But the easiest thing you can do is to build 5.10-rc4 with Ben’s patches and install it::
- Go to
https://gitlab.manjaro.org/packages/core/linux510
and look around
- Clone the repository with
git clone https://gitlab.manjaro.org/packages/core/linux510.git
- Save the following to
0001.patch
and 0002.patch
0001.patch
To: linux-usb@vger.kernel.org
Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>,
Guenter Roeck <linux@roeck-us.net>,
linux-kernel@vger.kernel.org, Benjamin Berg <bberg@redhat.com>,
Hans de Goede <hdegoede@redhat.com>,
Heikki Krogerus <heikki.krogerus@linux.intel.com>
Subject: [PATCH 1/2] usb: typec: ucsi: acpi: Always decode connector change information
Date: Fri, 9 Oct 2020 16:40:46 +0200
Message-ID: <20201009144047.505957-2-benjamin@sipsolutions.net> (raw)
In-Reply-To: <20201009144047.505957-1-benjamin@sipsolutions.net>
Normal commands may be reporting that a connector has changed. Always
call the usci_connector_change handler and let it take care of
scheduling the work when needed.
Doing this makes the ACPI code path identical to the CCG one.
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Signed-off-by: Benjamin Berg <bberg@redhat.com>
drivers/usb/typec/ucsi/ucsi_acpi.c | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/typec/ucsi/ucsi_acpi.c b/drivers/usb/typec/ucsi/ucsi_acpi.c
index fbfe8f5933af..04976435ad73 100644
--- a/drivers/usb/typec/ucsi/ucsi_acpi.c
+++ b/drivers/usb/typec/ucsi/ucsi_acpi.c
@@ -103,11 +103,12 @@ static void ucsi_acpi_notify(acpi_handle handle, u32 event, void *data)
if (ret)
return;
+ if (UCSI_CCI_CONNECTOR(cci))
+ ucsi_connector_change(ua->ucsi, UCSI_CCI_CONNECTOR(cci));
if (test_bit(COMMAND_PENDING, &ua->flags) &&
cci & (UCSI_CCI_ACK_COMPLETE | UCSI_CCI_COMMAND_COMPLETE))
complete(&ua->complete);
- else if (UCSI_CCI_CONNECTOR(cci))
- ucsi_connector_change(ua->ucsi, UCSI_CCI_CONNECTOR(cci));
static int ucsi_acpi_probe(struct platform_device *pdev)
2.26.2
0002.patch
Subject: [PATCH 2/2] usb: typec: ucsi: Work around PPM losing change information
Date: Fri, 9 Oct 2020 16:40:47 +0200
Message-ID: <20201009144047.505957-3-benjamin@sipsolutions.net> (raw)
Some/many PPMs are simply clearing the change bitfield when a
notification on a port is acknowledge. Unfortunately, doing so means
that any changes between the GET_CONNECTOR_STATUS and ACK_CC_CI commands
is simply lost.
Work around this by re-fetching the connector status afterwards. We can
then infer any changes that we see have happened but that may not be
respresented in the change bitfield.
We end up with the following actions:
1. UCSI_GET_CONNECTOR_STATUS, store result, update unprocessed_changes
2. UCSI_GET_CAM_SUPPORTED, discard result
3. ACK connector change
4. UCSI_GET_CONNECTOR_STATUS, store result
5. Infere lost changes by comparing UCSI_GET_CONNECTOR_STATUS results
6. If PPM reported a new change, then restart in order to ACK
7. Process everything as usual.
The worker is also changed to re-schedule itself if a new change
notification happened while it was running.
Doing this fixes quite commonly occurring issues where e.g. the UCSI
power supply would remain online even thought the ThunderBolt cable was
unplugged.
