After reading a few similar threads, I thought it may be more helpful to start a new one rather than to try and piggy back on someone else.
I’ve been running Manjaro Gnome for more than a year with very little problems ever. However, most recently when I close my laptop lid my computer often freezes to a black screen with the mouse cursor still visible but not responsive. The fans usually kick up and the laptop case get quite hot.
In these cases, the only way I can get a response is to force power off and reboot. That usually works, except yesterday it took 3 reboots before it started up again.
Any suggestions are much appreciated.
Here’s more system information:
inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=af2b505e-d0e1-4a35-8165-3f29ae45a52f rw quiet acpi_osi=!
"acpi_osi=Windows 2017" nouveau.modeset=0 apparmor=1 security=apparmor
resume=UUID=0785422f-231a-4033-b244-0a84826dd733 udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Notebook product: N85_N87,HJ,HJ1,HK1 v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Notebook model: N85_N87,HJ,HJ1,HK1 serial: <filter>
UEFI: American Megatrends v: 1.05.22RLS1 date: 03/27/2018
ID-1: BAT0 charge: 39.3 Wh condition: 41.6/59.9 Wh (69%) volts: 12.9/11.1
model: Notebook BAT type: Li-ion serial: <filter> status: Charging
Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: D6
L2 cache: 6144 KiB
bogomips: 44817
Speed: 900 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 901 8: 900
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 430.64 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Chicony Chicony USB 2.0 Camera type: USB driver: uvcvideo
bus ID: 1-2:2 chip ID: 04f2:b5a7
Display: x11 server: X.Org 1.20.9 compositor: gnome-shell
driver: modesetting,nvidia display ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1-1 res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 430.64
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Device-2: NVIDIA GP107GL High Definition Audio vendor: Intel
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.8.11-1-MANJARO
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: d000 bus ID: 03:00.1
chip ID: 10ec:8168
IF: enp3s0f1 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
bus ID: 04:00.0 chip ID: 8086:24fd
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 1.14 TiB used: 321.76 GiB (27.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS256G1X0C-00ENX0
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: B35900WD scheme: GPT
ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A490 scheme: GPT
ID-1: / raw size: 221.06 GiB size: 216.59 GiB (97.98%)
used: 32.87 GiB (15.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 288.89 GiB (31.5%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 50 C
Processes: 294 Uptime: 44m Memory: 15.53 GiB used: 5.84 GiB (37.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1481 pacman: 1473
lib: 400 flatpak: 0 snap: 8 Shell: Bash v: 5.0.18 running in: gnome-terminal
inxi: 3.1.05
