Thanks for the tutorial link
I attached inxi and journalctl output below
I closed the laptop lid around 12:xx, but it looks like it was still running until I force turn it off.
Here’s my inxi output:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=26334a62-3293-4a8d-b5d4-b52c97e2ea62 rw quiet splash apparmor=1
security=apparmor resume=UUID=51fa1a39-6dd3-4f24-995c-3b8bb5ffb0ce
udev.log_priority=3
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0JHP5H v: A00 serial: <filter> UEFI: Dell v: 1.24.0
date: 08/10/2021
ID-1: BAT0 charge: 51.2 Wh (100.0%) condition: 51.2/97.0 Wh (52.7%)
volts: 12.6 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Full
RAM: total: 19.4 GiB used: 11.19 GiB (57.7%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A size: 16 GiB speed: spec: 2667 MT/s actual: 2400 MT/s
type: DDR4 detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: 859B0000802C part-no: CT16G4SFD8266.M16FE
serial: <filter>
Device-2: DIMM B size: 4 GiB speed: 2400 MT/s type: DDR4
total: 64 bits manufacturer: Micron part-no: 4ATF51264HZ-2G3E1
serial: <filter>
Info: model: Intel Core i5-7300HQ socket: U3E1 bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEA
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3500 base/boost: 2400/2500 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 20004
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0c45:6713 class-ID: 0e02
Display: server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:003e class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0cf3:e301 class-ID: e001
Local Storage: total: 1.82 TiB used: 373.92 GiB (20.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5SSD8
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 1.64 TiB size: 1.61 TiB (98.37%) used: 373.92 GiB (22.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 26334a62-3293-4a8d-b5d4-b52c97e2ea62
used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: NO_LABEL uuid: 0256-F139
ID-1: swap-1 type: partition size: 28 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 51fa1a39-6dd3-4f24-995c-3b8bb5ffb0ce
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 9EAA-1271
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 127.34 GiB fs: ntfs label: N/A
uuid: 26B2C75AB2C72CDD
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 563 MiB fs: ntfs label: N/A
uuid: 1448F97948F959C6
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 32 GiB fs: ntfs label: Data
uuid: 560CAC6A0CAC4739
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e301
class-ID: e001
Device-2: 1-7:6 info: Validity Sensors VFS7552 Touch Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 138a:0091 class-ID: ff00 serial: <filter>
Device-3: 1-9:4 info: Elan Micro Touchscreen type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04f3:24a0 class-ID: 0300
Device-4: 1-12:5 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 46.0 C pch: 47.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2530 fan-2: 2525
Processes: 324 Uptime: 7h 53m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1430 lib: 345
flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.12
running-in: gnome-terminal inxi: 3.3.11
Here is journalctl output starting from LOW battery message:
1月 05 12:45:27 doraemon-xps tracker-miner-f[11690]: Running on LOW Battery, pausing
1月 05 12:48:17 doraemon-xps wpa_supplicant[776]: wlp2s0: WPA: Group rekeying completed with 8c:3b:ad:58:b0:83 [GTK=CCMP]
1月 05 12:48:33 doraemon-xps touchegg[513]: Client disconnected
1月 05 12:48:47 doraemon-xps NetworkManager[507]: <info> [1641358127.8992] manager: sleep: sleep requested (sleeping: no enabled: yes)
1月 05 12:48:47 doraemon-xps ModemManager[566]: <info> [sleep-monitor] system is about to suspend
1月 05 12:48:47 doraemon-xps NetworkManager[507]: <info> [1641358127.8995] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
1月 05 12:48:47 doraemon-xps NetworkManager[507]: <info> [1641358127.9003] manager: NetworkManager state is now ASLEEP
1月 05 12:48:47 doraemon-xps NetworkManager[507]: <info> [1641358127.9006] device (wlp2s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
1月 05 12:48:47 doraemon-xps dbus-daemon[505]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.1' (uid=0 pid=507 comm="/usr/bin/NetworkManager --no-daemon ")
1月 05 12:48:47 doraemon-xps systemd[1]: Starting Network Manager Script Dispatcher Service...
