Laptop restarts without any reason
Hi, my laptop is being restarted without any reason after some minutes of use without power supply connected, my system info is
  Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
    root=UUID=b9347fc8-fa22-4041-89b9-4bac8f435b9f rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Micro-Star product: Stealth GS77 12UGS v: REV:1.0
  Mobo: Micro-Star model: MS-17P1 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E17P1IMS.106 date: 01/27/2022
  ID-1: BAT1 charge: 81.8 Wh (85.6%) condition: 95.6/95.0 Wh (100.6%)
    volts: 16.1 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: discharging
  Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
    arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x414
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 470 high: 1129 min/max: 400/5000:3800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 430 2: 455 3: 432 4: 424
    5: 451 6: 429 7: 497 8: 412 9: 429 10: 453 11: 432 12: 400 13: 400 14: 400
    15: 535 16: 1129 17: 499 18: 400 19: 400 20: 400 bogomips: 116780
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Micro-Star MSI
    driver: i915 v: kernel ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU]
    vendor: Micro-Star MSI driver: nvidia v: 510.68.02
    alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:24a0 class-ID: 0302
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2048x1152 s-dpi: 96 s-size: 541x304mm (21.30x11.97")
    s-diag: 621mm (24.43")
  Monitor-1: eDP-1 model: BOE Display 0x09f9 built: 2021 res: 2048x1152
    dpi: 137 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
    ratio: 16:9 modes: 2560x1440
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.0.3
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:228b class-ID: 0403
  Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 30:00.0
    chip-ID: 10ec:3000 class-ID: 0200
  IF: enp48s0 state: down mac: <filter>
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
    chip-ID: 8087:0033 class-ID: e001
  Local Storage: total: 2.75 TiB used: 39.6 GiB (1.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Micron model: 3400 MTFDKBA1T0TFH
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: P7MA000 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
    used: 39.58 GiB (4.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:5
    used: 27.7 MiB (9.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 402 Uptime: 4m wakeups: 380 Memory: 31.05 GiB
  used: 2.92 GiB (9.4%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1230 lib: 338 flatpak: 0
  Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.15
Can you try a LTS kernel: version 5.15 ?
I have to use 5.17 because my WIFI wasn’t working, also, I use 5.17 for 2 days without any problem.
Although I think it’s unrelated to your problem described it looks like there is also a BIOS update E17P1IMS.107 available.
5.17.6 was causing some issues on my machine also. Maybe try the testing branch with 5.17.9 currently.
I will going to do the bios update, also, I don’t have the 5.17.9 kernel in the list, but I tried the kernel 5.18rc6.220509.gc5eb0a6-1 and it’s working better, but I had an “automatic restart” after 1 hour of use :/, I don’t know if there is a way to check the logs, just to look why I have that restart issue.
