Hey there, I use Latte Dock on Manjaro KDE and I have this problem:
Error: 1 layout has reported 1 error that you need to repair.(I18N_GAPS_IN_PLACEHOLDER_SEQUENCE)(I18N_EXCESS_ARGUMENTS_SUPPLIED)
What should I do to fix this?
As Latte updates, sometimes it’s easier just to delete outdated layouts… Certainly I learned before I play with a layout, or change anything, I open ‘latte’ from the menu and back up the layout I’m using.
First I had issues with the Git, so I have a GIT layout, and when I reinstalled the repo version I built it again as a ‘NoGit’ version - I pretty much gave up trying to fixing one’s with errors, as I’d already moved on and rarely use alternatives.
If you want to try something better have a go with this…
[ActionPlugins][1]
RightButton;NoModifier=org.kde.latte.contextmenu
[Containments][12]
activityId=
byPassWM=false
dockWindowBehavior=true
enableKWinEdges=true
formfactor=3
immutability=1
isPreferredForShortcuts=false
lastScreen=-1
layoutId=
location=5
name=
onPrimary=true
plugin=org.kde.latte.containment
raiseOnActivityChange=false
raiseOnDesktopChange=false
settingsComplexity=4
timerHide=700
timerShow=200
viewType=0
visibility=2
wallpaperplugin=org.kde.image
[Containments][12][Applets][126]
immutability=1
plugin=com.pajuelo.plasmaConfSaver
[Containments][12][Applets][126][Configuration]
PreloadWeight=0
[Containments][12][Applets][40]
immutability=1
plugin=org.kde.latte.plasmoid
[Containments][12][Applets][40][Configuration]
PreloadWeight=0
[Containments][12][Applets][40][Configuration][General]
hoverAction=PreviewWindows
infoBadgeProminentColorEnabled=true
isInLatteDock=true
launchers59=applications:wine-LINE.desktop,applications:webapp-Sonarr7844.desktop
scrollTasksEnabled=true
showOnlyCurrentActivity=false
showWindowActions=true
[Containments][12][Applets][41]
immutability=1
plugin=org.kde.latte.spacer
[Containments][12][Applets][41][Configuration]
PreloadWeight=0
[Containments][12][Applets][41][Configuration][ConfigDialog]
DialogHeight=540
DialogWidth=720
[Containments][12][Applets][41][Configuration][General]
containmentType=Latte
lengthPercentage=60
lengthType=Percentage
[Containments][12][Applets][42]
immutability=1
plugin=org.kde.plasma.systemtray
[Containments][12][Applets][42][Configuration]
PreloadWeight=84
SystrayContainmentId=13
[Containments][12][ConfigDialog]
DialogHeight=1018
DialogWidth=539
[Containments][12][Configuration]
PreloadWeight=0
[Containments][12][General]
advanced=false
alignment=4
alignmentUpgraded=true
appletOrder=40;41;42;126
backgroundRadius=24
backgroundShadowSize=9
iconSize=24
inConfigureAppletsMode=true
maxLength=80
panelPosition=Bottom
panelSize=100
panelTransparency=62
plasmaBackgroundForPopups=true
shadowColorType=Theme
shadowOpacity=60
shadowSize=45
shadows=All
shadowsUpgraded=true
showGlow=false
tasksUpgraded=true
thickMargin=8
zoomLevel=0
[Containments][12][Indicator]
customType=
enabled=true
enabledForApplets=true
padding=0.07999999821186066
type=org.kde.latte.default
[Containments][12][Indicator][org.kde.latte.default][General]
extraDotOnActive=true
[Containments][13]
PreloadWeight=0
activityId=
formfactor=3
immutability=1
lastScreen=-1
layoutId=
location=5
plugin=org.kde.plasma.private.systemtray
[Containments][13][Applets][130]
immutability=1
plugin=org.kde.plasma.manage-inputmethod
[Containments][13][Applets][130][Configuration]
PreloadWeight=0
[Containments][13][Applets][132]
immutability=1
plugin=org.kde.plasma.mediacontroller_plus
[Containments][13][Applets][132][Configuration]
PreloadWeight=0
[Containments][13][Applets][43]
immutability=1
plugin=org.kde.plasma.battery
[Containments][13][Applets][43][Configuration]
PreloadWeight=0
