hello
this is my first post so sorry for possible mistakes!
when laptop is on AC power it would start normally but when laptop is unplugged it will shutdown when i turn it on. i added i915.modeset=1
to kernel parameter and it starts working normally but it again turn off after turning on from suspend and the Xorg.0.log was:
xf86CloseConsole: KDSETMODE failed: Input/output error
so i started messing around with nvidia drivers and now it is not turning on with i915.modeset=1
either. i re-installed manjaro and installed it with non-free drivers and it turned-on normally but my laptop starts hanging so i re-installed it with free drivers now the problem persists.
here is inxi -Gazy
output:
Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nouveau v: kernel bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0302
Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85 driver:
loaded: modesetting unloaded: intel alternate: fbdev,nouveau,nv,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
I had this problem in arch as well before i install manjaro.