you can check previous boot logs… if you had the restart now, then run this command to check logs… check the last logs
journalctl --boot=-1 --no-pager
I didn’t find anything incorrect. this is the log
may 20 10:47:55 Oscar kernel: audit: type=1130 audit(1653061675.852:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
addr=? terminal=? res=success'
may 20 10:47:56 Oscar kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
may 20 10:47:56 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:47:56 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-9999 noise=9999 txrate=0
may 20 10:47:56 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:47:56 Oscar NetworkManager[517]: <info>  [1653061676.6419] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:47:56 Oscar NetworkManager[517]: <info>  [1653061676.6419] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:47:56 Oscar NetworkManager[517]: <info>  [1653061676.7015] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:47:56 Oscar NetworkManager[517]: <info>  [1653061676.7016] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:47:57 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:47:57 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:47:57 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:47:57 Oscar NetworkManager[517]: <info>  [1653061677.9759] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:47:57 Oscar NetworkManager[517]: <info>  [1653061677.9759] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:47:57 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:47:58 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:47:58 Oscar kernel: wlo1: authenticated
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.0113] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.0115] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:47:58 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:47:58 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:47:58 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:47:58 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:47:58 Oscar kernel: wlo1: associated
may 20 10:47:58 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:47:58 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1211] device (wlo1): supplicant interface state: associating -> completed
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1222] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1225] device (wlo1): ip:dhcp4: restarting
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1679] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1680] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1680] dhcp4 (wlo1): state changed no lease
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1681] device (wlo1): ip:dhcp6: restarting
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1681] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.1681] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:47:58 Oscar NetworkManager[517]: <info>  [1653061678.2249] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:47:58 Oscar kernel: wlo1: Limiting TX power to 30 (30 - 0) dBm as advertised by f4:95:1b:ca:b8:ac
may 20 10:47:58 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=234000
may 20 10:48:01 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:01 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:01 Oscar NetworkManager[517]: <info>  [1653061681.4183] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:01 Oscar NetworkManager[517]: <info>  [1653061681.4183] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:01 Oscar NetworkManager[517]: <info>  [1653061681.5205] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:01 Oscar NetworkManager[517]: <info>  [1653061681.5206] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:03 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:03 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:03 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.0115] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.0115] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.0439] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.0440] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:03 Oscar kernel: wlo1: authenticated
may 20 10:48:03 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:03 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:03 Oscar kernel: wlo1: associated
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:03 Oscar kernel: wlo1: Limiting TX power to 30 (30 - 0) dBm as advertised by f4:95:1b:ca:b8:ac
may 20 10:48:03 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=234000
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.1748] device (wlo1): supplicant interface state: associating -> completed
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.1753] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.1753] device (wlo1): ip:dhcp4: restarting
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2012] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2013] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2013] dhcp4 (wlo1): state changed no lease
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2014] device (wlo1): ip:dhcp6: restarting
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2014] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2014] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:03 Oscar NetworkManager[517]: <info>  [1653061683.2591] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:48:04 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:04 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:04 Oscar NetworkManager[517]: <info>  [1653061684.9982] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:04 Oscar NetworkManager[517]: <info>  [1653061684.9983] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:05 Oscar NetworkManager[517]: <info>  [1653061685.0998] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:05 Oscar NetworkManager[517]: <info>  [1653061685.1001] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:05 Oscar systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
may 20 10:48:05 Oscar audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
may 20 10:48:05 Oscar kernel: audit: type=1131 audit(1653061685.859:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
may 20 10:48:06 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:06 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:06 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.3796] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.3796] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:06 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:06 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:06 Oscar kernel: wlo1: authenticated
may 20 10:48:06 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.4157] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.4158] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:06 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:06 Oscar kernel: wlo1: associated
may 20 10:48:06 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:06 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:06 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:06 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.4797] device (wlo1): supplicant interface state: associating -> completed
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.4803] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.4804] device (wlo1): ip:dhcp4: restarting
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5312] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5312] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5313] dhcp4 (wlo1): state changed no lease
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5314] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5315] device (wlo1): ip:dhcp6: restarting
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5315] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5315] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:06 Oscar NetworkManager[517]: <info>  [1653061686.5763] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:48:06 Oscar dbus-daemon[504]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=517 comm="/usr/bin/NetworkM
anager --no-daemon")
may 20 10:48:06 Oscar systemd[1]: Starting Network Manager Script Dispatcher Service...
may 20 10:48:06 Oscar dbus-daemon[504]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
may 20 10:48:06 Oscar systemd[1]: Started Network Manager Script Dispatcher Service.
