It’s a stupid habit of me to use octothorpe prefix to denote a command from output text.
I am so sorry misleading you!
I have corrected it with a $ for regular user and the mistake won’t happen again.
Card name has changed to: alsa_card.pci-0000_00_1f.3
pactl list cards && pacmd dump | grep -v module
Card #0
Driver: module-alsa-card.c
Owner Module: 7
Properties:
alsa.card = "0"
alsa.card_name = "WD19 Dock"
alsa.long_card_name = "Dell-WD15-Dock"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:5.3.4:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3.4/1-5.3.4:1.0/sound/card0"
udev.id = "usb-Generic_USB_Audio_200901010001-00"
device.bus = "usb"
device.vendor.id = "0bda"
device.vendor.name = "Realtek Semiconductor Corp."
device.product.id = "402e"
device.product.name = "USB Audio"
device.serial = "Generic_USB_Audio_200901010001"
device.string = "0"
device.description = "USB Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
Profiles:
HiFi: Default (sinks: 2, sources: 1, priority: 8000, available: yes)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: HiFi
Ports:
[Out] Line: Line Out (type: Line, priority: 200, latency offset: 0 usec, availability unknown)
Part of profile(s): HiFi
[Out] Headphones: Headphones (type: Headphones, priority: 100, latency offset: 0 usec, availability unknown)
[In] Headset: Headset Microphone (type: Headset, priority: 100, latency offset: 0 usec, availability unknown)
Card #1
Owner Module: 8
Properties:
alsa.card = "1"
alsa.long_card_name = "HDA Intel PCH at 0xed518000 irq 172"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card1"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "1"
device.description = "Built-in Audio"
device.icon_name = "audio-card-pci"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 38668, available: yes)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 38733, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
Active Profile: output:analog-stereo
Ports:
analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4+input:analog-stereo
analog-input-headphone-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, availability unknown)
Properties:
analog-input-headset-mic: Headset Microphone (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 2, availability unknown)
Properties:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 2, availability unknown)
Properties:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, available)
Properties:
device.product.name = "LEN LT2223pwC"
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4, output:hdmi-surround71-extra4+input:analog-stereo
### Configuration dump generated at Tue Sep 13 12:04:18 2022
set-sink-volume alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock_1__sink 0x8000
set-sink-mute alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock_1__sink no
suspend-sink alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock_1__sink yes
set-sink-volume alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink 0x3333
set-sink-mute alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink no
suspend-sink alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink yes
set-sink-volume alsa_output.pci-0000_00_1f.3.analog-stereo 0x3852
set-sink-mute alsa_output.pci-0000_00_1f.3.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.analog-stereo yes
set-source-volume alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock_1__sink.monitor 0x10000
set-source-mute alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock_1__sink.monitor no
suspend-source alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock_1__sink.monitor yes
set-source-volume alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink.monitor 0x10000
set-source-mute alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink.monitor no
suspend-source alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink.monitor yes
set-source-volume alsa_input.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__source 0x828f
set-source-mute alsa_input.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__source no
suspend-source alsa_input.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__source yes
set-source-volume alsa_output.pci-0000_00_1f.3.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.analog-stereo.monitor yes
set-card-profile alsa_card.usb-Generic_USB_Audio_200901010001-00 HiFi
set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo
set-default-sink alsa_output.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__sink
set-default-source alsa_input.usb-Generic_USB_Audio_200901010001-00.HiFi__hw_Dock__source
### EOF
pactl set-card-profile alsa_card.pci-0000_00_1f.3 handsfree_head_unit
Failure: No such entity
I am reading this article: Setting a PulseAudio profile on Bluetooth headset connection · Anson VanDoren
You think it’s worth it to apply what the peer advises?
It will take me some time to get it working.
