Laptop gir struck in boot screen with this sort of error
/dev/sda1: recovering journal
/dev/sda4 primary superblock features different from backup, check forced.
/dev/sda1: Feature orphan present is set but orphan file is clean. CLEARED.
/dev/sda4: 573917/5767168 files (0.3% non-contiguous), 9063384/23040000 blocks I 19.056384] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
init Not tainted 6.1.38-1-MANJARO #1 of1cdf56f2a49bd5676746fb812ee136a1565433
I 19.165392] Hardware name: Hewlett-Packard HP ProBook 6470b/179C, BIOS 68ICE Ver. F.74 04/15/2019
[ 19.1653821 CPU: 1 PID: 1 Conn:
[ 19.1653951 Call Trace:
19.165398]
L 19.1654011 dump_stack_lul+0x18/0x60
[ 19.1654151 panic+0x11b/0x2ba 19.1654271 ? do_syscall_64+0x6c/0x90
[ 19.1654381 do exit.cold+0x15/0x15 L 19.165447] handle_n_fault+0xdf/0x240
L 19.1654601 do_group_exit+0x31/0x80 [ 19.165469) x64_sys_exit_group+0x18/0x20
I 19.165476) do_syscall_64+0x68/8x90 19.1654823 ? exc_page_fault+0x7c/0x188
I 19.1654921 entry SYSCALL_64_after_hufrane+0x63/0xcd [ 19.165499) RIP: 0833:0x7fb32dc971b5
E 19.165505) Code: 17 88 89 01 48 83 cB ff c3 66 Ze or if 84 00 00 00 00 00 66 90 f3 of le fa ba e7 00 00 00 eb 06 of 1f 44 00 00 г4 89 de of 05 <48> 3d 00 fe ff ff 76
f3 f7 48 89 05 bb 30 01 00 cb e9 66 of 1f 84 E 19.1655091 RSP: 082b:00007fff1de5a3b8 EFLAGS: 00000206 ORIG RAX: 00000000000000c7
L 19.1655161 RAX: ffffffffffffffda RBX: 00007fb32dca0108 RCX: 00007fb32dc971b5
I 19.1655201 RDX: 00000000000000e7 RSI: 00007fff1de59a80 RDI: 000000000000007f
I 19.1655233 RBP: 00007fb32dcaafcf B08: 00007fff1de5a3c8 R09: 0000
I 19.1655263 R10: ffffffffff R11: 0000000000000206 R12: 0000 [ 19.1655291 R13: 0000000000000001 R14: 00007fb32dc47000 R15: 000 02
I 19.165535] </TASK
I 19.1655741 Kernel Offset: 0xb200000 from exffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff) L 19.1917313-I end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