may 20 10:48:06 Oscar audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succe
ss'
may 20 10:48:06 Oscar kernel: audit: type=1130 audit(1653061686.596:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
may 20 10:48:07 Oscar kernel: wlo1: Limiting TX power to 30 (30 - 0) dBm as advertised by f4:95:1b:ca:b8:ac
may 20 10:48:08 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-57 noise=9999 txrate=650000
may 20 10:48:09 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:09 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:09 Oscar NetworkManager[517]: <info>  [1653061689.1392] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:09 Oscar NetworkManager[517]: <info>  [1653061689.1392] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:09 Oscar NetworkManager[517]: <info>  [1653061689.2402] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:09 Oscar NetworkManager[517]: <info>  [1653061689.2404] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:10 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:10 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:10 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.7487] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.7487] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:10 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:10 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.7829] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.7829] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:10 Oscar kernel: wlo1: authenticated
may 20 10:48:10 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:10 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:10 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:10 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:10 Oscar kernel: wlo1: associated
may 20 10:48:10 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:10 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.8827] device (wlo1): supplicant interface state: associating -> completed
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.8840] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.8842] device (wlo1): ip:dhcp4: restarting
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9280] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9280] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9280] dhcp4 (wlo1): state changed no lease
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9281] device (wlo1): ip:dhcp6: restarting
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9281] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9281] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:10 Oscar NetworkManager[517]: <info>  [1653061690.9833] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:48:11 Oscar kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
may 20 10:48:11 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:11 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-9999 noise=9999 txrate=0
may 20 10:48:11 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:11 Oscar NetworkManager[517]: <info>  [1653061691.7684] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:11 Oscar NetworkManager[517]: <info>  [1653061691.7685] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:11 Oscar NetworkManager[517]: <info>  [1653061691.8389] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:11 Oscar NetworkManager[517]: <info>  [1653061691.8391] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:13 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:13 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:13 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:13 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5672] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5672] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:13 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5772] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5772] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:13 Oscar kernel: wlo1: authenticated
may 20 10:48:13 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:13 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:13 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:13 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:13 Oscar kernel: wlo1: associated
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5918] device (wlo1): supplicant interface state: associating -> 4way_handshake
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5918] device (p2p-dev-wlo1): supplicant management interface state: associating -> 4way_handshake
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.5919] device (wlo1): ip:dhcp4: restarting
may 20 10:48:13 Oscar kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6213] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6214] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6214] dhcp4 (wlo1): state changed no lease
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6215] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6216] device (wlo1): ip:dhcp6: restarting
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6216] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6217] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:13 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:13 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6513] device (wlo1): supplicant interface state: 4way_handshake -> completed
may 20 10:48:13 Oscar NetworkManager[517]: <info>  [1653061693.6518] device (p2p-dev-wlo1): supplicant management interface state: 4way_handshake -> completed
may 20 10:48:14 Oscar kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
may 20 10:48:14 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:14 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-9999 noise=9999 txrate=0
may 20 10:48:14 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:14 Oscar NetworkManager[517]: <info>  [1653061694.5662] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:14 Oscar NetworkManager[517]: <info>  [1653061694.5662] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:14 Oscar NetworkManager[517]: <info>  [1653061694.6318] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:14 Oscar NetworkManager[517]: <info>  [1653061694.6319] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:16 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:16 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:16 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:16 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5278] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5280] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:16 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5572] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5573] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:16 Oscar kernel: wlo1: authenticated
may 20 10:48:16 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:16 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:16 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:16 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:16 Oscar kernel: wlo1: associated
