So latest update is that this has not fixed the problem.
So I’ve no idea if my laptop hardware is broken, or if I’m messed up my OS somehow.
Given my in-built webcam sometimes does work, and when it does it’s absolutely fine, I struggle to understand how a bad connection or cable could be the cause.
And given I reinstalled Manjaro from scratch with no hitches I don’t see how I could have broken the OS.
For now I’ve run out of options to debug this here.
I am facing a similar issue with a Blue Yeti microphone. It has recently started to reset unexpectedly, sound “pops”. After several resets it goes fully offline. Unplug and insert device does not work. On the other hand, a full system reboot makes the microphone work again. I see notifications like:
(dmesg)
[ 4428.762533] retire_capture_urb: 53 callbacks suppressed
[ 4428.940161] usb 1-1.4: USB disconnect, device number 28
[ 4429.222668] usb 1-1.4: new full-speed USB device number 29 using ehci-pci
(journalctl -xe)
nov 10 12:54:36 pulseaudio[1267]: W: [alsa-source-USB Audio] alsa-util.c: Got POLLNVAL from ALSA
nov 10 12:54:36 gsd-media-keys[1535]: Unable to get default source
(3x) nov 10 12:54:36 gsd-media-keys[1535]: gvc_mixer_card_get_index: assertion ‘GVC_IS_MIXER_CARD (card)’ failed
nov 10 12:54:36 kernel: usb 1-1.4: USB disconnect, device number 32
(3x) nov 10 12:54:36 gnome-shell[1283]: gvc_mixer_card_get_index: assertion ‘GVC_IS_MIXER_CARD (card)’ failed
nov 10 12:54:36 /usr/lib/gdm-x-session[1196]: (II) config/udev: removing device Blue Microphones Yeti Stereo Microphone Consumer Control
nov 10 12:54:36 /usr/lib/gdm-x-session[1196]: () Option “fd” “111”
nov 10 12:54:36 /usr/lib/gdm-x-session[1196]: (II) event15 - Blue Microphones Yeti Stereo Microphone Consumer Control: device removed
nov 10 12:54:36 /usr/lib/gdm-x-session[1196]: (II) UnloadModule: “libinput”
nov 10 12:54:36 /usr/lib/gdm-x-session[1196]: (II) systemd-logind: releasing fd for 13:79
nov 10 12:54:36 kernel: usb 1-1.4: new full-speed USB device number 33 using ehci-pci
(several messages later)
ov 10 12:54:36 mtp-probe[6100]: checking bus 1, device 33: “/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4”
nov 10 12:54:36 mtp-probe[6100]: bus: 1, device: 33 was not an MTP device
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) config/udev: Adding input device Blue Microphones Yeti Stereo Microphone Consumer Control (/dev/input/event15)
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Blue Microphones Yeti Stereo Microphone Consumer Control: Applying InputClass “evdev keyboard catchall”
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Blue Microphones Yeti Stereo Microphone Consumer Control: Applying InputClass “libinput keyboard catchall”
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Blue Microphones Yeti Stereo Microphone Consumer Control: Applying InputClass “system-keyboard”
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) Using input driver ‘libinput’ for ‘Blue Microphones Yeti Stereo Microphone Consumer Control’
nov 10 12:54:37 mtp-probe[6139]: checking bus 1, device 33: “/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4”
nov 10 12:54:37 mtp-probe[6139]: bus: 1, device: 33 was not an MTP device
nov 10 12:54:37 pipewire[2090]: [E][000004609.074811][private.h:241 pw_core_resource_errorv()] resource 0x5588a9f28e40: id:52 seq:893 res:-22 (Invalid argument) msg:"set param>
nov 10 12:54:37 pipewire[2095]: [E][000004609.074862][core.c:71 core_event_error()] core 0x561dfd9a6b70: proxy 0x561dfdc2ee90 id:52: seq:893 res:-22 (Invalid argument) msg:"se>
nov 10 12:54:37 pipewire[2095]: [E][000004609.074869][media-session.c:1799 core_error()] error id:52 seq:893 res:-22 (Invalid argument): set param id:11 (Spa:Enum:ParamId:Port>
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 111 paused 0
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Blue Microphones Yeti Stereo Microphone Consumer Control: always reports core events
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Option “Device” “/dev/input/event15”
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Option “_source” “server/udev”
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) event15 - Blue Microphones Yeti Stereo Microphone Consumer Control: is tagged by udev as: Keyboard
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) event15 - Blue Microphones Yeti Stereo Microphone Consumer Control: device is a keyboard
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) event15 - Blue Microphones Yeti Stereo Microphone Consumer Control: device removed
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Option “config_info” "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:B58E:9E84.0020/input/input75/e>
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: (II) XINPUT: Adding extended input device “Blue Microphones Yeti Stereo Microphone Consumer Control” (type: KEYBOARD, id 14)
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Option “xkb_model” “pc105”
nov 10 12:54:37 /usr/lib/gdm-x-session[1196]: () Option “xkb_layout” “se”
nov 10 12:54:37 rtkit-daemon[996]: Supervising 10 threads of 5 processes of 1 users.
nov 10 12:54:37 mixxx.desktop[2192]: ALSA lib pcm.c:8545:(snd_pcm_recover) underrun occurred
(several messages)
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
nov 10 12:54:37 gnome-shell[1283]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
I’m sorry you’re facing similar issues. People have tried to help me but so far we -the community- have not found a solution for my issue. I hope someone will know how to help you.
my issue is slowly pushing me away from Arch/Manjaro as it’s not a really viable replacement for Windows if it breaks all the time like this. And for the record, I have no desire whatsoever to distro-hop and am still actively trying to figure out a solution to my problem.
If I may, I’d recommend when you’re typing you’re message, you click on the icon and the > hide details, then paste all of that output in there so it’s collapsable. It’ll make it easier to scroll through.
Btw, I only learned of that in the forum tutorial here.
