I’m running the latest version of XCFE. When I try to boot with Kernel 5.10, I get an error message that LightDM won’t start.
Everything works properly if I drop back to the 5.4 LTS Kernel.
Any guidance would be greatly appreciated!
2 possibilities:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