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5776] device (wlo1): supplicant interface state: associating -> 4way_handshake
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5776] device (p2p-dev-wlo1): supplicant management interface state: associating -> 4way_handshake
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.5777] device (wlo1): ip:dhcp4: restarting
may 20 10:48:16 Oscar systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
may 20 10:48:16 Oscar audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
may 20 10:48:16 Oscar kernel: audit: type=1131 audit(1653061696.602:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
may 20 10:48:16 Oscar kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6146] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6147] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6148] device (wlo1): ip:dhcp6: restarting
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6148] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6148] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:16 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:16 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6505] device (wlo1): supplicant interface state: 4way_handshake -> completed
may 20 10:48:16 Oscar NetworkManager[517]: <info>  [1653061696.6519] device (p2p-dev-wlo1): supplicant management interface state: 4way_handshake -> completed
may 20 10:48:17 Oscar kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
may 20 10:48:17 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:17 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-9999 noise=9999 txrate=0
may 20 10:48:17 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:17 Oscar NetworkManager[517]: <info>  [1653061697.5720] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:17 Oscar NetworkManager[517]: <info>  [1653061697.5720] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:17 Oscar NetworkManager[517]: <info>  [1653061697.6342] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:17 Oscar NetworkManager[517]: <info>  [1653061697.6343] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:18 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:18 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:18 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:18 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:18 Oscar NetworkManager[517]: <info>  [1653061698.9356] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:18 Oscar NetworkManager[517]: <info>  [1653061698.9356] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:18 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:18 Oscar kernel: wlo1: authenticated
may 20 10:48:18 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:18 Oscar NetworkManager[517]: <info>  [1653061698.9616] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:18 Oscar NetworkManager[517]: <info>  [1653061698.9617] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:18 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:18 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:18 Oscar kernel: wlo1: associated
may 20 10:48:18 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:19 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:19 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.0491] device (wlo1): supplicant interface state: associating -> completed
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.0495] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.0496] device (wlo1): ip:dhcp4: restarting
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.1080] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.1081] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.1083] device (wlo1): ip:dhcp6: restarting
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.1083] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.1084] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.1701] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:48:19 Oscar dbus-daemon[504]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=517 comm="/usr/bin/NetworkM
may 20 10:48:19 Oscar systemd[1]: Starting Network Manager Script Dispatcher Service...
may 20 10:48:19 Oscar dbus-daemon[504]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
may 20 10:48:19 Oscar systemd[1]: Started Network Manager Script Dispatcher Service.
may 20 10:48:19 Oscar audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succe
ss'
may 20 10:48:19 Oscar kernel: audit: type=1130 audit(1653061699.182:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
may 20 10:48:19 Oscar kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
may 20 10:48:19 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:19 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-9999 noise=9999 txrate=0
may 20 10:48:19 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.9372] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.9372] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.9989] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:19 Oscar NetworkManager[517]: <info>  [1653061699.9989] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:21 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:21 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:21 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.2697] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.2697] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:21 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:21 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.3039] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.3039] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:21 Oscar kernel: wlo1: authenticated
may 20 10:48:21 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:21 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:21 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:21 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:21 Oscar kernel: wlo1: associated
may 20 10:48:21 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:21 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.3830] device (wlo1): supplicant interface state: associating -> completed
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.3835] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.3835] device (wlo1): ip:dhcp4: restarting
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4145] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4145] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4146] dhcp4 (wlo1): state changed no lease
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4146] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4146] device (wlo1): ip:dhcp6: restarting
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4147] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4147] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:21 Oscar NetworkManager[517]: <info>  [1653061701.4593] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:48:22 Oscar kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