drivers/usb/typec/ucsi/ucsi.c | 125 ++++++++++++++++++++++++++++------
drivers/usb/typec/ucsi/ucsi.h | 2 +
2 files changed, 107 insertions(+), 20 deletions(-)
diff --git a/drivers/usb/typec/ucsi/ucsi.c b/drivers/usb/typec/ucsi/ucsi.c
index 758b988ac518..fad8680be7ab 100644
--- a/drivers/usb/typec/ucsi/ucsi.c
+++ b/drivers/usb/typec/ucsi/ucsi.c
@@ -53,7 +53,7 @@ static int ucsi_acknowledge_connector_change(struct ucsi *ucsi)
ctrl = UCSI_ACK_CC_CI;
ctrl |= UCSI_ACK_CONNECTOR_CHANGE;
- return ucsi->ops->async_write(ucsi, UCSI_CONTROL, &ctrl, sizeof(ctrl));
+ return ucsi->ops->sync_write(ucsi, UCSI_CONTROL, &ctrl, sizeof(ctrl));
static int ucsi_exec_command(struct ucsi *ucsi, u64 command);
@@ -625,21 +625,113 @@ static void ucsi_handle_connector_change(struct work_struct *work)
struct ucsi_connector *con = container_of(work, struct ucsi_connector,
work);
struct ucsi *ucsi = con->ucsi;
+ struct ucsi_connector_status pre_ack_status;
+ struct ucsi_connector_status post_ack_status;
enum typec_role role;
+ u16 inferred_changes;
+ u16 changed_flags;
u64 command;
int ret;
mutex_lock(&con->lock);
+ * Some/many PPMs have an issue where all fields in the change bitfield
+ * are cleared when an ACK is send. This will causes any change
+ * between GET_CONNECTOR_STATUS and ACK to be lost.
+ * We work around this by re-fetching the connector status afterwards.
+ * We then infer any changes that we see have happened but that may not
+ * be represented in the change bitfield.
+ * Also, even though we don't need to know the currently supported alt
+ * modes, we run the GET_CAM_SUPPORTED command to ensure the PPM does
+ * not get stuck in case it assumes we do.
+ * Always do this, rather than relying on UCSI_CONSTAT_CAM_CHANGE to be
+ * set in the change bitfield.
+ * We end up with the following actions:
+ * 1. UCSI_GET_CONNECTOR_STATUS, store result, update unprocessed_changes
+ * 2. UCSI_GET_CAM_SUPPORTED, discard result
+ * 3. ACK connector change
+ * 4. UCSI_GET_CONNECTOR_STATUS, store result
+ * 5. Infere lost changes by comparing UCSI_GET_CONNECTOR_STATUS results
+ * 6. If PPM reported a new change, then restart in order to ACK
+ * 7. Process everything as usual.
+ * We may end up seeing a change twice, but we can only miss extremely
+ * short transitional changes.
+ /* 1. First UCSI_GET_CONNECTOR_STATUS */
+ command = UCSI_GET_CONNECTOR_STATUS | UCSI_CONNECTOR_NUMBER(con->num);
+ ret = ucsi_send_command(ucsi, command, &pre_ack_status,
+ sizeof(pre_ack_status));
+ if (ret < 0) {
+ dev_err(ucsi->dev, "%s: GET_CONNECTOR_STATUS failed (%d)\n",
+ __func__, ret);
+ goto out_unlock;
+ con->unprocessed_changes |= pre_ack_status.change;
+ /* 2. Run UCSI_GET_CAM_SUPPORTED and discard the result. */
+ command = UCSI_GET_CAM_SUPPORTED;
+ command |= UCSI_CONNECTOR_NUMBER(con->num);
+ ucsi_send_command(con->ucsi, command, NULL, 0);
+ /* 3. ACK connector change */
+ clear_bit(EVENT_PENDING, &ucsi->flags);
+ ret = ucsi_acknowledge_connector_change(ucsi);
+ if (ret) {
+ dev_err(ucsi->dev, "%s: ACK failed (%d)", __func__, ret);
+ goto out_unlock;
+ /* 4. Second UCSI_GET_CONNECTOR_STATUS */
- ret = ucsi_send_command(ucsi, command, &con->status,
- sizeof(con->status));
+ ret = ucsi_send_command(ucsi, command, &post_ack_status,
+ sizeof(post_ack_status));
if (ret < 0) {
__func__, ret);
goto out_unlock;
+ /* 5. Inferre any missing changes */
