Running Manjaro Gnome.
This is very basic, I am sure. But could not figure out a solution.
I have installed TiddlyDesktop. Its executable, nw
resides in ~/td
. In ~/.local/share/applications
there is a TiddlyDesktop.desktop file that contains:
[Desktop Entry]
Name=TiddlyWiki Desktop
Comment=
Keywords=
Exec=/home/user/td/nw
TryExec=
Terminal=false
Icon=TiddlyDesktop
Type=Application
Categories=
MimeType=
StartupNotify=false
StartupWMClass=
OnlyShowIn=
Actions=
But still, there is no trace of TiddlyDesktop as I hit Super
key and start entering the name.
How do I get that functionality?
Restart the gnome shell (Alt +F2 then type r
and press Enter )
Or just log out and log back in
Usually that happens if âExecâ points to a non executable and/or the executable doesnât exist.
I would also remove entries that are left blank and not mandatory, such as âOnlyShowInâ.
Try changing it to Exec=/bin/true
Then running: update-desktop-database
See if it shows up in the menu now.
@winnie Thanks. That worked. I removed all âemptyâ entries and now it works as expected.
system
Closed
28 August 2021 19:03
5