1月 05 12:48:47 doraemon-xps dbus-daemon[505]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
1月 05 12:48:47 doraemon-xps systemd[1]: Started Network Manager Script Dispatcher Service.
1月 05 12:48:47 doraemon-xps audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 12:48:47 doraemon-xps kernel: audit: type=1130 audit(1641358127.933:374): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 12:48:47 doraemon-xps kernel: wlp2s0: deauthenticating from 8c:3b:ad:58:b0:83 by local choice (Reason: 3=DEAUTH_LEAVING)
1月 05 12:48:48 doraemon-xps wpa_supplicant[776]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=8c:3b:ad:58:b0:83 reason=3 locally_generated=1
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0257] device (wlp2s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
1月 05 12:48:48 doraemon-xps wpa_supplicant[776]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0395] dhcp4 (wlp2s0): canceled DHCP transaction
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0396] dhcp4 (wlp2s0): state changed bound -> terminated
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0420] device (wlp2s0): set-hw-addr: set MAC address to 42:F9:37:2E:08:C5 (scanning)
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0546] device (wlp2s0): supplicant interface state: completed -> disconnected
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0551] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0553] device (wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
1月 05 12:48:48 doraemon-xps NetworkManager[507]: <info> [1641358128.0571] device (wlp2s0): set-hw-addr: reset MAC address to 9C:B6:D0:BA:4B:BB (unmanage)
1月 05 12:48:48 doraemon-xps wpa_supplicant[776]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
1月 05 12:48:49 doraemon-xps gnome-shell[1333]: Source ID 384202 was not found when attempting to remove it
1月 05 12:48:49 doraemon-xps gnome-shell[1333]: Source ID 384329 was not found when attempting to remove it
1月 05 12:48:49 doraemon-xps gnome-shell[1333]: Source ID 384381 was not found when attempting to remove it
1月 05 12:48:49 doraemon-xps gnome-shell[1333]: [System monitor] applet disable
1月 05 12:48:49 doraemon-xps gnome-shell[1333]: _shell_embedded_window_unmap: assertion 'SHELL_IS_EMBEDDED_WINDOW (window)' failed
1月 05 12:48:50 doraemon-xps gnome-shell[2571]: [2564:2594:0105/124850.055835:ERROR:connection_factory_impl.cc(425)] Failed to connect to MCS endpoint with error -106
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: [x11gestures@joseexposito.github.io] Extension disabled
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: [x11gestures@joseexposito.github.io] Building entry point for GNOME Shell 41.2
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: An active wireless connection, in infrastructure mode, involves no access point?
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: [x11gestures@joseexposito.github.io] Connection with Touchégg daemon lost: null
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: [x11gestures@joseexposito.github.io] Connection manually closed, not reconnecting to the daemon
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Could not create transient scope for PID 61547: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 61547 does not exist.
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Could not create transient scope for PID 61550: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 61550 does not exist.
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
1月 05 12:48:50 doraemon-xps gnome-shell[1333]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
1月 05 12:48:51 doraemon-xps systemd[1]: Reached target Sleep.
1月 05 12:48:51 doraemon-xps systemd[1]: Starting Hybrid Suspend+Hibernate...
1月 05 12:48:51 doraemon-xps systemd-sleep[61554]: Entering sleep state 'hybrid-sleep'...
1月 05 12:48:51 doraemon-xps kernel: PM: hibernation: hibernation entry
1月 05 12:48:51 doraemon-xps wpa_supplicant[776]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
1月 05 12:48:51 doraemon-xps systemd-logind[512]: Lid closed.
