After some time has elapsed, at random, the second language input just stops working. If I need to change language, I have to restart i3 in place. Sometimes I might need to restart i3 in place multiple times until the language switcher responds and starts functioning again. How can I troubleshoot this?
@kosa
I’m sure that your locale.gen is ok. With me as an example
grep -v '^#' /etc/locale.gen
pl_PL.UTF-8 UTF-8
en_US.UTF-8 UTF-8
hu_HU.UTF-8 UTF-8
sudo locale-gen has been run
I inserted into ~/.i3/config
exec_always --no-startup-id setxkbmap -layout hu,pl -variant ,qwertz -option grp:ctrl_alt_toggle
Should you need indicator in i3bar use i3blocks in config:
bar {
status_command i3blocks -c ~/.i3/i3blocks.conf
### i3bar_command i3bar
### status_command i3status
position bottom
i3blocks.conf
for keyboard layouts switcher
see i3 config file
this needs xkblayout-state installed from the AUR:
AUR (en) - xkblayout-state-git
[keyboard-layout]
command=~/.i3/scripts/keyboard-layout
interval=2`
keyboard-layout
#!/usr/bin/env bash
KBD=$(/usr/bin/xkblayout-state print ‘%s’)
echo $KBD
btw Endeavouros i3-wm uses i3blocks
$mod+Shift+r (restart) also may help because I’ve encountered similar keyboard toggle problems in Mabox
It is. Here’s mine:
en_US.UTF-8 UTF-8
el_GR.UTF-8 UTF-8
my .i3/config has this in my case:
exec_always setxkbmap -layout us,gr exec_always setxkbmap -option 'grp:shifts_toggle'
I also have tray_output primary
but I don’t have i3blocks. What I have is this:
> # Start i3bar to display a workspace bar (plus the system information i3status if available)
> bar {
> i3bar_command i3bar
> position top
> ## please set your primary output first. Example: 'xrandr --output eDP1 --primary'
> tray_output primary
> # tray_output HDMI-1
> # tray_output eDP1
> bindsym button4 nop
> bindsym button5 nop
> # font xft:URWGothic-Book 11
> strip_workspace_numbers no
> colors {
> background #222D31
> statusline #F9FAF9
> separator #454947
> # border backgr. text
> focused_workspace #F9FAF9 #16a085 #292F34
> active_workspace #595B5B #353836 #FDF6E3
> inactive_workspace #595B5B #222D31 #EEE8D5
> binding_mode #16a085 #2C2C2C #F9FAF9
> urgent_workspace #16a085 #FDF6E3 #E5201D
$mod+Shift+r (restart inplace) does indeed help, but the question remains: why does it have to happen in the first place?
I replaced setxkbmap with yours and was not able to reproduce the error.
I also met this feature. (this reminds me an old programming etude: Check whether the nth character of a string is G and if it is not replace with G – Simpler version overwrite it with G without testing. I would make two shortcuts. )
Edit: Yes, it’s annoying not knowing the reason of failure.
bindcode $mod+50 exec setxkbmap us
bindcode $mod+62 exec setxkbmap gr
the first line is Super+Shift_L
the 2nd is Super+Shift_R
It is working – not relying on toggle state.
