00SM50, 415020WD, max UDMA/133
[ 0.797471] ata5.00: 3907029168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.799101] ata5.00: Features: Dev-Sleep
[ 0.800709] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.800937] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.801226] ata6.00: ATA-9: M4-CT256M4SSD2, 000F, max UDMA/100
[ 0.801526] ata6.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.802063] ata6.00: configured for UDMA/100
[ 0.802497] ata5.00: configured for UDMA/133
[ 0.802888] scsi 4:0:0:0: Direct-Access ATA WDC WDS200T2B0A 20WD PQ: 0 ANSI: 5
[ 0.803454] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 0.803502] sd 4:0:0:0: [sda] Write Protect is off
[ 0.803509] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.803646] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.803691] scsi 5:0:0:0: Direct-Access ATA M4-CT256M4SSD2 000F PQ: 0 ANSI: 5
[ 0.803718] sd 4:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 0.803878] ata8: SATA link down (SStatus 4 SControl 300)
[ 0.804456] sd 5:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ 0.804471] sd 5:0:0:0: [sdb] Write Protect is off
[ 0.804474] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 0.804490] sd 5:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.804510] sd 5:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
[ 0.805839] sdb: sdb1 sdb2 sdb3
[ 0.806417] sda: sda1
[ 0.806473] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 0.806617] sd 4:0:0:0: [sda] Attached SCSI disk
[ 0.829421] ata7.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133
[ 0.838520] ata7.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.899228] ata7.00: configured for UDMA/133
[ 0.899696] scsi 6:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5
[ 0.901252] sd 6:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 0.901259] sd 6:0:0:0: [sdc] 4096-byte physical blocks
[ 0.901368] sd 6:0:0:0: [sdc] Write Protect is off
[ 0.901376] sd 6:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 0.901572] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.901862] sd 6:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[ 0.948618] sdc: sdc1 sdc2
[ 0.949002] sd 6:0:0:0: [sdc] Attached SCSI disk
[ 0.949237] clk: Disabling unused clocks
[ 0.962544] Freeing unused decrypted memory: 2028K
[ 0.962978] Freeing unused kernel image (initmem) memory: 3420K
[ 0.962980] Write protecting the kernel read-only data: 30720k
[ 0.963597] Freeing unused kernel image (rodata/data gap) memory: 1196K
[ 0.967766] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.967769] rodata_test: all tests were successful
[ 0.967771] Run /init as init process
[ 0.967772] with arguments:
[ 0.967773] /init
[ 0.967773] with environment:
[ 0.967773] HOME=/
[ 0.967774] TERM=linux
[ 0.967774] BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
[ 0.988783] fbcon: Taking over console
[ 0.994453] Console: switching to colour frame buffer device 240x50
[ 1.094013] vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
[ 1.094017] pci_bus 10000:e0: root bus resource [bus e0-ff]
[ 1.094019] pci_bus 10000:e0: root bus resource [mem 0x82000000-0x83ffffff]
[ 1.094020] pci_bus 10000:e0: root bus resource [mem 0x4212102000-0x42121fffff 64bit]
[ 1.094866] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.094870] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.095953] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 1.096192] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.096194] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.096195] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 1.096253] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 1.096256] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.096257] usb usb1: Product: xHCI Host Controller
[ 1.096258] usb usb1: Manufacturer: Linux 6.6.1-1-MANJARO xhci-hcd
[ 1.096259] usb usb1: SerialNumber: 0000:00:14.0
[ 1.096362] hub 1-0:1.0: USB hub found
[ 1.096390] hub 1-0:1.0: 16 ports detected
[ 1.097723] vmd 0000:00:0e.0: Bound to PCI domain 10000
[ 1.098943] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 1.098945] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.098946] usb usb2: Product: xHCI Host Controller
[ 1.098947] usb usb2: Manufacturer: Linux 6.6.1-1-MANJARO xhci-hcd
[ 1.098947] usb usb2: SerialNumber: 0000:00:14.0
[ 1.098998] hub 2-0:1.0: USB hub found
[ 1.099017] hub 2-0:1.0: 10 ports detected
[ 1.099610] usb: port power management may be unreliable
[ 1.099940] nvme 0000:08:00.0: platform quirk: setting simple suspend
[ 1.099985] nvme nvme0: pci function 0000:08:00.0
[ 1.129483] nvme nvme0: 20/0/0 default/read/poll queues
[ 1.134798] nvme0n1: p1 p2 p3
[ 1.340994] PM: Image not found (code -22)
[ 1.346079] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[ 1.397228] EXT4-fs (nvme0n1p2): mounted filesystem d8f51c21-a5ce-4611-973c-b7d694ae22a1 r/w with ordered data mode. Quota mode: none.
