Laptop stopped hibernating
I setup hibernate on my laptop using instructions from a few sources that I combined and saved as my own guide, which is below for reference. Hibernate was working for months until the last couple of days. The system no longer goes into hibernation after 2 hours or manually. When I try to hibernate the system the screen will go dark and after 10-20 seconds the login screen will appear.
2 days ago there was a large system update and after checking the pacman log the kernel updating from 6.18.1-1 to 6.18.4-1 is the only real change I can notice. I have not changed anything manually for a while.
I was able to disable, delete, and then recreate the swap partition and hibernate worked one time. It seems hibernate will work once after a reboot, but after resuming it does not work again.
#instructions used to make hibernation work
sudo su
#Make swapfile, check guide for size https://wiki.manjaro.org/index.php?title=Swap
btrfs filesystem mkswapfile --size 38G --uuid clear /swap/swapfile
#Enable swapfile
swapon /swap/swapfile
#check output
swapon --show
NAME           TYPE SIZE USED PRIO
/swap/swapfile file  38G   0B   -2
#Add swapfile info the fstab
echo /swap/swapfile none swap defaults 0 0 > /etc/fstab
#Set swapfile offset value
btrfs inspect-internal map-swapfile -r /swap/swapfile > /sys/power/resume_offset
#Get the UUID from the partition with the swapfile
blkid
/dev/nvme0n1p2: UUID="6b027c88-6eb9-4ede-8986-d7e790d03cfd"
#Get swapfile offset value, note this can change
37233920
#Add resume=UUID and resume_offset
nano /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT='resume=UUID=6b027c88-6eb9-4ede-8986-d7e790d03cfd resume_offset=37233920
#Regenerate grub
grub-mkconfig -o /boot/grub/grub.cfg
#Add "resume", no quotes to the end of the Hooks= line
nano /etc/mkinitcpio.conf
#Regenerate config
mkinitcpio -P
#Edit sleep config
nano /etc/systemd/sleep.conf
#Uncomment and edit line to MemorySleepMode=deep
#Uncomment and edit line to HibernateDelaySec=2h
#Set swapfile device so resume works without a reboot
lsblk
#Find the MAJ:MIN value for the device with the /swap/swapfile on it
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
nvme0n1     259:0    0 953.9G  0 disk
├─nvme0n1p1 259:1    0   300M  0 part /boot/efi
└─nvme0n1p2 259:2    0 953.6G  0 part /var/cache
                                     /home
                                     /var/log
echo 259:2 > /sys/power/resume
#Use said value in above command
systemctl hibernate
#Test if it works
inxi -zv8
  Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=6b027c88-6eb9-4ede-8986-d7e790d03cfd rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Convertible System: LENOVO product: 83LC v: Yoga 9 2-in-1 14ILL10
    serial: <superuser required> Chassis: type: 31 v: Yoga 9 2-in-1 14ILL10
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76576 WIN
    serial: <superuser required> part-nu: LENOVO_MT_83LC_BU_idea_FM_Yoga 9
    2-in-1 14ILL10 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: Q9CN22WW date: 01/09/2025
  ID-1: BAT0 charge: 28.5 Wh (38.8%) condition: 73.3/75 Wh (97.8%)
    power: 5.3 W volts: 7.62 min: 7.7 model: ATL L24N4PH2 type: Li-poly
    serial: <filter> charging: status: discharging type: standard
    avail: long_life,standard cycles: 13
  System RAM: total: 32 GiB available: 30.86 GiB used: 6.18 GiB (20.0%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 4 GiB speed: 8533 MT/s volts: curr: 0.5 width (bits): data: 16
    total: 16 manufacturer: Micron Technology part-no: N/A serial: <filter>
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: Intel Core Ultra 7 258V bits: 64 type: MCP arch: Lunar Lake
    level: v3 note: check built: 2024+ process: TSMC n3b (3nm) family: 6
    model-id: 0xBD (189) stepping: 1 microcode: 0x125
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 smt: <unsupported> cache:
    L1: 832 KiB desc: d-4x32 KiB, 4x48 KiB; i-8x64 KiB L2: 14 MiB
    desc: 4x2.5 MiB, 1x4 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4700:4800:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 bogomips: 52838
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lam lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg
    wbnoinvd x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Lunar Lake [Intel Arc Graphics 130V / 140V] vendor: Lenovo
