The error message after failure is huge so I posted it on pastebin (if that’s ok).
The relevant error message probably:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 19.0M 100 19.0M 0 0 333k 0 0:00:58 0:00:58 --:--:-- 361k
Fetching https://playwright.azureedge.net/builds/driver/next/playwright-1.11.0-next-1620085974000-linux.zip
File "/home/moss/miniconda3/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py", line 280, in <module>
main()
File "/home/moss/miniconda3/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py", line 263, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/home/moss/miniconda3/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py", line 204, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/tmp/pip-build-env-vpxu1rpd/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 221, in build_wheel
return self._build_with_temp_dir(['bdist_wheel'], '.whl',
File "/tmp/pip-build-env-vpxu1rpd/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 207, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-vpxu1rpd/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 150, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 133, in <module>
setup(
File "/tmp/pip-build-env-vpxu1rpd/overlay/lib/python3.8/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/home/moss/miniconda3/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/home/moss/miniconda3/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/home/moss/miniconda3/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "setup.py", line 120, in run
with InWheel(
TypeError: __init__() got an unexpected keyword argument 'ret_self'
ERROR: Failed building wheel for playwright
Failed to build playwright
ERROR: Could not build wheels for playwright which use PEP 517 and cannot be installed directly
==> ERROR: A failure occurred in package().
Aborting...
error making: python-playwright-git
What I am trying to do:
I am trying to run a python script that requires playwright
. If I install it using pip
, when running, it complains a shared library, libicui18n.so.66
, is not found.
$ yay -F libicui18n.so
core/icu 68.2-1 [installed: 69.1-1]
usr/lib/libicui18n.so
community/onlyoffice-desktopeditors 6.1.0-4
opt/onlyoffice/desktopeditors/libicui18n.so
community/synology-drive-client 2.0.3.11102-1
opt/Synology/SynologyDrive/lib/libicui18n.so
multilib/lib32-icu 68.2-1 [installed: 69.1-1]
usr/lib32/libicui18n.so
alerque/zoom-system-qt 5.4.53391.1108-3
opt/zoom/libicui18n.so
So I am guessing I need to build playwrght
myself. That is why I am trying to install python-playwright-git
