Having an issue getting HDMI audio to work with RPi4 (Raspberry Pi 4) to new audio-enabled monitor. It does work out of box with Raspbian, but I don’t want to use that. Alsa seems to see the devices, although alsamixer says there are no controls associated with the HDMI audio devices. KDE audio mixer app using pipewire does not seem to show any audio devices other than headphone jack. This is stable branch.
I’ve been through every RPi4/RPi HDMI audio and HDMI audio posting I could find to find potential clues or solutions and have come up with no working solution.
Any thoughts or recommendations?
uname -a:
Linux rpi4 5.15.56-1-MANJARO-ARM-RPI #1 SMP PREEMPT Fri Jul 22 13:22:49 UTC 2022 aarch64 GNU/Linux
/dev/snd:
drwxr-xr-x 2 root root 100 Aug 9 18:29 by-path
crw-rw----+ 1 root audio 116, 0 Aug 9 18:29 controlC0
crw-rw----+ 1 root audio 116, 32 Aug 9 18:29 controlC1
crw-rw----+ 1 root audio 116, 64 Aug 9 18:29 controlC2
crw-rw----+ 1 root audio 116, 16 Aug 9 18:29 pcmC0D0p
crw-rw----+ 1 root audio 116, 48 Aug 9 18:29 pcmC1D0p
crw-rw----+ 1 root audio 116, 80 Aug 9 18:29 pcmC2D0p
crw-rw----+ 1 root audio 116, 1 Aug 24 10:59 seq
crw-rw----+ 1 root audio 116, 33 Aug 9 18:29 timer
lsmod:
lsmod | egrep snd\|bcm
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 81920 7 snd_seq_dummy
snd_seq_device 20480 1 snd_seq
snd_soc_hdmi_codec 20480 2
btbcm 28672 1 hci_uart
bcm2835_v4l2 45056 0
bluetooth 487424 43 hci_uart,btbcm,bnep,rfcomm
bcm2835_codec 53248 0
v4l2_mem2mem 45056 2 bcm2835_codec,rpivid_hevc
videobuf2_vmalloc 20480 1 bcm2835_v4l2
bcm2835_isp 32768 0
bcm2835_mmal_vchiq 40960 3 bcm2835_codec,bcm2835_v4l2,bcm2835_isp
videobuf2_dma_contig 24576 3 bcm2835_codec,rpivid_hevc,bcm2835_isp
videobuf2_v4l2 32768 5 bcm2835_codec,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
videobuf2_common 69632 9 bcm2835_codec,videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_v4l2,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,videobuf2_memops,bcm2835_isp
videodev 266240 7 bcm2835_codec,videobuf2_v4l2,bcm2835_v4l2,videobuf2_common,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
vc_sm_cma 36864 2 bcm2835_mmal_vchiq,bcm2835_isp
snd_bcm2835 28672 1
mc 61440 7 videodev,bcm2835_codec,videobuf2_v4l2,videobuf2_common,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
snd_soc_core 249856 2 vc4,snd_soc_hdmi_codec
snd_compress 20480 1 snd_soc_core
snd_pcm_dmaengine 20480 1 snd_soc_core
snd_pcm 139264 5 snd_bcm2835,snd_soc_hdmi_codec,snd_compress,snd_soc_core,snd_pcm_dmaengine
snd_timer 36864 3 snd_seq,snd_hrtimer,snd_pcm
snd 102400 14 snd_seq,snd_seq_device,snd_bcm2835,snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
alsactl info:
mikeb@rpi4 ~]$ alsactl info
# Sound card
- card: 0
name: bcm2835 Headphones
longname: bcm2835 Headphones
mixer_name: Broadcom Mixer
components:
controls_count: 2
pcm:
- stream: PLAYBACK
devices:
- device: 0
id: bcm2835 Headphones
subdevices:
- subdevice: 0
- subdevice: 1
- subdevice: 2
- subdevice: 3
- subdevice: 4
- subdevice: 5
- subdevice: 6
- subdevice: 7
alsactl: rawmidi_device_list:105: snd_ctl_rawmidi_next_device
[mikeb@rpi4 ~]$ alsactl info 1
# Sound card
- card: 1
longname: vc4-hdmi-0
mixer_name:
components:
controls_count: 4
pcm:
- stream: PLAYBACK
devices:
- device: 0
id: MAI PCM i2s-hifi-0
name: MAI PCM i2s-hifi-0
subdevices:
- subdevice: 0
[mikeb@rpi4 ~]$ alsactl info 2
# Sound card
- card: 2
longname: vc4-hdmi-1
mixer_name:
components:
controls_count: 4
pcm:
- stream: PLAYBACK
devices:
- device: 0
subdevices:
- subdevice: 0
Below, I’ve tried tried different combinations of hdmi_group and hdmi_drive, including leaving them out.
/boot/config.txt:
gpu_mem=128
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
dtparam=krnbt=on
display_auto_detect=1
arm_boost=1
over_voltage=6
gpu_freq=700
arm_freq=2000
force_turbo=1
enable_uart=1
#enable sound
dtparam=audio=on
hdmi_group=2
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_splash=1
Below I’ve tried the alsa parameter with 1 and 0.
/boot/cmdline.txt:
root=PARTUUID=da4f6ea3-02 rw rootwait console=serial0,115200 console=tty3 selinux=0 quiet splash plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 usbhid.mousepoll=8 bcm2835.enable_compat_alsa=0 audit=0
Thanks