[ 1.490553] usb 1-2: config 1 has an invalid interface number: 2 but max is 1
[ 1.490556] usb 1-2: config 1 has no interface number 1
[ 1.491400] usb 1-2: New USB device found, idVendor=0b05, idProduct=19af, bcdDevice= 1.00
[ 1.491403] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.491404] usb 1-2: Product: AURA LED Controller
[ 1.491406] usb 1-2: Manufacturer: AsusTek Computer Inc.
[ 1.491407] usb 1-2: SerialNumber: 9876543210
[ 1.498111] systemd[1]: systemd 254.6-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.498126] systemd[1]: Detected architecture x86-64.
[ 1.499089] systemd[1]: Hostname set to <hostname>.
[ 1.616310] usb 2-10: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.642528] systemd[1]: bpf-lsm: LSM BPF program attached
[ 1.673810] usb 2-10: New USB device found, idVendor=174c, idProduct=3074, bcdDevice= 0.01
[ 1.673819] usb 2-10: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 1.673822] usb 2-10: Product: ASM107x
[ 1.673825] usb 2-10: Manufacturer: ASUS TEK.
[ 1.686363] hub 2-10:1.0: USB hub found
[ 1.690104] hub 2-10:1.0: 4 ports detected
[ 1.776005] usb 1-8: new high-speed USB device number 3 using xhci_hcd
[ 1.796580] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.824160] systemd[1]: Created slice Slice /system/getty.
[ 1.824624] systemd[1]: Created slice Slice /system/modprobe.
[ 1.824999] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.825283] systemd[1]: Created slice User and Session Slice.
[ 1.825378] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.825908] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.826033] systemd[1]: Reached target Login Prompts.
[ 1.826130] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 1.826178] systemd[1]: Reached target Remote File Systems.
[ 1.826206] systemd[1]: Reached target Slice Units.
[ 1.826276] systemd[1]: Reached target Local Verity Protected Volumes.
[ 1.826412] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.826697] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.828375] systemd[1]: Listening on Process Core Dump Socket.
[ 1.828547] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.828681] systemd[1]: Listening on Journal Socket.
[ 1.828953] systemd[1]: Listening on udev Control Socket.
[ 1.829066] systemd[1]: Listening on udev Kernel Socket.
[ 1.830556] systemd[1]: Mounting Huge Pages File System...
[ 1.831729] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.832253] systemd[1]: Mounting Kernel Debug File System...
[ 1.832537] systemd[1]: Mounting Kernel Trace File System...
[ 1.832906] systemd[1]: Starting Load AppArmor profiles...
[ 1.833233] systemd[1]: Starting Create List of Static Device Nodes...
[ 1.833540] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.833856] systemd[1]: Starting Load Kernel Module configfs...
[ 1.834170] systemd[1]: Starting Load Kernel Module dm_mod...
[ 1.834486] systemd[1]: Starting Load Kernel Module drm...
[ 1.834837] systemd[1]: Starting Load Kernel Module fuse...
[ 1.835154] systemd[1]: Starting Load Kernel Module loop...
[ 1.835202] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 1.835667] systemd[1]: Starting Load Kernel Modules...
[ 1.835691] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 1.835988] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.836310] systemd[1]: Starting Coldplug All udev Devices...
[ 1.836621] systemd[1]: Starting Virtual Console Setup...
[ 1.837232] systemd[1]: Mounted Huge Pages File System.
[ 1.837311] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.837359] systemd[1]: Mounted Kernel Debug File System.
[ 1.837976] systemd[1]: Mounted Kernel Trace File System.
[ 1.838520] loop: module loaded
[ 1.839488] EXT4-fs (nvme0n1p2): re-mounted d8f51c21-a5ce-4611-973c-b7d694ae22a1 r/w. Quota mode: none.