[Containments][13][Applets][44]
immutability=1
plugin=org.kde.plasma.volume
[Containments][13][Applets][44][Configuration]
PreloadWeight=52
[Containments][13][Applets][44][Configuration][ConfigDialog]
DialogHeight=558
DialogWidth=720
[Containments][13][Applets][44][Configuration][General]
currentTab=streams
[Containments][13][Applets][45]
immutability=1
plugin=org.kde.plasma.printmanager
[Containments][13][Applets][45][Configuration]
PreloadWeight=0
[Containments][13][Applets][47]
immutability=1
plugin=org.kde.plasma.notifications
[Containments][13][Applets][47][Configuration]
PreloadWeight=0
[Containments][13][Applets][48]
immutability=1
plugin=org.kde.plasma.keyboardindicator
[Containments][13][Applets][48][Configuration]
PreloadWeight=0
[Containments][13][Applets][49]
immutability=1
plugin=org.kde.plasma.networkmanagement
[Containments][13][Applets][49][Configuration]
PreloadWeight=0
[Containments][13][Applets][51]
immutability=1
plugin=org.kde.plasma.devicenotifier
[Containments][13][Applets][51][Configuration]
PreloadWeight=0
[Containments][13][Applets][52]
immutability=1
plugin=org.kde.plasma.nightcolorcontrol
[Containments][13][Applets][52][Configuration]
PreloadWeight=0
[Containments][13][Applets][53]
immutability=1
plugin=org.kde.plasma.clipboard
[Containments][13][Applets][53][Configuration]
PreloadWeight=0
[Containments][13][Applets][61]
immutability=1
plugin=org.kde.plasma.keyboardlayout
[Containments][13][Applets][61][Configuration]
PreloadWeight=0
[Containments][13][Applets][61][Configuration][ConfigDialog]
DialogHeight=558
DialogWidth=720
[Containments][13][Applets][61][Configuration][General]
showFlag=true
[Containments][13][Applets][61][Shortcuts]
global=
[Containments][13][ConfigDialog]
DialogHeight=833
DialogWidth=1105
[Containments][13][General]
extraItems=org.kde.plasma.nightcolorcontrol,org.kde.plasma.battery,org.kde.plasma.notifications,org.kde.plasma.networkmanagement,org.kde.plasma.devicenotifier,org.kde.plasma.volume,org.kde.plasma.keyboardlayout,org.kde.plasma.clipboard,org.kde.plasma.printmanager,org.kde.plasma.keyboardindicator,org.kde.plasma.mediacontroller_plus,org.kde.plasma.manage-inputmethod
hiddenItems=org.kde.plasma.battery,org.kde.plasma.clipboard
knownItems=org.kde.plasma.volumewin7mixer,org.kde.plasma.mediacontroller_plus,org.kde.plasma.nightcolorcontrol,org.kde.plasma.battery,org.kde.plasma.notifications,org.kde.plasma.networkmanagement,org.kde.plasma.devicenotifier,org.kde.plasma.bluetooth,org.kde.plasma.volume,org.kde.plasma.keyboardlayout,org.kde.kdeconnect,org.kde.ktp-contactlist,org.kde.plasma.clipboard,org.kde.plasma.printmanager,org.kde.plasma.keyboardindicator,org.kde.plasma.mediacontroller,org.kde.plasma.manage-inputmethod
scaleIconsToFit=true
[Containments][14]
activityId=
byPassWM=false
formfactor=2
immutability=1
lastScreen=-1
layoutId=
location=3
name=
onPrimary=true
timerHide=700
timerShow=0
viewType=0
visibility=2
[Containments][14][Applets][127]
immutability=1
plugin=org.kde.plasma.eventcalendar
[Containments][14][Applets][127][Configuration]
PreloadWeight=29
[Containments][14][Applets][127][Configuration][Agenda]
agendaEventSpacing=6
agendaFontSize=14
agendaInProgressColor=#c0ff37
agendaWeatherShowIcon=false
[Containments][14][Applets][127][Configuration][Calendar]
monthCellRadius=0.22432432432432434
monthEventBadgeType=bottomBar
[Containments][14][Applets][127][Configuration][ConfigDialog]
DialogHeight=926
DialogWidth=834
[Containments][14][Applets][127][Configuration][Events]
eventStartingSfxPath=file:///home/ben/Sounds/School Handbell.wav
[Containments][14][Applets][127][Configuration][General]
clockFontFamily=Arial Rounded MT Bold
clockLine2HeightRatio=0.44