may 20 10:48:22 Oscar kernel: wlo1: Connection to AP f4:95:1b:ca:b8:ac lost
may 20 10:48:22 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-9999 noise=9999 txrate=0
may 20 10:48:22 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-DISCONNECTED bssid=f4:95:1b:ca:b8:ac reason=4 locally_generated=1
may 20 10:48:22 Oscar NetworkManager[517]: <info>  [1653061702.2803] device (wlo1): supplicant interface state: completed -> disconnected
may 20 10:48:22 Oscar NetworkManager[517]: <info>  [1653061702.2804] device (p2p-dev-wlo1): supplicant management interface state: completed -> disconnected
may 20 10:48:22 Oscar NetworkManager[517]: <info>  [1653061702.3485] device (wlo1): supplicant interface state: disconnected -> scanning
may 20 10:48:22 Oscar NetworkManager[517]: <info>  [1653061702.3485] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: SME: Trying to authenticate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:23 Oscar kernel: wlo1: authenticate with f4:95:1b:ca:b8:ac
may 20 10:48:23 Oscar kernel: wlo1: Invalid HE elem, Disable HE
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.8706] device (wlo1): supplicant interface state: scanning -> authenticating
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.8706] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
may 20 10:48:23 Oscar kernel: wlo1: send auth to f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: Trying to associate with f4:95:1b:ca:b8:ac (SSID='Claro_5G_681080' freq=5240 MHz)
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.9049] device (wlo1): supplicant interface state: authenticating -> associating
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.9049] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
may 20 10:48:23 Oscar kernel: wlo1: authenticated
may 20 10:48:23 Oscar kernel: wlo1: associate with f4:95:1b:ca:b8:ac (try 1/3)
may 20 10:48:23 Oscar kernel: wlo1: RX AssocResp from f4:95:1b:ca:b8:ac (capab=0x1411 status=0 aid=8)
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: Associated with f4:95:1b:ca:b8:ac
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
may 20 10:48:23 Oscar kernel: wlo1: associated
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: WPA: Key negotiation completed with f4:95:1b:ca:b8:ac [PTK=CCMP GTK=TKIP]
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-CONNECTED - Connection to f4:95:1b:ca:b8:ac completed [id=0 id_str=]
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.9867] device (wlo1): supplicant interface state: associating -> completed
may 20 10:48:23 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=234000
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.9870] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
may 20 10:48:23 Oscar NetworkManager[517]: <info>  [1653061703.9870] device (wlo1): ip:dhcp4: restarting
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0346] dhcp4 (wlo1): canceled DHCP transaction
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0346] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0346] dhcp4 (wlo1): state changed no lease
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0347] device (wlo1): ip:dhcp6: restarting
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0347] dhcp6 (wlo1): canceled DHCP transaction
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0347] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
may 20 10:48:24 Oscar NetworkManager[517]: <info>  [1653061704.0791] dhcp4 (wlo1): state changed new lease, address=192.168.20.52
may 20 10:48:24 Oscar kernel: wlo1: Limiting TX power to 30 (30 - 0) dBm as advertised by f4:95:1b:ca:b8:ac
may 20 10:48:29 Oscar systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
may 20 10:48:29 Oscar audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
may 20 10:48:29 Oscar kernel: audit: type=1131 audit(1653061709.189:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
may 20 10:48:35 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a784fa580) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 10:48:35 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 10:48:35 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 10:48:45 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a782500c0) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 10:48:45 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 10:48:45 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 10:48:46 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a7825f170) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 10:48:46 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 10:48:46 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 10:49:14 Oscar kwin_x11[948]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45096, resource id: 18948400, major code: 20 (GetProperty), minor code: 0
may 20 10:51:26 Oscar kwin_x11[948]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26230, resource id: 18960234, major code: 20 (GetProperty), minor code: 0
may 20 10:52:22 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 10:52:27 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 10:54:46 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a78519ea0) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 10:54:46 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 10:54:46 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 10:56:03 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a784d6890) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 10:56:03 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 10:56:03 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 10:56:05 Oscar kwin_x11[948]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49534, resource id: 35651996, major code: 15 (QueryTree), minor code: 0
may 20 10:56:13 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 10:56:20 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 10:56:23 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 10:56:49 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 10:57:29 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a77f9ea90) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 10:57:29 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 10:57:29 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 10:57:44 Oscar kded5[945]: Registering ":1.340/StatusNotifierItem" to system tray
may 20 10:57:46 Oscar wpa_supplicant[769]: wlo1: WPA: Group rekeying completed with f4:95:1b:ca:b8:ac [GTK=TKIP]
may 20 10:58:58 Oscar wpa_supplicant[769]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=585000
may 20 10:59:53 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 11:01:01 Oscar CROND[12053]: (root) CMD (run-parts /etc/cron.hourly)
may 20 11:01:01 Oscar anacron[12062]: Anacron started on 2022-05-20
may 20 11:01:01 Oscar CROND[12052]: (root) CMDEND (run-parts /etc/cron.hourly)
may 20 11:01:01 Oscar anacron[12062]: Will run job `cron.daily' in 50 min.