+ changed_flags = pre_ack_status.flags ^ post_ack_status.flags;
+ inferred_changes = 0;
+ if (UCSI_CONSTAT_PWR_OPMODE(changed_flags) != 0)
+ inferred_changes |= UCSI_CONSTAT_POWER_OPMODE_CHANGE;
+ if (changed_flags & UCSI_CONSTAT_CONNECTED)
+ inferred_changes |= UCSI_CONSTAT_CONNECT_CHANGE;
+ if (changed_flags & UCSI_CONSTAT_PWR_DIR)
+ inferred_changes |= UCSI_CONSTAT_POWER_DIR_CHANGE;
+ if (UCSI_CONSTAT_PARTNER_FLAGS(changed_flags) != 0)
+ inferred_changes |= UCSI_CONSTAT_PARTNER_CHANGE;
+ if (UCSI_CONSTAT_PARTNER_TYPE(changed_flags) != 0)
+ /* Mask out anything that was correctly notified in the later call. */
+ inferred_changes &= ~post_ack_status.change;
+ if (inferred_changes)
+ dev_dbg(ucsi->dev, "%s: Inferred changes that would have been lost: 0x%04x\n",
+ __func__, inferred_changes);
+ con->unprocessed_changes |= inferred_changes;
+ /* 6. If PPM reported a new change, then restart in order to ACK */
+ if (post_ack_status.change)
+ goto out_unlock;
+ /* 7. Continue as if nothing happened */
+ con->status = post_ack_status;
+ con->status.change = con->unprocessed_changes;
+ con->unprocessed_changes = 0;
role = !!(con->status.flags & UCSI_CONSTAT_PWR_DIR);
if (con->status.change & UCSI_CONSTAT_POWER_OPMODE_CHANGE ||
@@ -676,28 +768,19 @@ static void ucsi_handle_connector_change(struct work_struct *work)
ucsi_unregister_partner(con);
- if (con->status.change & UCSI_CONSTAT_CAM_CHANGE) {
- * We don't need to know the currently supported alt modes here.
- * Running GET_CAM_SUPPORTED command just to make sure the PPM
- * does not get stuck in case it assumes we do so.
- command = UCSI_GET_CAM_SUPPORTED;
- command |= UCSI_CONNECTOR_NUMBER(con->num);
- ucsi_send_command(con->ucsi, command, NULL, 0);
if (con->status.change & UCSI_CONSTAT_PARTNER_CHANGE)
ucsi_partner_change(con);
- ret = ucsi_acknowledge_connector_change(ucsi);
- if (ret)
- dev_err(ucsi->dev, "%s: ACK failed (%d)", __func__, ret);
trace_ucsi_connector_change(con->num, &con->status);
out_unlock:
- clear_bit(EVENT_PENDING, &ucsi->flags);
+ if (test_and_clear_bit(EVENT_PENDING, &ucsi->flags)) {
+ schedule_work(&con->work);
+ mutex_unlock(&con->lock);
+ return;
+ clear_bit(EVENT_PROCESSING, &ucsi->flags);
@@ -715,7 +798,9 @@ void ucsi_connector_change(struct ucsi *ucsi, u8 num)
return;
- if (!test_and_set_bit(EVENT_PENDING, &ucsi->flags))
+ set_bit(EVENT_PENDING, &ucsi->flags);
+ if (!test_and_set_bit(EVENT_PROCESSING, &ucsi->flags))
EXPORT_SYMBOL_GPL(ucsi_connector_change);
diff --git a/drivers/usb/typec/ucsi/ucsi.h b/drivers/usb/typec/ucsi/ucsi.h
index cba6f77bea61..543d54a33cb9 100644
--- a/drivers/usb/typec/ucsi/ucsi.h
+++ b/drivers/usb/typec/ucsi/ucsi.h
@@ -296,6 +296,7 @@ struct ucsi {
#define EVENT_PENDING 0
#define COMMAND_PENDING 1
#define ACK_PENDING 2
+#define EVENT_PROCESSING 3
#define UCSI_MAX_SVID 5
@@ -322,6 +323,7 @@ struct ucsi_connector {
struct typec_capability typec_cap;
+ u16 unprocessed_changes;
struct ucsi_connector_status status;
struct ucsi_connector_capability cap;
struct power_supply *psy;
2.26.2
- Edit PKGBUILD adding the these patches filenames right below the section
# ARCH Patches
# ARCH Patches
'0001.patch'
'0002.patch'
- Save PKGBUILD as
PKGBUILD_Ben
- Run
updpkgsums PKGBUILD_Ben
- Run
makepkg -i -p PKGBUILD_Ben
, this will build and install both kernel and kernel headers.
- Reboot to check if it helped.
The same could be done with with 5.9 kernel, I suppose.