[ 1.841824] fuse: init (API version 7.39)
[ 1.842064] device-mapper: uevent: version 1.0.3
[ 1.842157] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 1.844320] vboxdrv: loading out-of-tree module taints kernel.
[ 1.844322] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 1.857216] audit: type=1400 audit(1701137994.863:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-anvil" pid=405 comm="apparmor_parser"
[ 1.857276] audit: type=1400 audit(1701137994.863:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=401 comm="apparmor_parser"
[ 1.859490] vboxdrv: Found 20 processor cores/threads
[ 1.865336] audit: type=1400 audit(1701137994.869:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=393 comm="apparmor_parser"
[ 1.868034] audit: type=1400 audit(1701137994.873:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-director" pid=410 comm="apparmor_parser"
[ 1.869228] audit: type=1400 audit(1701137994.873:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=394 comm="apparmor_parser"
[ 1.869255] audit: type=1400 audit(1701137994.873:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-dict" pid=409 comm="apparmor_parser"
[ 1.869609] audit: type=1400 audit(1701137994.873:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="syslogd" pid=403 comm="apparmor_parser"
[ 1.869612] audit: type=1400 audit(1701137994.873:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-config" pid=407 comm="apparmor_parser"
[ 1.869639] audit: type=1400 audit(1701137994.876:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=394 comm="apparmor_parser"
[ 1.881620] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.882721] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 1.882890] vboxdrv: TSC mode is Invariant, tentative frequency 3494399665 Hz
[ 1.882892] vboxdrv: Successfully loaded version 7.0.12 r159484 (interface 0x00330004)
[ 1.886398] VBoxNetAdp: Successfully started.
[ 1.887744] VBoxNetFlt: Successfully started.
[ 1.897189] Guest personality initialized and is inactive
[ 1.897264] VMCI host device registered (name=vmci, major=10, minor=120)
[ 1.897266] Initialized host personality
[ 1.909575] systemd[1]: Finished Load Kernel Module configfs.
[ 1.910661] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 1.926483] usb 1-8: New USB device found, idVendor=03f0, idProduct=632a, bcdDevice= 1.00
[ 1.926487] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.926488] usb 1-8: Product: HP LaserJet M203-M206
[ 1.926488] usb 1-8: Manufacturer: HP
[ 1.926489] usb 1-8: SerialNumber: VND3B11535
[ 1.946379] systemd[1]: Finished Load Kernel Module dm_mod.
[ 1.946632] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.989895] systemd[1]: Finished Load Kernel Module drm.
[ 2.023160] systemd[1]: Finished Load AppArmor profiles.
[ 2.056096] usb 1-10: new high-speed USB device number 4 using xhci_hcd
[ 2.059590] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 2.060141] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.082990] systemd[1]: Finished Load Kernel Module fuse.
[ 2.083449] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 2.112849] systemd[1]: Finished Load Kernel Module loop.
[ 2.136094] systemd[1]: Finished Load Kernel Modules.
[ 2.159564] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.189591] systemd[1]: Finished Coldplug All udev Devices.
[ 2.208440] usb 1-10: New USB device found, idVendor=174c, idProduct=2074, bcdDevice= 0.01
[ 2.208450] usb 1-10: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 2.208453] usb 1-10: Product: ASM107x
[ 2.208455] usb 1-10: Manufacturer: ASUS TEK.
[ 2.209960] hub 1-10:1.0: USB hub found
[ 2.210138] hub 1-10:1.0: 4 ports detected
[ 2.216275] systemd[1]: Finished Virtual Console Setup.
[ 2.246250] systemd[1]: Activating swap /swapfile...
[ 2.247783] systemd[1]: Mounting FUSE Control File System...
[ 2.249051] systemd[1]: Mounting Kernel Configuration File System...
[ 2.250990] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 2.251974] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 2.253501] systemd[1]: Starting Load/Save OS Random Seed...
[ 2.253759] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 2.253794] Adding 524284k swap on /swapfile. Priority:-2 extents:5 across:465616892k SS
[ 2.255050] systemd[1]: Starting Apply Kernel Variables...
[ 2.256174] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 2.257534] systemd[1]: Activated swap /swapfile.