may 20 11:01:01 Oscar anacron[12062]: Jobs will be executed sequentially
may 20 11:01:09 Oscar rtkit-daemon[1124]: Supervising 12 threads of 5 processes of 1 users.
may 20 11:06:52 Oscar plasmashell[1039]: libkcups: Renew-Subscription last error: 0 successful-ok
may 20 11:07:46 Oscar wpa_supplicant[769]: wlo1: WPA: Group rekeying completed with f4:95:1b:ca:b8:ac [GTK=TKIP]
may 20 11:08:40 Oscar dbus-daemon[889]: [session uid=1000 pid=889] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.347' (uid=1000 pid=12535 comm="pamac checkupdates -q
--refresh-tmp-files-dbs --us")
may 20 11:08:40 Oscar systemd[809]: Starting Virtual filesystem metadata service...
may 20 11:08:40 Oscar dbus-daemon[889]: [session uid=1000 pid=889] Successfully activated service 'org.gtk.vfs.Metadata'
may 20 11:08:40 Oscar systemd[809]: Started Virtual filesystem metadata service.
may 20 11:08:48 Oscar plasmashell[1039]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x558a77811890) QQmlContext(0x558a770483e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global
/Globals.qml")
/Globals.qml")
may 20 11:08:48 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 20 11:08:48 Oscar plasmashell[1039]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 20 11:08:53 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:08:53 Oscar kwin_x11[948]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63597, resource id: 35652030, major code: 15 (QueryTree), minor code: 0
may 20 11:10:08 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:11:23 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:17:38 Oscar dbus-daemon[504]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.28' (uid=1000 pid=1037 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
may 20 11:17:38 Oscar dbus-daemon[504]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
may 20 11:17:46 Oscar wpa_supplicant[769]: wlo1: WPA: Group rekeying completed with f4:95:1b:ca:b8:ac [GTK=TKIP]
may 20 11:25:32 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:26:47 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:26:52 Oscar dbus-daemon[504]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.28' (uid=1000 pid=1037 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
may 20 11:26:52 Oscar dbus-daemon[504]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
may 20 11:27:46 Oscar wpa_supplicant[769]: wlo1: WPA: Group rekeying completed with f4:95:1b:ca:b8:ac [GTK=TKIP]
may 20 11:29:28 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:30:43 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:31:58 Oscar org_kde_powerdevil[1037]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
may 20 11:37:46 Oscar wpa_supplicant[769]: wlo1: WPA: Group rekeying completed with f4:95:1b:ca:b8:ac [GTK=TKIP]
may 20 11:40:47 Oscar kwin_x11[948]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2432, resource id: 62914605, major code: 15 (QueryTree), minor code: 0
may 20 11:40:52 Oscar dbus-daemon[504]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.28' (uid=1000 pid=1037 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
may 20 11:40:52 Oscar dbus-daemon[504]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
but are these logs from the crash?
I think are almost form the crash, but this are from the crash, I’m sure
may 20 11:56:40 Oscar systemd[1]: Starting Cleanup of Temporary Directories...
may 20 11:56:40 Oscar systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
may 20 11:56:40 Oscar systemd[1]: Finished Cleanup of Temporary Directories.
may 20 11:56:40 Oscar audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 20 11:56:40 Oscar audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 20 11:56:40 Oscar kernel: audit: type=1130 audit(1653065800.789:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? add
may 20 11:56:40 Oscar kernel: audit: type=1131 audit(1653065800.789:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? add
may 20 11:57:19 Oscar rtkit-daemon[1142]: Supervising 13 threads of 6 processes of 1 users.
may 20 11:57:46 Oscar wpa_supplicant[769]: wlo1: WPA: Group rekeying completed with f4:95:1b:ca:b8:ac [GTK=TKIP]
may 20 12:00:19 Oscar plasmashell[1048]: trying to show an empty dialog
may 20 12:00:57 Oscar rtkit-daemon[1142]: Supervising 13 threads of 6 processes of 1 users.
