Hat tatsächlich gefehlt. Allerdings kommt nun eine andere Fehlermeldung:
cura
/usr/lib/python3.10/site-packages/UM/PluginRegistry.py:4: DeprecationWarning: the imp module is deprecated in favour of importlib and slated for removal in Python 3.12; see the module's documentation for alternative uses
import imp
/usr/lib/python3.10/site-packages/UM/Settings/InstanceContainer.py:53: DeprecationWarning: invalid escape sequence '\d'
version_regex = re.compile("\nversion ?= ?(\d+)")
/usr/lib/python3.10/site-packages/UM/Settings/InstanceContainer.py:55: DeprecationWarning: invalid escape sequence '\w'
type_regex = re.compile("\ntype ?= ?(\w+)")
/usr/lib/python3.10/site-packages/UM/VersionUpgradeManager.py:98: DeprecationWarning: invalid escape sequence '\.'
".*\.lock", # Don't upgrade the configuration file lock. It's not persistent.
Fatal Python error: Segmentation fault
Current thread 0x00007ff6744ab740 (most recent call first):
File "/usr/lib/python3.10/site-packages/cura/PrinterOutput/PrinterOutputDevice.py", line 47 in <module>
File "<frozen importlib._bootstrap>", line 241 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 883 in exec_module
File "<frozen importlib._bootstrap>", line 688 in _load_unlocked
File "<frozen importlib._bootstrap>", line 1006 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1027 in _find_and_load
File "/usr/lib/python3.10/site-packages/cura/Settings/GlobalStack.py", line 23 in <module>
File "/usr/lib/python3.10/site-packages/cura/BuildVolume.py", line 30 in <module>
File "/usr/lib/python3.10/site-packages/cura/Arranging/Arrange.py", line 12 in <module>
File "/usr/lib/python3.10/site-packages/cura/CuraApplication.py", line 55 in <module>
File "/usr/bin/cura", line 190 in <module>
Extension modules: PyQt5.QtCore, PyQt5.QtNetwork, PyQt5.QtGui, PyQt5.QtWidgets, numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, scipy._lib._ccallback_c, scipy.sparse._sparsetools, _csparsetools, scipy.sparse._csparsetools, scipy.sparse.linalg._isolve._iterative, scipy.linalg._fblas, scipy.linalg._flapack, scipy.linalg._cythonized_array_utils, scipy.linalg._flinalg, scipy.linalg._solve_toeplitz, scipy.linalg._matfuncs_sqrtm_triu, scipy.linalg.cython_lapack, scipy.linalg.cython_blas, scipy.linalg._matfuncs_expm, scipy.linalg._decomp_update, scipy.sparse.linalg._dsolve._superlu, scipy.sparse.linalg._eigen.arpack._arpack, scipy.sparse.csgraph._tools, scipy.sparse.csgraph._shortest_path, scipy.sparse.csgraph._traversal, scipy.sparse.csgraph._min_spanning_tree, scipy.sparse.csgraph._flow, scipy.sparse.csgraph._matching, scipy.sparse.csgraph._reordering, scipy.spatial._ckdtree, scipy._lib.messagestream, scipy.spatial._qhull, scipy.spatial._voronoi, scipy.spatial._distance_wrap, scipy.spatial._hausdorff, scipy.special._ufuncs_cxx, scipy.special._ufuncs, scipy.special._specfun, scipy.special._comb, scipy.special._ellip_harm_2, scipy.spatial.transform._rotation, PyQt6.QtCore, PyQt6.QtGui, PyQt6.QtOpenGL, PyQt6.QtWidgets, PyQt6.QtNetwork, PyQt6.QtQml, PyQt5.QtQml, PyQt6.QtQuick, pyArcus, PyQt6.QtSvg, pyclipper._pyclipper (total: 64)
Speicherzugriffsfehler (Speicherabzug geschrieben)