[ 2.258728] systemd[1]: Mounted FUSE Control File System.
[ 2.259261] systemd[1]: Mounted Kernel Configuration File System.
[ 2.261290] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 448 (snapd-apparmor)
[ 2.263003] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 2.286345] systemd[1]: Finished Load/Save OS Random Seed.
[ 2.299621] usb 2-10.2: new SuperSpeed USB device number 3 using xhci_hcd
[ 2.323502] usb 2-10.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[ 2.323508] usb 2-10.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.323511] usb 2-10.2: Product: USB3.1 Hub
[ 2.323513] usb 2-10.2: Manufacturer: GenesysLogic
[ 2.329736] systemd[1]: Finished Apply Kernel Variables.
[ 2.330162] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 2.334654] hub 2-10.2:1.0: USB hub found
[ 2.335442] hub 2-10.2:1.0: 4 ports detected
[ 2.356275] systemd[1]: Starting CLI Netfilter Manager...
[ 2.376383] systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
[ 2.419733] systemd[1]: Finished CLI Netfilter Manager.
[ 2.442699] usb 1-13: new high-speed USB device number 5 using xhci_hcd
[ 2.459525] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 2.522976] systemd[1]: Starting Create System Users...
[ 2.559704] systemd[1]: Finished Create System Users.
[ 2.561536] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.612934] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.613316] systemd[1]: Reached target Preparation for Local File Systems.
[ 2.614463] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 2.616556] systemd[1]: Mounting Mount unit for core, revision 15925...
[ 2.619769] systemd[1]: Mounting Mount unit for core, revision 16202...
[ 2.620488] loop0: detected capacity change from 0 to 216728
[ 2.620514] systemd[1]: Mounting Mount unit for core18, revision 2790...
[ 2.620851] loop1: detected capacity change from 0 to 216720
[ 2.621306] systemd[1]: Mounting Mount unit for core18, revision 2796...
[ 2.621672] loop2: detected capacity change from 0 to 113992
[ 2.622121] systemd[1]: Mounting Mount unit for hello-world, revision 29...
[ 2.622447] loop3: detected capacity change from 0 to 113992
[ 2.622906] systemd[1]: Mounting Mount unit for jupyter, revision 6...
[ 2.622964] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 2.623403] loop4: detected capacity change from 0 to 40
[ 2.624201] loop5: detected capacity change from 0 to 137792
[ 2.624650] systemd[1]: Starting Journal Service...
[ 2.624672] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.625287] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.626669] systemd[1]: Mounted Mount unit for core, revision 15925.
[ 2.627253] systemd[1]: Mounted Mount unit for core, revision 16202.
[ 2.627315] systemd[1]: Mounted Mount unit for core18, revision 2790.
[ 2.627596] systemd[1]: Mounted Mount unit for core18, revision 2796.
[ 2.627876] systemd[1]: Mounted Mount unit for hello-world, revision 29.
[ 2.628150] systemd[1]: Mounted Mount unit for jupyter, revision 6.
[ 2.629742] systemd-journald[499]: Collecting audit messages is disabled.
[ 2.643117] systemd[1]: Started Journal Service.
[ 2.651102] systemd-journald[499]: Received client request to flush runtime journal.
[ 2.658156] systemd-journald[499]: /var/log/journal/aede48b225b340f58e75f1991d5c06ed/system.journal: Journal file uses a different sequence number ID, rotating.
[ 2.658168] systemd-journald[499]: Rotating system journal.
