Laptop screen freezing randomly
This happened on windows 10 also. When i do something like uploading or doing apps the screen frozed without any reason. I posted on tomshardware and it say check the event viewer but it happened on linux yesterday so how do i check a event viewer? Or should i boot to windows and wait for it to trigger. What causes this?
Specs:
CPU: AMD A4 6210
GPU: AMD RADEON R3
RAM: 16GB
If it happens in different operating systems I might tend to think its a hardware or other lower level problem like bad BIOS config.
I suppose its possible that some configuration applied in both softwares could be to blame like OS-based under or overclocking.
As to looking in the logs … journalctl is likely at least part of where you might look.
But heres a link for ‘general troubleshooting’;
https://wiki.archlinux.org/title/General_troubleshooting
can you report
inxi -Fza
cpupower frequency-info
here is the inxi i posted previously
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=7d636cc1-cc97-4108-8039-fec5f183efb2 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver avail: budgie-screensaver vt: 7
    dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
    v: 0974120000405F00000620180 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 2268 v: 73.35 serial: <superuser required>
    part-nu: N8H90EA#UUW uuid: <superuser required> UEFI: American Megatrends
    v: F.33 date: 11/21/2014
  ID-1: BAT0 charge: 23.2 Wh (94.3%) condition: 24.6/24.6 Wh (100.0%)
    power: 5.9 W volts: 17.2 min: 14.8 model: Hewlett-Packard Primary
    type: Li-ion serial: N/A status: charging cycles: 221
  System RAM: total: 16 GiB available: 14.57 GiB used: 978.1 MiB (6.6%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom-Slot 1 (left) type: DDR3 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: spec: 1600 MT/s actual: 1333 MT/s volts:
    curr: 2 min: 1.35 max: 2 width (bits): data: 64 total: 64
    manufacturer: Hynix part-no: HMT41GS6DFR8A-PB serial: <filter>
  Device-2: Bottom-Slot 2 (right) type: DDR3 detail: synchronous unbuffered
    manufacturer: Samsung part-no: M471B1G73QH0-YK0 serial: <filter>
  Info: model: AMD A4-6210 APU with AMD Radeon R3 Graphics bits: 64 type: MCP
    arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
    model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 1000 min/max: 1000/1800 boost: disabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1000 2: 1000 3: 1000
    4: 1000 bogomips: 14377
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
    clflush cmov cmp_legacy constant_tsc cpuid cr8_legacy cx16 cx8 de
    decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
    hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
    msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
    wdt xsave xsaveopt
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R3 Graphics]
    vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
    arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9850
    class-ID: 0300
  Device-2: Chicony HP Truevision HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.2:3 chip-ID: 04f2:b45e
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: radeon display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: BOE Display 0x0618 built: 2014 res: 1366x768
    dpi: 102 gamma: 1.2 chroma: red: x: 0.584 y: 0.345 green: x: 0.333 y: 0.569
    blue: x: 0.165 y: 0.118 white: x: 0.310 y: 0.337
    size: 277x156mm (10.91x6.14") diag: 389mm (15.3") ratio: 16:9, 15:9
    modes: 1366x768, 1280x720, 1152x768, 1024x768, 800x600, 848x480, 720x480,
    640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: KABINI (radeonsi LLVM 18.1.8 DRM 2.50
    6.12.1-4-MANJARO) device-ID: 1002:9850 memory: 1000 MiB unified: no
  Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1
    chip-ID: 1002:9840 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
    class-ID: 0403
  Device-3: Jieli USB Audio Device driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
    chip-ID: 4c4a:3435 class-ID: 0300
  API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
  Server-1: JACK v: 1.9.22 status: off tools: qjackctl
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:b723
    class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:3 chip-ID: 0bda:b001
  Local Storage: total: 476.94 GiB used: 12.58 GiB (2.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T-FORCE 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: LA.5 scheme: GPT
  ID-1: / raw-size: 59.31 GiB size: 58.08 GiB (97.92%) used: 12.55 GiB (21.6%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 7d636cc1-cc97-4108-8039-fec5f183efb2
    used: 31.3 MiB (10.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 1609-A1CB
  ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: ext4 label: kubuntu_2404
    uuid: 4f03e560-d858-47c1-943e-688fd87097b2
  ID-2: /dev/sda3 maj-min: 8:3 size: 417.32 GiB fs: ntfs label: N/A
    uuid: EA4EC14F4EC114EB
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 1-1:2 info: Jieli USB Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
  Device-2: 1-2:3 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0300 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
    chip-ID: 0438:7900 class-ID: 0900
  Device-1: 3-1.3:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
  Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-6: 4-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  Device-1: 4-1.2:3 info: Chicony HP Truevision HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b45e class-ID: 0e02
  System Temperatures: cpu: 53.0 C mobo: N/A gpu: radeon temp: 52.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1174 libs: 350 tools: pamac pm: flatpak pkgs: 0
    1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
Processes:
  CPU top: 5 of 196
  1: cpu: 4.1% command: Xorg pid: 774 mem: 92.7 MiB (0.6%)
  2: cpu: 3.8% command: xfdesktop pid: 1024 mem: 66.3 MiB (0.4%)
  3: cpu: 2.7% command: xfce4-terminal pid: 1388 mem: 60.1 MiB (0.4%)
  4: cpu: 2.6% command: xfwm4 pid: 968 mem: 99.9 MiB (0.6%)
  5: cpu: 2.5% command: blueman-applet started-by: python pid: 1100
    mem: 67.0 MiB (0.4%)
  Memory top: 5 of 196
  1: mem: 99.9 MiB (0.6%) command: xfwm4 pid: 968 cpu: 2.6%
  2: mem: 92.7 MiB (0.6%) command: Xorg pid: 774 cpu: 4.1%
  3: mem: 67.0 MiB (0.4%) command: blueman-applet started-by: python
    pid: 1100 cpu: 2.5%
  4: mem: 66.3 MiB (0.4%) command: xfdesktop pid: 1024 cpu: 3.8%
  5: mem: 65.7 MiB (0.4%) command: nm-applet pid: 1091 cpu: 1.2%
  Processes: 196 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.81 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
    inxi: 3.3.36
@LinuxPersuasive, do not start new threads about the same topic. I have merged both of your threads.
So is this an XFCE system that had budgie things added to it?
Have other kernels been tried?
Especially with such old hardware it might make sense to aim lower.
This isnt easy to look up … but do you have the latest BIOS?
Looks like you are currently using the legacy radeon driver but may be able to use the modern amdgpu.