1月 05 12:48:52 doraemon-xps wpa_supplicant[776]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "52"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event3 - Power Button: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "76"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event15 - Video Bus: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "54"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event16 - Video Bus: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "53"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event1 - Power Button: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "103"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event2 - Sleep Button: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "50"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event14 - Integrated_Webcam_HD: Integrate: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "60"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event11 - ELAN Touchscreen: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "55"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event7 - DLL07BE:01 06CB:7A13 Mouse: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "58"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event8 - DLL07BE:01 06CB:7A13 Touchpad: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "56"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event5 - Intel HID events: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "59"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event6 - Intel HID 5 button array: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "57"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event10 - Dell WMI hotkeys: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "51"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event4 - AT Translated Set 2 keyboard: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (**) Option "fd" "100"
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) event23 - ydotoold virtual device: device removed
1月 05 12:48:52 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) AIGLX: Suspending AIGLX clients for VT switch
1月 05 13:08:43 doraemon-xps kernel: Filesystems sync: 0.007 seconds
1月 05 13:08:44 doraemon-xps kernel: Freezing user space processes ... (elapsed 0.022 seconds) done.
1月 05 13:08:44 doraemon-xps kernel: OOM killer disabled.
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x00058000-0x00058fff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x0009f000-0x000fffff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x6476e000-0x6476ffff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x72f75000-0x73184fff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x78429000-0x795fefff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Marking nosave pages: [mem 0x79600000-0xffffffff]
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Basic memory bitmaps created
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Preallocating image memory
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Allocated 2014588 pages for snapshot
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Allocated 8058352 kbytes in 27.67 seconds (291.23 MB/s)
1月 05 13:08:44 doraemon-xps kernel: Freezing remaining freezable tasks ... (elapsed 0.107 seconds) done.
1月 05 13:08:44 doraemon-xps kernel: printk: Suspending console(s) (use no_console_suspend to debug)
1月 05 13:08:44 doraemon-xps kernel: ACPI: EC: interrupt blocked
1月 05 13:08:44 doraemon-xps kernel: Disabling non-boot CPUs ...
1月 05 13:08:44 doraemon-xps kernel: smpboot: CPU 1 is now offline
1月 05 13:08:44 doraemon-xps kernel: smpboot: CPU 2 is now offline
1月 05 13:08:44 doraemon-xps kernel: smpboot: CPU 3 is now offline
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Creating image:
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Need to copy 2002278 pages
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Normal pages needed: 2002278 + 1024, available pages: 3201757
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Image created (2002278 pages copied)
1月 05 13:08:44 doraemon-xps kernel: Enabling non-boot CPUs ...
1月 05 13:08:44 doraemon-xps kernel: x86: Booting SMP configuration:
1月 05 13:08:44 doraemon-xps kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
1月 05 13:08:44 doraemon-xps kernel: CPU1 is up
1月 05 13:08:44 doraemon-xps kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
1月 05 13:08:44 doraemon-xps kernel: CPU2 is up
1月 05 13:08:44 doraemon-xps kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
1月 05 13:08:44 doraemon-xps kernel: CPU3 is up
1月 05 13:08:44 doraemon-xps kernel: ACPI: EC: interrupt unblocked
1月 05 13:08:44 doraemon-xps kernel: nvme nvme0: 4/0/0 default/read/poll queues
1月 05 13:08:44 doraemon-xps kernel: ata2: SATA link down (SStatus 4 SControl 300)
1月 05 13:08:44 doraemon-xps kernel: PM: Using 3 thread(s) for compression
1月 05 13:08:44 doraemon-xps kernel: PM: Compressing and saving image data (2006189 pages)...