[ 2.676015] usb 1-10.2: new high-speed USB device number 6 using xhci_hcd
[ 2.726850] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 2.726915] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 2.728617] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 2.728676] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 2.730801] i2c i2c-0: 4/4 memory slots populated (from DMI)
[ 2.731237] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 2.731651] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 2.732075] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 2.732208] spi-nor spi0.0: s25fl064k (8192 Kbytes)
[ 2.732489] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 2.732765] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[ 2.733034] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 2.734480] Creating 1 MTD partitions on "0000:00:1f.5":
[ 2.734482] 0x000000000000-0x000001800000 : "BIOS"
[ 2.734483] mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x800000
[ 2.735534] spi-nor spi0.1: mx25l12805d (16384 Kbytes)
[ 2.749151] intel-lpss 0000:00:15.2: enabling device (0004 -> 0006)
[ 2.749617] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.749641] ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.749652] ee1004 0-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.749661] ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.749741] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 2.750561] iTCO_vendor_support: vendor-support=0
[ 2.788423] usb 1-10.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 2.788426] usb 1-10.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.788427] usb 1-10.2: Product: USB2.1 Hub
[ 2.788427] usb 1-10.2: Manufacturer: GenesysLogic
[ 2.789293] hub 1-10.2:1.0: USB hub found
[ 2.789549] hub 1-10.2:1.0: 4 ports detected
[ 2.793335] r8169 0000:07:00.0: enabling device (0000 -> 0003)
[ 2.793618] r8169 0000:07:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.807805] r8169 0000:07:00.0 eth0: RTL8125B, 50:eb:f6:5c:e0:0f, XID 641, IRQ 171
[ 2.807809] r8169 0000:07:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.843493] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 2.843642] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 2.847422] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
[ 2.847430] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.847433] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.850210] r8169 0000:07:00.0 enp7s0: renamed from eth0
[ 2.850330] asus_wmi: ASUS WMI generic driver loaded
[ 2.853632] asus_wmi: Initialization: 0x0
[ 2.853693] asus_wmi: BIOS WMI version: 0.0
[ 2.853828] asus_wmi: SFUN value: 0x0
[ 2.853831] eeepc-wmi eeepc-wmi: Detected AsusMbSwInterface, not ASUSWMI, use DSTS
[ 2.856973] Adding 196607996k swap on /dev/nvme0n1p1. Priority:-3 extents:1 across:196607996k SS
[ 2.857134] cryptd: max_cpu_qlen set to 1000
[ 2.857355] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input4
[ 2.869738] AVX2 version of gcm_enc/dec engaged.
[ 2.869763] AES CTR mode by8 optimization enabled
[ 2.873497] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 2.873710] snd_hda_intel 0000:03:00.1: enabling device (0000 -> 0002)
[ 2.873825] snd_hda_intel 0000:03:00.1: Force to non-snoop mode
[ 2.884577] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1/input5
[ 2.884621] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1/input6
[ 2.884640] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1/input7
[ 2.884663] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1/input8
[ 2.884696] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1/input9
[ 2.897832] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC897: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 2.897838] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.897839] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.897841] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 2.897841] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x0
[ 2.897842] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 2.897843] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 2.897844] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 2.897845] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 2.921192] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[ 2.921216] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[ 2.921235] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 2.921253] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 2.921271] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 2.955138] intel_tcc_cooling: Programmable TCC Offset detected
[ 3.099414] usb 1-10.2.1: new full-speed USB device number 7 using xhci_hcd
[ 3.214122] usb 1-10.2.1: New USB device found, idVendor=1532, idProduct=0084, bcdDevice= 2.00
[ 3.214124] usb 1-10.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.214125] usb 1-10.2.1: Product: Razer DeathAdder V2
[ 3.214126] usb 1-10.2.1: Manufacturer: Razer
[ 3.319335] usb 1-10.2.2: new low-speed USB device number 8 using xhci_hcd
[ 3.438167] usb 1-10.2.2: New USB device found, idVendor=04f2, idProduct=0400, bcdDevice= 1.03
[ 3.438168] usb 1-10.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.438169] usb 1-10.2.2: Product: USB Keyboard
[ 3.438169] usb 1-10.2.2: Manufacturer: Chicony
[ 3.536005] usb 1-10.2.4: new full-speed USB device number 9 using xhci_hcd
[ 3.543539] EXT4-fs (sda1): mounted filesystem 4ea61d4f-2919-48cc-aae4-6d268776ea4f r/w with ordered data mode. Quota mode: none.
[ 3.650336] usb 1-10.2.4: New USB device found, idVendor=0b05, idProduct=190e, bcdDevice= 2.00
[ 3.650339] usb 1-10.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.650339] usb 1-10.2.4: Product: ASUS USB-BT500
[ 3.650340] usb 1-10.2.4: Manufacturer: Realtek
[ 3.650341] usb 1-10.2.4: SerialNumber: 00E04C239987
[ 3.901903] [drm] amdgpu kernel modesetting enabled.