clockMaxHeight=25
clockTimeFormat1='<font color="#8cc74d">'HH:mm'</font>'\s
leftColumnWidth=200
pin=true
rightColumnWidth=200
v71Migration=true
v72Migration=true
widgetShowCalendar=false
widgetShowMeteogram=false
widgetShowTimer=false
[Containments][14][Applets][127][Configuration][Google Calendar]
accessToken=ya29.A0ARrdaM87zulgX6D5FmFrXgmhBCihA5FP_NqHQRyYiCqyOtiKumV5-7YdlyBGLjzhF6MKRmGaqhfqK7eqjj1bti2Jl60578qS19znWG3ADYpwwG63N5h7q3RfNshTTfvKVkl0c1WLpyDCP_waC-AMg4ZuhdgFvFQ
accessTokenExpiresAt=1672423857
accessTokenType=Bearer
calendarIdList=ben2talk@gmail.com,family10075762188398543217@group.calendar.google.com,en-gb.th#holiday@group.v.calendar.google.com,mailto.rattanaporn@gmail.com,c_classroomde844738@group.calendar.google.com,p#weather@group.v.calendar.google.com
calendarList=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
refreshToken=1//0gcD5l3DPDRpnCgYIARAAGBASNwF-L9Irtl5DEw1sGEj2TYPpWyjgnUM1WkquvTITMC20Uxu1y7GPFpQAjS3w4uZ_MlJkhs-aQqw
sessionClientId=391436299960-k0s16nm589meovhoblpcquqgbbrena17.apps.googleusercontent.com
sessionClientSecret=Gdr_7lKIQuGBD4Up3MOiw-7i
tasklistIdList=MDgyNjc5MTg0MjU0NTk1NTU3OTc6MDow
tasklistList=W3sia2luZCI6InRhc2tzI3Rhc2tMaXN0IiwiaWQiOiJNRGd5TmpjNU1UZzBNalUwTlRrMU5UVTNPVGM2TURvdyIsImV0YWciOiJcIkxURTRNRFU1T1RJek1EUVwiIiwidGl0bGUiOiJCZW4ydGFsaydzIGxpc3QiLCJ1cGRhdGVkIjoiMjAyMC0xMi0yNFQxMDo0NTo0My44MTVaIiwic2VsZkxpbmsiOiJodHRwczovL3d3dy5nb29nbGVhcGlzLmNvbS90YXNrcy92MS91c2Vycy9AbWUvbGlzdHMvTURneU5qYzVNVGcwTWpVME5UazFOVFUzT1RjNk1Eb3cifV0=
[Containments][14][Applets][127][Shortcuts]
global=Alt+P
[Containments][14][Applets][131]
immutability=1
plugin=org.kde.plasma.icon
[Containments][14][Applets][131][Configuration]
PreloadWeight=0
localPath=/home/ben/.local/share/plasma_icons/refresh.sh.desktop
url=file:///home/ben/Dropbox/Admin/refresh.sh
[Containments][14][Applets][54]
immutability=1
[Containments][14][Applets][54][Configuration]
PreloadWeight=0
[Containments][14][Applets][54][Configuration][Agenda]
agendaDaySpacing=40
agendaFontSize=14
agendaInProgressColor=#d75dff5d
agendaShowEventHangoutLink=false
[Containments][14][Applets][54][Configuration][Calendar]
firstDayOfWeek=1
monthCellRadius=0.13783783783783785
monthCurrentCustomTitleFormat=dd MMMM yyyy
monthHeightSingleColumn=350
[Containments][14][Applets][54][Configuration][ConfigDialog]
DialogHeight=886
DialogWidth=1011
[Containments][14][Applets][54][Configuration][Events]
enabledCalendarPlugins=holidaysevents.so,astronomicalevents.so
[Containments][14][Applets][54][Configuration][General]
bottomRowHeight=500
clockFontFamily=Varela Round
clockMaxHeight=18
clockTimeFormat1='<font color="#d5c4a1">'ddd d MMM'</font>'
leftColumnWidth=600
pin=true
timerSfxFilepath=file:///home/ben/reminder3.wav
v71Migration=true
v72Migration=true
widgetShowAgenda=false
[Containments][14][Applets][54][Configuration][Google Calendar]
accessToken=ya29.A0ARrdaM8khr01knwjeC6TnolZDtXZy0ZEzwDNHUBioNTBvc1o_xlfUpdTjtJsehDhgiVFO5qMNW89c2sUYcv1RR9IwxLfu-VBjqHkHhfKLwceSJbQvXEvuJvGtouXrsCHPKAU4_krfV2HrcG-aHUVqed_1-d9MJk
accessTokenExpiresAt=1672423909
calendarIdList=ben2talk@gmail.com,mailto.rattanaporn@gmail.com
calendarList=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
refreshToken=1//0grGafLZEsbphCgYIARAAGBASNwF-L9IreBzl5SESmaKJeZjrzxQIk7i07fOAvsEH1a0mEl3F0pHJt-v36RQbopGIar-1nV6oolk
[Containments][14][Applets][54][Configuration][Weather]
meteogramHours=12
openWeatherMapCityId=1609348
[Containments][14][Applets][54][Shortcuts]
global=
[Containments][14][ConfigDialog]
DialogHeight=976
DialogWidth=539
[Containments][14][Configuration]
PreloadWeight=0
[Containments][14][General]
alignment=2
appletOrder=127;131;54
backgroundRadius=37
backgroundShadowSize=5
