Hi,
I installed Manjaro Gnome in May of this year and recently(past few weeks) it seems to be slower to open most programs.
I have no idea how to troubleshoot what is happening, and I fear I am making things worse.
I hope someone points me to the right direction on figuring out those problems. Worst case scenario I will have to install the SO again.
Thank you very much!
Details:
Most programs are taking less than 1 minute to open, but they used to be almost instantaneous.
And they act kind of weird, for example the terminal: it “opens” fast, but it takes a while to show the “fish” welcome message and to allow me to type.
The worst program seems to be Steam, it takes 5~10 minutes to open. I tried to follow the troubleshoot for AUR, and stuff I found here in the forum like:
steam-runtime --reset
deleting steam cache
disabling hardware acceleration.
removing everything than installing different packages
But nothing works and now I get a bunch of new messages when opening steam
- Pins potentially out-of-date.
- Forcing building of pins
And it also forgets my user.
When I try to run steam, top shows:
- 90% ~ 94% idle
- steam uses ~100MB of memory, 0% CPU and write ~15MB to disk.
- the only changes in usage are:
- if I alt+tab +10% usage of CPU.
- if I resize terminal xorg and gnome-shell go crazy
The computer has 32GB of RAM, CPU AMD Ryzen 2700
Storage is in either a nvme or sata ssd.
In 1TB nvme:
- SWAP 34GB
- /boot 524 MB ext4
- /boot/efi 524MB fat
- / 419GB ext4
- /home 569BG btrfs
I tried kernels 5.7.19 , 5.8.18 and 5.9.
inxi -Fxza --no-host
Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: ro root=/dev/nvme1n1p4 initrd=\initramfs-5.9-x86_64.img
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.1
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X470 AORUS GAMING 7 WIFI v: N/A
serial: <filter>
Mobo: Gigabyte model: X470 AORUS GAMING 7 WIFI-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F31 date: 05/06/2019
Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D
L2 cache: 4096 KiB
bogomips: 118438
Speed: 1891 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 1889 2: 1890 3: 2195 4: 2192 5: 2071 6: 2077 7: 4358 8: 2075 9: 2048
10: 1891 11: 1934 12: 1937 13: 4350 14: 1934 15: 2194 16: 2058
disabled, RSB filling
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: ZOTAC
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 0a:00.0
chip ID: 10de:1e07
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce RTX 2080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: NVIDIA TU102 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 0a:00.1 chip ID: 10de:10f7
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 0c:00.3 chip ID: 1022:1457
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus ID: 1-9:4 chip ID: 046d:082d
serial: <filter>
Sound Server: ALSA v: k5.9.8-2-MANJARO
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel port: f000 bus ID: 06:00.0 chip ID: 8086:1539
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: f000
bus ID: 07:00.0 chip ID: 8086:2526
IF: wlp7s0 state: down mac: <filter>
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
bus ID: 1-2:2 chip ID: 8087:0025
Local Storage: total: 6.12 TiB used: 1.07 TiB (17.4%)
ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S11 Pro
size: 1.86 TiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 42A4SANA scheme: GPT
ID-2: /dev/nvme1n1 vendor: HP model: SSD EX920 1TB size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: SVN139B scheme: GPT
ID-3: /dev/sda vendor: A-Data model: SU800 size: 1.86 TiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: S86B
scheme: GPT
ID-4: /dev/sdb vendor: Plextor model: PX-128M6S size: 119.24 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1.03 scheme: GPT
ID-5: /dev/sdc vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
serial: <filter> rev: 2B6Q scheme: GPT
ID-6: /dev/sdd vendor: Crucial model: CT480M500SSD1 size: 447.13 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: MU02 scheme: GPT
ID-1: / raw size: 390.62 GiB size: 383.99 GiB (98.30%)
used: 91.92 GiB (23.9%) fs: ext4 dev: /dev/nvme1n1p4
ID-2: /boot raw size: 500.0 MiB size: 476.2 MiB (95.24%)
used: 237.1 MiB (49.8%) fs: ext4 dev: /dev/nvme1n1p2
ID-3: /home raw size: 530.27 GiB size: 530.27 GiB (100.00%)
used: 89.63 GiB (16.9%) fs: btrfs dev: /dev/nvme1n1p5
ID-1: swap-1 type: partition size: 32.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p1
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 27 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 457 Uptime: 1h 42m Memory: 31.37 GiB used: 6.70 GiB (21.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 7/8/9 clang: 11.0.0
Packages: 1763 pacman: 1755 lib: 474 rpm: 0 flatpak: 4 snap: 4 Shell: fish
v: 3.1.2 running in: gnome-terminal inxi: 3.1.08