[ 3.901983] amdgpu: Virtual CRAT table created for CPU
[ 3.901988] amdgpu: Topology: Add CPU node
[ 3.902081] amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
[ 3.902160] [drm] initializing kernel modesetting (DIMGREY_CAVEFISH 0x1002:0x73FF 0x1DA2:0x448E 0xC1).
[ 3.902166] [drm] register mmio base: 0x85400000
[ 3.902167] [drm] register mmio size: 1048576
[ 3.905322] [drm] add ip block number 0 <nv_common>
[ 3.905324] [drm] add ip block number 1 <gmc_v10_0>
[ 3.905326] [drm] add ip block number 2 <navi10_ih>
[ 3.905327] [drm] add ip block number 3 <psp>
[ 3.905328] [drm] add ip block number 4 <smu>
[ 3.905330] [drm] add ip block number 5 <dm>
[ 3.905331] [drm] add ip block number 6 <gfx_v10_0>
[ 3.905332] [drm] add ip block number 7 <sdma_v5_2>
[ 3.905333] [drm] add ip block number 8 <vcn_v3_0>
[ 3.905334] [drm] add ip block number 9 <jpeg_v3_0>
[ 3.905356] amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
[ 3.905358] amdgpu: ATOM BIOS: 113-3E4480U-S6L
[ 3.907298] intel_rapl_msr: PL4 support detected.
[ 3.907315] intel_rapl_common: Found RAPL domain package
[ 3.907318] intel_rapl_common: Found RAPL domain core
[ 3.912774] [drm] VCN(0) decode is enabled in VM mode
[ 3.912776] [drm] VCN(0) encode is enabled in VM mode
[ 3.914574] [drm] JPEG decode is enabled in VM mode
[ 3.929373] Console: switching to colour dummy device 80x25
[ 3.989676] amdgpu 0000:03:00.0: vgaarb: deactivate vga console
[ 3.989680] amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 3.989734] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 3.989739] amdgpu 0000:03:00.0: amdgpu: VRAM: 8176M 0x0000008000000000 - 0x00000081FEFFFFFF (8176M used)
[ 3.989740] amdgpu 0000:03:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[ 3.989741] amdgpu 0000:03:00.0: amdgpu: AGP: 267894784M 0x0000008400000000 - 0x0000FFFFFFFFFFFF
[ 3.989749] [drm] Detected VRAM RAM=8176M, BAR=8192M
[ 3.989750] [drm] RAM width 128bits GDDR6
[ 3.989867] [drm] amdgpu: 8176M of VRAM memory ready
[ 3.989868] [drm] amdgpu: 32023M of GTT memory ready.
[ 3.989877] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 3.989965] [drm] PCIE GART of 512M enabled (table at 0x00000081FEB00000).
[ 4.471701] NET: Registered PF_QIPCRTR protocol family
[ 4.499353] RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
[ 4.692876] r8169 0000:07:00.0 enp7s0: Link is Down
[ 4.938254] usb 1-13: New USB device found, idVendor=046d, idProduct=085c, bcdDevice= 0.16
[ 4.938257] usb 1-13: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 4.938258] usb 1-13: Product: C922 Pro Stream Webcam
[ 4.938259] usb 1-13: SerialNumber: EB8FAF8F
[ 4.957784] hid-generic 0003:0B05:19AF.0001: hiddev96,hidraw0: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:00:14.0-2/input2
[ 4.958195] input: Razer Razer DeathAdder V2 as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.2/1-10.2.1/1-10.2.1:1.0/0003:1532:0084.0002/input/input15
[ 4.958226] hid-generic 0003:1532:0084.0002: input,hidraw1: USB HID v1.00 Mouse [Razer Razer DeathAdder V2] on usb-0000:00:14.0-10.2.1/input0
[ 4.958763] input: Razer Razer DeathAdder V2 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.2/1-10.2.1/1-10.2.1:1.1/0003:1532:0084.0003/input/input16
[ 4.959276] mc: Linux media interface: v0.10
[ 4.967791] videodev: Linux video capture interface: v2.00
[ 4.980943] Bluetooth: Core ver 2.22
[ 4.980955] NET: Registered PF_BLUETOOTH protocol family
[ 4.980956] Bluetooth: HCI device and connection manager initialized
[ 4.980958] Bluetooth: HCI socket layer initialized
[ 4.980960] Bluetooth: L2CAP socket layer initialized
[ 4.980962] Bluetooth: SCO socket layer initialized