iconSize=28
maxLength=60
offset=1
panelPosition=10
panelSize=100
panelTransparency=75
solidBackgroundForMaximized=true
splitterPosition=1
splitterPosition2=2
tasksUpgraded=true
thickMargin=7
zoomLevel=0
[Containments][14][Indicator]
customType=
enabled=true
[Containments][15]
activityId=
byPassWM=false
formfactor=2
immutability=1
lastScreen=-1
layoutId=
location=3
maxLength=100
name=Default Dock
onPrimary=true
timerHide=700
timerShow=200
viewType=0
visibility=2
[Containments][15][Applets][122]
immutability=1
plugin=org.kde.plasma.appmenu
[Containments][15][Applets][122][Configuration]
PreloadWeight=0
[Containments][15][Applets][122][Configuration][ConfigDialog]
DialogHeight=540
DialogWidth=720
[Containments][15][Applets][123]
immutability=1
plugin=org.kde.plasma.kickoff
[Containments][15][Applets][123][Configuration]
PreloadWeight=100
[Containments][15][Applets][123][Configuration][ConfigDialog]
DialogHeight=558
DialogWidth=720
[Containments][15][Applets][123][Configuration][General]
favoritesPortedToKAstats=true
icon=application-menu
systemFavorites=suspend\\,hibernate\\,reboot\\,shutdown
[Containments][15][Applets][123][Shortcuts]
global=Alt+F1
[Containments][15][Applets][124]
immutability=1
plugin=org.communia.apptitle
[Containments][15][Applets][124][Configuration]
PreloadWeight=0
[Containments][15][Applets][124][Configuration][ConfigDialog]
DialogHeight=558
DialogWidth=720
[Containments][15][Applets][124][Configuration][General]
bold=true
showApplicationIcon=true
textType=1
[Containments][15][ConfigDialog]
DialogHeight=600
DialogWidth=586
[Containments][15][Configuration]
PreloadWeight=0
[Containments][15][General]
advanced=false
alignment=1
appletOrder=123;124;122
backgroundRadius=21
backgroundShadowSize=3
iconSize=24
lockedZoomApplets=122
maxLength=50
panelSize=100
panelTransparency=65
shadowOpacity=60
shadows=All
showGlow=false
tasksUpgraded=true
thickMargin=8
titleTooltips=false
zoomLevel=0
[Containments][15][Indicator]
customType=
enabled=true
[LayoutSettings]
background=
backgroundStyle=0
color=blue
customBackground=
customTextColor=
icon=
lastUsedActivity=5a152156-6256-4e7d-93ef-e59e12e65c3b
launchers=
popUpMargin=-1
preferredForShortcutsTouched=false
schemeFile=
showInMenu=true
textColor=fcfcfc
version=2
How did you manage to do it with these sources? I did the opposite of what you did by switching from repo to git version and still had no luck. Anyway, did you manage the scripts via terminal? If so, what command did you use to edit them?
Did you use nano to edit? If so, what command?
No, I never edit them directly - the files are in your .config/latte
folder, it’s easy to copy to a new file to see if it works.
I can’t seem to find that directory.
What did you name this layout or whatever?
Latte-NoGit
This is my current default - has vertical bar at bottom left, containing configsaver, systray, tasks - then a short bar near the top right corner, horizontal (hides on FS windows) with 2 instances of Event Calendar (one for calendar, shows Day/date the other for Clock, showing only schedule).
The icon between clock and date is a shortcut to a script which cleans up Wine (for when I’m running LINE and can’t easily close it)
wineserver -k
latte-dock -r
I don’t really ‘use’ it much - I never click to open menu’s, and usually do a mouse gesture to pull up windows (Ctrl+F10 for ‘Present Windows’ is mapped to a gesture, as is ‘present desktops’).
So when you’re at keyboard, you drive with Keyboard shortcuts, then when on mouse, you use that - not doing all that difficult moving of the mouse to target and click icons and menu’s
The tasks are only there as a visual cue to what’s there - so it’s quite small.
