Hello,
I’m having persistent problems with programs, seemingly randomly, crashing when I save or open files.
When I save an Inkscape file, it occasionally becomes unresponsive and has to be killed. Likewise, when adding a folder to Atom, the same problem occurs, and has to be killed. I’ve been using Firefox and downloading files does the same thing.
journalctl -f
does not log anything.
Here’s inxi -Fazy:
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e3142dad-e257-46d6-835b-733a9073fd46 rw quiet apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-K v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 3202 date: 06/15/2021
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 92446
Speed: 1376 MHz min/max: 1550/3850 MHz boost: disabled Core speeds (MHz):
1: 1376 2: 1378 3: 1378 4: 1374 5: 1376 6: 1377 7: 1377 8: 1377 9: 1377
10: 1374 11: 1373 12: 1375
disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK PH-GTX1050TI-4G
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1c82 class-ID: 0300
Device-2: MacroSilicon USB Video type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 3-1.2:5
chip-ID: 534d:2109 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: MacroSilicon USB Video type: USB
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel modules: r8168
port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: uk-london5 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-3:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 5.46 TiB used: 614.48 GiB (11.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM005-2CW102
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: BUP Slim RD
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0304 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Seagate model: BUP Slim BK
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 22.8 GiB (23.3%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc3 maj-min: 8:35
ID-3: /home raw-size: 100 GiB size: 97.87 GiB (97.87%)
used: 18.97 GiB (19.4%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc4 maj-min: 8:36
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 298 Uptime: 5h 27m wakeups: 0 Memory: 15.6 GiB
used: 2.6 GiB (16.7%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10 Packages: pacman: 1331 lib: 346 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
Thanks.