[ 5.016084] input: Razer Razer DeathAdder V2 as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.2/1-10.2.1/1-10.2.1:1.1/0003:1532:0084.0003/input/input17
[ 5.016192] hid-generic 0003:1532:0084.0003: input,hidraw2: USB HID v1.00 Keyboard [Razer Razer DeathAdder V2] on usb-0000:00:14.0-10.2.1/input1
[ 5.016731] input: Razer Razer DeathAdder V2 as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.2/1-10.2.1/1-10.2.1:1.2/0003:1532:0084.0004/input/input18
[ 5.039121] usbcore: registered new interface driver btusb
[ 5.041749] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[ 5.042717] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 5.042720] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[ 5.043068] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[ 5.043199] Bluetooth: hci0: RTL: cfg_sz 6, total sz 30210
[ 5.072787] hid-generic 0003:1532:0084.0004: input,hidraw3: USB HID v1.00 Keyboard [Razer Razer DeathAdder V2] on usb-0000:00:14.0-10.2.1/input2
[ 5.073648] hid-generic 0003:1532:0084.0005: hiddev97,hidraw4: USB HID v1.11 Device [Razer Razer DeathAdder V2] on usb-0000:00:14.0-10.2.1/input3
[ 5.076528] input: Chicony USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10.2/1-10.2.2/1-10.2.2:1.0/0003:04F2:0400.0006/input/input19
[ 5.086387] usblp 1-8:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x03F0 pid 0x632A
[ 5.086409] usbcore: registered new interface driver usblp
[ 5.094734] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.094735] Bluetooth: BNEP filters: protocol multicast
[ 5.094737] Bluetooth: BNEP socket layer initialized
[ 5.098236] usbcore: registered new interface driver snd-usb-audio
[ 5.098263] usb 1-13: Found UVC 1.00 device C922 Pro Stream Webcam (046d:085c)
[ 5.099252] usbcore: registered new interface driver uvcvideo
[ 5.132757] hid-generic 0003:04F2:0400.0006: input,hidraw5: USB HID v1.11 Keyboard [Chicony USB Keyboard] on usb-0000:00:14.0-10.2.2/input0
[ 5.132778] usbcore: registered new interface driver usbhid
[ 5.132779] usbhid: USB HID core driver
[ 5.138944] mousedev: PS/2 mouse device common for all mice
[ 5.192027] amdgpu 0000:03:00.0: amdgpu: STB initialized to 2048 entries
[ 5.192077] [drm] Loading DMUB firmware via PSP: version=0x02020020
[ 5.192531] [drm] use_doorbell being set to: [true]
[ 5.192539] [drm] use_doorbell being set to: [true]
[ 5.192547] [drm] Found VCN firmware Version ENC: 1.29 DEC: 2 VEP: 0 Revision: 2
[ 5.192550] amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
[ 5.194758] Bluetooth: hci0: RTL: fw version 0xdfc6d922
[ 5.261824] Bluetooth: MGMT ver 1.22
[ 5.264368] NET: Registered PF_ALG protocol family
[ 5.271929] [drm] reserve 0xa00000 from 0x81fd000000 for PSP TMR
[ 5.395030] amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 5.416699] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 5.416734] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000000f, smu fw if version = 0x00000013, smu fw program = 0, version = 0x003b2f00 (59.47.0)
[ 5.416742] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[ 5.416783] amdgpu 0000:03:00.0: amdgpu: use vbios provided pptable
[ 5.464329] amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
[ 5.464508] [drm] Display Core v3.2.247 initialized on DCN 3.0.2
[ 5.464509] [drm] DP-HDMI FRL PCON supported
[ 5.465648] [drm] DMUB hardware initialized: version=0x02020020
[ 5.467913] snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 5.631208] [drm] kiq ring mec 2 pipe 1 q 0
[ 5.635311] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 5.635702] [drm] JPEG decode initialized successfully.