    driver: xe v: kernel arch: Xe2 process: TSMC n3 (3nm) built: 2024+ ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:64a0
    class-ID: 0300
  Device-2: Luxvisions Innotech Integrated Camera
    driver: hid-sensor-hub,usbhid,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 30c9:00f7 class-ID: fe01
    serial: <filter>
    alternate: fbdev,vesa dri: iris gpu: xe display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x415a built: 2020 res: mode: 3840x2400
    hz: 60 scale: 200% (2) to: 1920x1200 dpi: 323 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white:
    x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44") diag: 356mm (14")
    ratio: 16:10 modes: 3840x2400
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (LNL)
    device-ID: 8086:64a0 memory: 30.13 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: integrated-gpu
    name: Intel Graphics (LNL) driver: mesa intel v: 25.3.3-arch1.1
    device-ID: 8086:64a0 surfaces: N/A
  Device-1: Intel Lunar Lake-M HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-lnl
    alternate: snd_sof_pci_intel_lnl,snd_hda_intel bus-ID: 00:1f.3
    chip-ID: 8086:a828 class-ID: 0401
  API: ALSA v: k6.18.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel BE201 320MHz driver: iwlwifi v: kernel port: N/A
    bus-ID: 00:14.3 chip-ID: 8086:a840 class-ID: 0280
  Device-1: Intel driver: btintel_pcie v: 0.1 bus-ID: 00:14.7
    chip-ID: 8086:a876 class-ID: 0d11
  Local Storage: total: 953.87 GiB used: 134.08 GiB (14.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN7100S SDFPMSL-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 7611M001 temp: 22.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 134.07 GiB (14.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 6b027c88-6eb9-4ede-8986-d7e790d03cfd
    used: 12.6 MiB (4.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: FDE1-39FB
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-1: swap-1 type: file size: 38 GiB used: 849.7 MiB (2.2%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
  Device-1: 3-4:2 info: Luxvisions Innotech Integrated Camera
    type: video,HID driver: hid-sensor-hub,usbhid,uvcvideo interfaces: 6
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
    chip-ID: 30c9:00f7 class-ID: fe01 serial: <filter>
  Device-2: 3-6:14 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:650c class-ID: ef00 serial: <filter>
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1310 libs: 345 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    8: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    9: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    11: https://linorg.usp.br/manjaro/stable/$repo/$arch
    12: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    13: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    16: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    17: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    19: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    20: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    22: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    24: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    25: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 397
  1: cpu: 5.7% command: firefox pid: 12334 mem: 451.8 MiB (1.4%)
  2: cpu: 1.5% command: firefox pid: 1617 mem: 564.4 MiB (1.7%)
  3: cpu: 0.9% command: plasmashell pid: 1189 mem: 275.0 MiB (0.8%)
  4: cpu: 0.7% command: firefox pid: 2067 mem: 353.4 MiB (1.1%)
  5: cpu: 0.7% command: firefox pid: 12389 mem: 340.8 MiB (1.0%)
  Memory top: 5 of 397
  1: mem: 802.6 MiB (2.5%) command: firefox pid: 2193 cpu: 0.3%
  2: mem: 564.4 MiB (1.7%) command: firefox pid: 1617 cpu: 1.5%
  3: mem: 451.8 MiB (1.4%) command: firefox pid: 12334 cpu: 5.7%
  4: mem: 386.0 MiB (1.2%) command: firefox pid: 1910 cpu: 0.2%
  5: mem: 353.4 MiB (1.1%) command: firefox pid: 2067 cpu: 0.7%
  Processes: 397 Power: uptime: 10h 13m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.33 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
My system is setup similarly to yours but didn’t hibernate prior to the update (well, the log reports it did but it only lasts 1 second before un-hibernating itself). It’s still doing it after the update.
