Large icons in top bar and start menu
After the most recent stable update and a restart, all icons in the start menu and top bar have become much larger than normal. The scaling in the display settings is of the same size as normal. How do I restore to the normal state?
[2021-04-10T14:12:20+0530] [ALPM] upgraded matcha-gtk-theme (20210204-1 -> 20210409-2)
Just found this in pamac logs. I think this is what caused it. I will try downgrading.
How do I downgrade this package?
Downgrading packages - Manjaro This does not list the older version nor do I have it in my cache.
Ok, so what I did was go to an old unsynced mirror that had the version I wanted and ran installed that package.
For anyone who wants the older version of the matcha-gtk-theme, here you go: https://drive.google.com/file/d/1t_rGLUPgEBLIrvz_DLej6ph0jYC1xHR_/view?usp=sharing