[ 5.684551] amdgpu: HMM registered 8176MB device memory
[ 5.685717] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 5.685727] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 5.686044] amdgpu: Virtual CRAT table created for GPU
[ 5.686146] amdgpu: Topology: Add dGPU node [0x73ff:0x1002]
[ 5.686147] kfd kfd: amdgpu: added device 1002:73ff
[ 5.686164] amdgpu 0000:03:00.0: amdgpu: SE 2, SH per SE 2, CU per SH 8, active_cu_number 32
[ 5.686306] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 5.686307] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 5.686308] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 5.686308] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 5.686309] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 5.686309] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 5.686309] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 5.686310] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 5.686310] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 5.686311] amdgpu 0000:03:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 11 on hub 0
[ 5.686311] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 5.686312] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[ 5.686312] amdgpu 0000:03:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[ 5.686312] amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[ 5.686313] amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[ 5.686313] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[ 5.687214] amdgpu 0000:03:00.0: amdgpu: Using BACO for runtime pm
[ 5.687495] [drm] Initialized amdgpu 3.54.0 20150101 for 0000:03:00.0 on minor 1
[ 5.694000] fbcon: amdgpudrmfb (fb0) is primary device
[ 5.694113] [drm] DSC precompute is not needed.
[ 5.802818] Console: switching to colour frame buffer device 240x50
[ 5.822631] amdgpu 0000:03:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 7.541080] r8169 0000:07:00.0 enp7s0: Link is Up - 1Gbps/Full - flow control off
[ 10.156521] usblp0: removed
[ 10.160576] usblp 1-8:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x03F0 pid 0x632A
[ 19.718186] systemd-journald[499]: /var/log/journal/aede48b225b340f58e75f1991d5c06ed/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[ 42.328804] gnome-shell[3253]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 42.773242] rfkill: input handler disabled
[ 43.182841] usb 1-13: reset high-speed USB device number 5 using xhci_hcd
[ 43.329858] usb 1-13: device firmware changed
[ 43.329908] usb 1-13: USB disconnect, device number 5
[ 43.678220] Bluetooth: RFCOMM TTY layer initialized
[ 43.678225] Bluetooth: RFCOMM socket layer initialized
[ 43.678226] Bluetooth: RFCOMM ver 1.11
[ 43.732666] usb 1-13: new high-speed USB device number 10 using xhci_hcd
[ 45.117944] usblp0: removed
[ 46.111420] usb 1-13: New USB device found, idVendor=046d, idProduct=085c, bcdDevice= 0.16
[ 46.111423] usb 1-13: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 46.111424] usb 1-13: Product: C922 Pro Stream Webcam
[ 46.111425] usb 1-13: SerialNumber: EB8FAF8F
[ 46.112530] usb 1-13: Found UVC 1.00 device C922 Pro Stream Webcam (046d:085c)
[ 73.097291] usb 1-13: reset high-speed USB device number 10 using xhci_hcd
[ 73.244300] usb 1-13: device firmware changed
[ 73.244327] usb 1-13: USB disconnect, device number 10
[ 73.646940] usb 1-13: new high-speed USB device number 11 using xhci_hcd
[ 76.191476] usb 1-13: New USB device found, idVendor=046d, idProduct=085c, bcdDevice= 0.16
[ 76.191483] usb 1-13: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 76.191485] usb 1-13: Product: C922 Pro Stream Webcam
[ 76.191487] usb 1-13: SerialNumber: EB8FAF8F
[ 76.192751] usb 1-13: Found UVC 1.00 device C922 Pro Stream Webcam (046d:085c)
[ 84.864600] usb 1-13: reset high-speed USB device number 11 using xhci_hcd
[ 85.008113] usb 1-13: device firmware changed
[ 85.008200] usb 1-13: USB disconnect, device number 11
[ 85.410982] usb 1-13: new high-speed USB device number 12 using xhci_hcd
[ 87.919702] usb 1-13: New USB device found, idVendor=046d, idProduct=085c, bcdDevice= 0.16
[ 87.919713] usb 1-13: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 87.919716] usb 1-13: Product: C922 Pro Stream Webcam
[ 87.919719] usb 1-13: SerialNumber: EB8FAF8F
[ 87.921698] usb 1-13: Found UVC 1.00 device C922 Pro Stream Webcam (046d:085c)
