When I suspend my laptop for the first it wakes up with no problems, however, if I try to suspend it again the system freezes and display does not turn on. I tried using REISUB in the frozen state, however, nothing happens. (REISUB works when the system is not frozen). Accordingly, I have to shut it down by pressing a power button.
Note I am using latest kernels as previous ones had different issues and rolling back to a previous one is not an option.
journalctl -b -1 output: https://pastebin.com/fvVPduDt
inxi -Fxzc0 output:
System: Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: KDE Plasma 5.20.5 Distro: Manjaro Linux
Machine: Type: Laptop System: Micro-Star product: Bravo 15 A4DDR v: REV:1.0 serial: <filter>
Mobo: Micro-Star model: MS-16WK v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16WKAMS.110 date: 10/29/2020
Battery: ID-1: BAT1 charge: 46.2 Wh condition: 46.6/51.3 Wh (91%) model: MSI Corp. MS-16WK
status: Charging
Device-1: hid-98:fd:b4:7c:55:35-battery model: HP Bluetooth Mouse Z5000 charge: N/A
status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 rev: 1 L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92660
Speed: 2101 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 2101
2: 1959 3: 1401 4: 1395 5: 1408 6: 1397 7: 1397 8: 1397 9: 1859 10: 1682 11: 1617
12: 1402 13: 1529 14: 1576 15: 1397 16: 1397
Graphics: Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus ID: 03:00.0
Device-2: AMD Renoir vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 07:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1920x1080~120Hz
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.7-3-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.3 direct render: Yes
Audio: Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 03:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Micro-Star MSI
driver: N/A bus ID: 07:00.5
Device-3: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 07:00.6
Sound Server: ALSA v: k5.10.7-3-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 60.09 GiB (12.6%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB temp: 43.9 C
Partition: ID-1: / size: 97.93 GiB used: 12.46 GiB (12.7%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 511 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 353.19 GiB used: 47.62 GiB (13.5%) fs: ext4 dev: /dev/nvme0n1p4
Swap: ID-1: swap-1 type: partition size: 16.6 GiB used: 3 MiB (0.0%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 71.8 C mobo: N/A
GPU: device: amdgpu temp: 49.0 C device: amdgpu temp: 48.0 C fan: 65535
Info: Processes: 395 Uptime: 40m Memory: 15.1 GiB used: 8.84 GiB (58.5%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1273 Client: KDE Plasma v: 5.20.5 inxi: 3.2.02