I also can’t find anything in the pacman log for the updates that would change anything for you. Perhaps check your /var/log/pacman.log for any updates that may have changed anything.
I ended up upgrading to the 6.19 kernel and hibernation works fine again. I know it’s listed as experimental, but as my laptop is a secondary device I’m not worried about it.
I believe resume isn’t needed if you have been dealing with your pacnew files. It’s part of the systemd hook. (I don’t use hibernate though, not 100%.)
Also..
Is no-CoW set on this file? (You need it, if you have any snapshots including this. Likely there are other reasons too.)
lsattr -l /swap/swapfile
If you don’t see No_COW, then it’s not set.
(Since we can see it here, also no compression?)
And you can set nocow with:
sudo chattr +C /swap/swapfile
I just followed instructions I found online so I can’t say if any steps like adding resume to mkinitcpio.conf are unneeded.
My swap file does show No_COW, so it must have gotten set somehow.
The udev, usr and resume hooks are unneeded if one uses the systemd hook instead of the udev hook. :backhand_index_pointing_down:
My laptop is still having issues going into hibernate. Typically after a reboot it will hibernate properly at least once, but after that it generally will not hibernate until it’s rebooted again. I tried to research this some more and found the command below to find stuff in a log, but searching using some of the results didn’t
sudo journalctl -b -1 | grep -i "hibernate\|resume\|swap"                                 ✔
[sudo] password for pball:
Feb 14 08:51:30 aurablue systemd-logind[616]: The system will hibernate now!
Feb 14 08:51:31 aurablue systemd[1]: Starting System Hibernate...
Feb 14 08:51:31 aurablue systemd-sleep[22870]: Performing sleep operation 'hibernate'...
Feb 14 08:51:31 aurablue systemd-sleep[22870]: Failed to put system to sleep. System resumed again: Device or resource busy
Feb 14 08:51:31 aurablue systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Feb 14 08:51:31 aurablue systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Feb 14 08:51:31 aurablue systemd[1]: Failed to start System Hibernate.
Feb 14 08:51:31 aurablue systemd[1]: hibernate.target: Job hibernate.target/start failed with result 'dependency'.
Feb 14 08:51:31 aurablue systemd-logind[616]: Operation 'hibernate' finished.
Feb 14 08:51:31 aurablue rtkit-daemon[990]: Resumed scheduling 7 threads.
Feb 14 08:54:03 aurablue kernel: cs42l43-codec cs42l43-codec: Failed to resume for shutters: -16
Feb 14 08:54:03 aurablue systemd[1]: Stopped target Swaps.
Feb 14 08:54:03 aurablue systemd[1]: Deactivating swap /swap/swapfile...
This suggests that you have an active process somewhere that’s preventing hibernation — presumably because said process would be conducting I/O, although that’s only one possibility.
Seems odd this would start happening after a few months of hibernate working perfectly. If I have to reinstall to try and fix this, I’ll probably distro hop a bit to try out other things.
It could be the result of a change brought about by an updated package. :man_shrugging:
The command shows you only lines which contain the terms “hibernate” “resume” and “swap”
Now that you know where to look (the timestamp)
look at the log without that filter
You might find lines pointing to the reason for failing to hibernate.
You can also search the log while it is being displayed.
Just
journalctl -b 1
and then search like one would in less output - using / and then the search term
jump to next occurence with n …
The problem isn’t apparent to me.. It seems like it should work. (It has to be hiding in plain sight!!)
But if you wanted set the swap file up as more of a best practice way for btrfs, and maybe this could potentially fix it at the same time.
There is a slightly better way to put your swap file on a btrfs fie system than throwing it on your root volume. And that is to put the swap file on a dedicated swap subvolume.
And we can make the whole subvolume no-CoW, no-compression, no-checksum for the entire volume. It’s a requirement of the swap file, and it’s just cleaner isolation for your swap.
