I’ve installed Latte, rebooted. I’ve started latte from the menu but nothing shows on the desktop
I can see it in my processes
1328 ? Sl 0:01 /usr/bin/latte-dock
These are the contents of lattedockrc in .config
[PlasmaThemeExtended]
outlineWidth=1
[ScreenConnectors]
10=HDMI-0
11=VGA-0
[UniversalSettings]
badges3DStyle=false
canDisableBorders=false
currentLayout=
downloadWindowSize=800,550
lastNonAssignedLayout=
launchers=
layoutsColumnWidths=
layoutsWindowSize=700,450
memoryUsage=0
metaPressAndHoldEnabled=true
mouseSensitivity=2
screenTrackerInterval=2500
showInfoWindow=true
version=1
What is amiss?
nunonun
January 21, 2022, 12:29am
#2
I am currently facing the same problem on a fresh installation of Manjaro KDE.
My Latte Dock’s layout is in .config/latte/
and it is not empty, containing all the launchers I’ve put in the dock.
There are several strange things happening:
I can right click on the bottom of the screen and have access to Latte’s menu;
If I select WhiteSur layout, the dock shows up, with the launchers pre-defined in this layout;
However, if I change back to my layout, the dock disappears again - its menu is still accessible via a right-click;
If I create a new layout, it shows up; I add all the launchers I want, but when I restart the computer, the problem persists, i.e. , the layouts I created are not visible anymore.
Does anybody know why is this happening?
My configuration:
❯ inxi -Fazy
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=ca0b13f1-3220-4bc9-9dc7-77d2311111e0 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 4180Q3U v: ThinkPad T420
Mobo: LENOVO model: 4180Q3U serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 83ET82WW (1.52 ) date: 06/04/2018
ID-1: BAT0 charge: 14.1 Wh (95.9%) condition: 14.7/56.2 Wh (26.1%)
volts: 12.3 min: 10.8 model: SANYO 45N1001 type: Li-ion serial: <filter>
status: N/A
Info: model: Intel Core i7-2640M bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3290 high: 3475 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3111 2: 3475 3: 3288
4: 3289 bogomips: 22338
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo ThinkPad T420 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0126 class-ID: 0300
Device-2: Chicony integrated camera type: USB driver: uvcvideo
bus-ID: 1-1.6:6 chip-ID: 04f2:b221 class-ID: 0e02
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
IF-ID-1: wwp0s29u1u4i6 state: down mac: <filter>
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 208.05 GiB (14.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
type: HDD rpm: 5400 serial: <filter> rev: A7G0 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 20.56 GiB (20.6%)
fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 71.9 MiB (14.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 365.26 GiB size: 365.26 GiB (100.00%)
used: 187.42 GiB (51.3%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 20.56 GiB (20.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 93.0 C mobo: N/A
Fan Speeds (RPM): cpu: 4544
Processes: 282 Uptime: 8m wakeups: 2 Memory: 15.41 GiB
used: 3.51 GiB (22.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1696 lib: 372 flatpak: 0
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
nunonun
January 21, 2022, 12:31am
#3
I think I found the problem! It has to do with the “Windows Can Cover” option. Selecting another option for visibility makes the dock visible again.
I’ll try to report this issue to the developers.
@psionman , have you sorted it out? Did you find the same thing?
