Slug
23 February 2022 15:26
1
I have an up-to-date manjaro kde , with the Qgis 3.22.1-3 from the community repository.
I have also a working install of GRASS 8.1.dev, a major release recently published .
However, the version of Qgis from the community repository does not support GRASS 8 processing tools, since the Qgis GRASS provider only considers up to GRASS 7.
I’ve presented the case on Qgis git page , where I’ve been told to update my Qgis installation , since this commit have brought support for GRASS 8 in Qgis.
Qgis 3.24 has just been released.
It would be great to update the Manjaro community Qgis package.
Lolix
23 February 2022 15:56
2
qgis is imported from Arch
Both testing and unstable have 3.24. So either switch branches or wait till it hits stable.
Links
Manjaro - Branch Compare
Switching Branches - Manjaro
Slug
23 February 2022 18:34
4
I changed branch, as suggested, from stable to unstable , using the recommended steps .
I had warnings about possibly missing firmware, and about some missing kernel module headers. Is there a log I can find ?
I rebooted anyway.
Qgis is now on version 3.24, and GRASS 8 appears in the processing toolbox.
I have switched back to stable .
It seems you don’t read #announcements and/or weren’t up to date on the stable branch to begin with.
New warnings when building the fallback initcpio - Possibly missing firmware for module: bfa, qed, qla1280, qla2xxx
That’s due to the recent changes to the linux-firmware package. Note these are warnings, not errors. You only need those firmwares if you have Mellanox Spectrum switches, Marvell devices, Qualcomm SoCs, Cavium LiquidIO server adapters, QLogic devices and Broadcom NetXtreme II 10Gb ethernet adapters. if you have that hardware you can install linux-firmware-qlogic to get rid of those warnings. If you do not have that hardware you can safely ignore those warnings.
pamac install linux-firmware-qlogic
See also Manjaro - Branch Compare and Manjaro - Fresh & Stable .
system
Closed
26 February 2022 13:48
6
