I have dual boot and noticed that laptop gets way warmer on Manjaro than on Windows 10.
I looked around and tried to tweak things.
I switched off turbo boost.
Switched off balooctl.
Installed thermald.
And yet after I turn on my laptop I’m still getting 55-60 degree temperatures.
paste <(cat /sys/class/thermal/thermal_zone*/type) <(cat /sys/class/thermal/thermal_zone*/temp) | column -s $'\t' -t | sed 's/...$/.0°C/'
INT3400 Thermal 20.0°C
SEN1 47.0°C
SEN2 47.0°C
SEN3 47.0°C
pch_cannonlake 55.0°C
B0D4 53.0°C
x86_pkg_temp 53.0°C
iwlwifi_1 60.0°C
PCH seems to be common issue, I’m not so sure about iwlwifi. d
I have only browser open right now and the back of my laptop is hot.
This doesn’t happen, or at least I never noticed it, on Windows 10 unless I game.
I have integrated and NVIDIA 1550ti, via Optimus I set NVIDIA as default.
heavenhaeven:
iwlwifi_1 60.0°C
That’s your WiFi chip. Something is wrong if it’s hotter than your CPU. Are your fans working? Maybe it’s time to clean out the dust bunnies.
Well, I tried to blow some dust away, but it didn’t look too bad, I can feel the fans at 55-60 degrees, though I don’t hear them. It’s just that it doesn’t overheat on Windows with the same hardware.
heavenhaeven:
hardware
Which is? Please post your system info as outlined here:
Welcome to Manjaro!
To allow all of us helpful gurus on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone probably linked you to this tutorial, so if you’re reading this in response to a question, please click the green link above this text to bring you to the full and unabridged text of the tutorial…
Sure.
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=29deaf49-34de-4405-862c-b7c9df170718 ro quiet apparmor=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH
serial: <filter> Chassis: type: 10 v: Lenovo Legion Y530-15ICH
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: 8JCN44WW date: 08/13/2018
ID-1: BAT0 charge: 43.2 Wh (98.0%) condition: 44.1/52.5 Wh (84.1%)
volts: 12.6 min: 11.4 model: CPT-COS L17C3PG1 type: Li-poly serial: <filter>
status: Unknown
RAM: total: 15.51 GiB used: 1.88 GiB (12.1%)
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 8 MiB bogomips: 36812
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d
fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:56a6 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: 4000 bus-ID: 07:00.0 chip-ID: 8086:3166 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 08:00.0
IF: enp8s0 state: down mac: <filter>
bus-ID: 1-14:4 chip-ID: 8087:0a2a class-ID: e001
Message: No LVM data was found.
Local Storage: total: 1.36 TiB used: 1.03 TiB (75.4%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: MBR
ID-1: / raw-size: 120.56 GiB size: 118.17 GiB (98.02%)
used: 96.24 GiB (81.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 29deaf49-34de-4405-862c-b7c9df170718
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 0227-CDD9
ID-3: /run/media/ww/9270B63170B61BC3 raw-size: 585.89 GiB
size: 585.89 GiB (100.00%) used: 545.32 GiB (93.1%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 9270B63170B61BC3
ID-4: /run/media/ww/A03229043228E0D0 raw-size: 336.59 GiB
size: 336.59 GiB (100.00%) used: 68.14 GiB (20.2%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: A03229043228E0D0
ID-5: /run/media/ww/CEB24C78B24C66D5 raw-size: 344.63 GiB
size: 344.63 GiB (100.00%) used: 343.4 GiB (99.6%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: CEB24C78B24C66D5
ID-6: /run/media/ww/EE5C-6E50 raw-size: 1000 MiB size: 996 MiB (99.60%)
used: 19.7 MiB (2.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: EE5C-6E50
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: d6a68c8b-f4f7-468c-aea3-76e30d93873d
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 507 MiB fs: ntfs label: N/A
uuid: EC128B74128B4316
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-6:3 info: IMC Networks Integrated Camera type: Video
Device-3: 1-14:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 281 Uptime: 3m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1535 pacman: 1528 lib: 488
flatpak: 0 snap: 7 Shell: Bash v: 5.1.0 running-in: yakuake inxi: 3.3.03
heavenhaeven:
Kernel: 5.9.16-1
5.9 is EOL (End Of Life) and has not received any updates since December. Try either the latest stable kernel which is currently 5.11 or an LTS (Long Term Support) kernel like 5.10 or 5.4.
There’s also a BIOS update available.
Thanks a lot. I switched to 11 and updated BIOS, I think it helped.
system
Closed
12 April 2021 00:12
8