The Arch wiki says this:
To properly create a swap file on Btrfs, first create a subvolume to store the swap file, as snapshots cannot be created for that subvolume afterwards. For example, create the /swap subvolume:
btrfs subvolume create /swap
Tip: Consider creating the subvolume directly below the top-level subvolume, then mount it to /swap (or any other accessible location).
They do not tell you how, or what options to use, but one key is “directly below the top-level subvolume”.
So you have to mount the top level subvolume to create it there.
sudo mount -o subvol=/ /dev/nvme0n1p2 /mnt
# OR
sudo mount -o subvolid=5 /dev/nvme0n1p2 /mnt
Then you can:
sudo btrfs subvolume create /mnt/swap
Add the swap subvolume entry to fstab, along with disabling CoW and everything else:
/etc/fstab
UUID="6b027c88-6eb9-4ede-8986-d7e790d03cfd" /swap btrfs subvol=swap,defaults,nodatacow,noatime 0 0
As your moving the swap file from your root subvolume to the swap subvolume, it’s just easier to delete and recreate the swap file.
So you can just: sudo rm /swap/swapfile
Then mount the new subvolume:
sudo systemctl daemon-reload
sudo mount /swap
Then just re-create the swap file exactly the way you did before.
And of course, swapon /swap/swapfile or reboot.
If you’re going to create it directly under the top subvolume, then you had better use the correct mount options, i.e. subvol= and subvolid=.
Also note that — as you said — copy-on-write and compression must be disabled for the whole filesystem, which throws away two of the best assets of btrfs, and makes it impossible to efficiently use snapshots.
@Molski Thanks for the improved method. I went and redid the swap setup using that.
Digging into those logs more I did see a bunch of bluetooth things mentioned during the hibernation process. I disabled bluetooth and was able to hibernate and resume successfully a few times in a row. Though I turned BT back on and was able to hibernate and resume multiple times afterwards. So I guess I’ll just monitor things for a bit and see what happens.
I was digging around a little and realised the last update prior to this issue occurring for you @pball changed my system to systemd from udev. Systemd handles hibernation a little differently and many people seem to be having issues with processes not freezing correctly. The Arch wiki seems to explain it quite well and includes workarounds that may be needed, like instructing your system to shutdown rather than powering off.
My issue seems to have been a combination of this and the KDE file indexer baloo not freezing, also relatively common from a search. Disabling baloo since I’m not currently using it anyway and changing the shutdown option above has been working for me this week.
I meant to correct this last week. I did some reading, then forgot I had this draft mostly composed. I’m not sure if you know what this entails, @pball.
I had unknowingly recommended a method that temporarily changes how new files are created on your entire btrfs filesystem.
I’ve been using btrfs for a few years, always playing with it and learning new things. I was actually unaware you couldn’t disable CoW for a specific subvolume.
“You can do files and folders, subvolumes is even easier, right?”
Wrong. Mount options affect the whole file system In Linux of course. And this no-CoW exception only works per inode.
But there’s no need to panic. Everything is fine. The swap isolation is still better than before, and the filesystem itself is not damaged in any way.
If you had made this change, I would just undo it.
Remove nodatacow from your fstab on the swap line.
/etc/fstab
To:
UUID="6b027c88-6eb9-4ede-8986-d7e790d03cfd" /swap btrfs subvol=swap,defaults,noatime 0 0
And to return to btrfs happy land: reboot
Even if you use snapshots, they will be 100% functional again.
I should probably add there is nothing wrong with leaving it as is. But you do lose the ability do live compression, or snapshot. And maybe that’s fine too!
The only quirk is that your fstab will look a bit inconsistent having nodatacow only on the swap subvolume. If you want it to be obvious, I’d copy the nodatacow option to all your subvolumes on that FS.
Or just move the option to the @ subvolume and remove it from the other subvolumes. The @ subvolume gets mounted first, and the others will implicitly inherit the nodatacow option from there.