may 20 12:01:01 Oscar CROND[5504]: (root) CMD (run-parts /etc/cron.hourly)
may 20 12:01:01 Oscar anacron[5513]: Anacron started on 2022-05-20
may 20 12:01:01 Oscar CROND[5503]: (root) CMDEND (run-parts /etc/cron.hourly)
may 20 12:01:01 Oscar anacron[5513]: Will run job `cron.daily' in 6 min.
may 20 12:01:01 Oscar anacron[5513]: Jobs will be executed sequentially
may 20 12:02:17 Oscar rtkit-daemon[1142]: Supervising 13 threads of 6 processes of 1 users.
may 20 12:02:54 Oscar dbus-daemon[506]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=1043 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
may 20 12:02:54 Oscar dbus-daemon[506]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
may 20 12:03:19 Oscar rtkit-daemon[1142]: Supervising 13 threads of 6 processes of 1 users.
may 20 12:03:26 Oscar dbus-daemon[506]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=1043 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
may 20 12:03:26 Oscar dbus-daemon[506]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
may 20 12:04:19 Oscar rtkit-daemon[1142]: Supervising 13 threads of 6 processes of 1 users.
nothing there… you could try installing the 5.15 LTS and 5.10LTS kernel and try running with them and see if you get restarts
I will, thanks!
If nothing has been mentioned at the journal and the reboot/crash happens suddenly, then I assume the kernel triggers something on the firmware (UEFI) which results in that malfunction.
So firmware update or kernel update can change that behavior.
Also: If you run it in dualboot mode with windows, then keep sure you always cold boot and not warm boot the laptop.
I did the firmware update and changed the kernel, but nothing works (that was 2 days ago), also, I always cold boot my laptop, anyways, at least today I’m not having that issue
Which kernel did you use/ switch to? 5.15 or newer 5.17?
I’m using Kernel Version: 5.18.0-1-MANJARO (64-bit) I tried 5.17.9-1 but it have the same issue
5.18 and above will be the better choice for your given hardware specs. Keep an eye on future Bios updates.
You say that the random reboots only happen while on battery, is it?
Without indication in journal logs it’s only a guessing, or you approach it with the process of elimination.
Have you checked Bios options for any power management configuration? If feasible for you, you could also try to run the system from live iso on battery with Manjaro KDE, possible try different distros also from live iso and see if it also reboots automatically after a while.
HI, the reboot happens with or without battery, how can I give you the journal logs?, also, what should I check in the Bios?, another important information, I tried pop os, and ubuntu, but I have the same issue.
To check journal logs you can use terminal or with KDE application KSystemLog. For other users here it’s easier with terminal journalctl.
List of journals per boot, starting from oldest to newest. Use the leading number for next step.
journalctl --list-boot
Examples of different log outputs for you to try:
  • Journal for current boot with message priority 3 -p3
journalctl --boot=0 -p3 --catalog
  • Journal for last boot with message priority 3 -p3
journalctl --boot=-1 -p3 --catalog
  • Journal for last boot with message priority 4 -p4
journalctl --boot=-1 -p4 --catalog
  • Journal for last boot everything
journalctl --boot=-1 --catalog
Since the random restarts happens at --boot=-1 at the end of the log you most likely will find indications of what caused the reboot when you scroll to end of journalctl --boot=-1 --catalog. Go by journal timestamp.
So it’s maybe not related to performance optimization by the system while on battery, which I thought because you mentioned at the beginning that it happens with battery only.
Do you have any reference when using it with Windows? I suppose the notebook was shipped with WIN11. Do you dualboot or have you wiped the disk and installed Manjaro only?
Have you considered that it may be related to a hardware issue?
I will going to run all those commands when the bug happens again, but for now, I’m using the 5.15 kernel and I didn’t have any restart, also, with windows I don’t have any issue, so, I think is an issue witht he 5.17 kernel
Does Wifi work with kernel 5.15?
