$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.4.58-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Predator PH315-51 v: V1.26 serial: <filter>
Mobo: CFL model: Sienta_CFS v: V1.26 serial: <filter> UEFI: Insyde v: 1.26
date: 03/27/2019
Battery: ID-1: BAT1 charge: 28.1 Wh condition: 41.0/48.9 Wh (84%) volts: 15.2/15.2
model: LG PABAS0241231 type: Li-ion serial: <filter> status: Discharging
Memory: RAM: total: 7.62 GiB used: 1.28 GiB (16.7%)
CPU: Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake rev: A
L2 cache: 9216 KiB bogomips: 52815
Speed: 1400 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 1400 2: 1400 3: 1403 4: 1401
5: 1400 6: 1401 7: 1400 8: 1400 9: 1400 10: 1400 11: 1401 12: 1400
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1
bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics 630 vendor: Acer Incorporated ALI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: Quanta HD Webcam type: USB driver: uvcvideo bus ID: 1-5:2 chip ID: 0408:a060
serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.5
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.4.58-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlp0s20f3 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000 bus ID: 06:00.1
chip ID: 10ec:8168
IF: enp6s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 1.03 TiB used: 223.81 GiB (21.3%)
ID-1: /dev/sda vendor: SK Hynix model: HFS128G39TND-N210A size: 119.24 GiB speed: 6.0 Gb/s
serial: <filter> rev: 1P10 scheme: GPT
ID-2: /dev/sdb vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A3J0 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 86.76 GiB used: 35.48 GiB (40.9%) fs: ext4 dev: /dev/sda7 label: N/A
uuid: f862f40b-3214-4d99-a3ec-37c5006163a4
ID-2: /boot/efi size: 499.0 MiB used: 316 KiB (0.1%) fs: vfat dev: /dev/sda6 label: N/A
uuid: 3A04-5656
ID-3: /mnt/c94d185c-f75f-453b-bc8b-aff8bc598341 size: 915.89 GiB used: 188.32 GiB (20.6%)
fs: ext4 dev: /dev/sdb1 label: N/A uuid: c94d185c-f75f-453b-bc8b-aff8bc598341
Swap: ID-1: swap-1 type: file size: 8.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: ID-1: /dev/sda1 size: 100.0 MiB fs: vfat label: N/A uuid: 0C8D-CF7C
ID-2: /dev/sda2 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-3: /dev/sda3 size: 29.38 GiB fs: ntfs label: N/A uuid: 4E169E32169E1AD3
ID-4: /dev/sda4 size: 513.0 MiB fs: ntfs label: N/A uuid: 389C237F9C2336B2
ID-5: /dev/sda5 size: 100.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-4:4 info: Logitech G203 Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c084
serial: <filter>
Device-2: 1-5:2 info: Quanta HD Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 0408:a060 serial: <filter>
Device-3: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
Info: Processes: 276 Uptime: 7m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1235
pacman: 1222 flatpak: 10 snap: 3 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
I’m using KDE. For past 2-3 weeks I stopped using touchpad and switched to wired mouse. Now after this time I tried to use touchpad and it has gone laggy. I’m not talking about pointer speed here. It literally feels laggy. If I move my finger from one point to other pointer doesn’t go to corner immidiately (You know what I’m saying right? I can literally see it lagging behind the input, which was not the case earlier.)
I’ve tweaked setting, increased pointer speed but still I can notice the lag. Even the two finger tap doesn’t work.
I’ve cleaned the surface of the touchpad with alcohol (Spirit) and removed the dust fin the gap with blower but got no result.
Can anyone help me out to fix this? Also is there anything we can do to get windows likke gestures features for touchpad?