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 0%
1月 05 13:08:44 doraemon-xps kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 10%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 20%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 30%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 40%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 50%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 60%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 70%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 80%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 90%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving progress: 100%
1月 05 13:08:44 doraemon-xps kernel: PM: Image saving done
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Wrote 8024756 kbytes in 10.18 seconds (788.28 MB/s)
1月 05 13:08:44 doraemon-xps kernel: PM: S|
1月 05 13:08:44 doraemon-xps kernel: ACPI: Preparing to enter system sleep state S3
1月 05 13:08:44 doraemon-xps kernel: ACPI: EC: event blocked
1月 05 13:08:44 doraemon-xps kernel: ACPI: EC: EC stopped
1月 05 13:08:44 doraemon-xps kernel: PM: Saving platform NVS memory
1月 05 13:08:44 doraemon-xps kernel: ACPI: Low-level resume complete
1月 05 13:08:44 doraemon-xps kernel: ACPI: EC: EC started
1月 05 13:08:44 doraemon-xps kernel: PM: Restoring platform NVS memory
1月 05 13:08:44 doraemon-xps kernel: ACPI: Waking up from system sleep state S3
1月 05 13:08:44 doraemon-xps kernel: nvidia 0000:01:00.0: Enabling HDA controller
1月 05 13:08:44 doraemon-xps kernel: ACPI: EC: event unblocked
1月 05 13:08:44 doraemon-xps kernel: i915 0000:00:02.0: [drm] [ENCODER:94:DDI A/PHY A] is disabled/in DSI mode with an ungated DDI clock, gate it
1月 05 13:08:44 doraemon-xps kernel: i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
1月 05 13:08:44 doraemon-xps kernel: i915 0000:00:02.0: [drm] [ENCODER:118:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
1月 05 13:08:44 doraemon-xps kernel: usb usb1: root hub lost power or was reset
1月 05 13:08:44 doraemon-xps kernel: usb usb2: root hub lost power or was reset
1月 05 13:08:44 doraemon-xps kernel: usb 1-4: reset full-speed USB device number 2 using xhci_hcd
1月 05 13:08:44 doraemon-xps kernel: usb 1-9: reset full-speed USB device number 4 using xhci_hcd
1月 05 13:08:44 doraemon-xps kernel: usb 1-12: reset high-speed USB device number 5 using xhci_hcd
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:16: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:15: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:14: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:13: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:12: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:11: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:10: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:0f: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:0e: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:0d: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:0c: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:0b: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:0a: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:09: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:08: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:07: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:06: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:05: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:04: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: acpi LNXPOWER:03: Turning OFF
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: Basic memory bitmaps freed
1月 05 13:08:44 doraemon-xps kernel: OOM killer enabled.
1月 05 13:08:44 doraemon-xps kernel: Restarting tasks ... done.
1月 05 13:08:44 doraemon-xps kernel: usb 1-7: USB disconnect, device number 9
1月 05 13:08:44 doraemon-xps kernel: PM: hibernation: hibernation exit
1月 05 13:08:44 doraemon-xps kernel: Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
1月 05 13:08:44 doraemon-xps kernel: Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: The canary thread is apparently starving. Taking action.
1月 05 13:08:44 doraemon-xps kernel: usb 1-7: new full-speed USB device number 10 using xhci_hcd
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Demoting known real-time threads.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Successfully demoted thread 1409 of process 1400.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Successfully demoted thread 1400 of process 1400.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Successfully demoted thread 1408 of process 1402.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Successfully demoted thread 1402 of process 1402.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Successfully demoted thread 1407 of process 1401.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Successfully demoted thread 1401 of process 1401.
1月 05 13:08:43 doraemon-xps rtkit-daemon[954]: Demoted 6 threads.
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/ldac
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSink/aptx_hd
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_hd
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aac
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSink/sbc
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/sbc
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSink/sbc_xq
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/sbc_xq
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/faststream
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/faststream_duplex
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_1
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_0
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint unregistered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
1月 05 13:08:44 doraemon-xps gdm[833]: GLib: Source ID 125 was not found when attempting to remove it
1月 05 13:08:44 doraemon-xps systemd-sleep[61554]: System returned from sleep state.
1月 05 13:08:44 doraemon-xps kernel: usb 1-7: New USB device found, idVendor=138a, idProduct=0091, bcdDevice= 1.64
1月 05 13:08:44 doraemon-xps kernel: usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=1
1月 05 13:08:44 doraemon-xps kernel: usb 1-7: SerialNumber: 4f7aa880f419
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:78
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:68
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:67
1月 05 13:08:44 doraemon-xps dbus-daemon[505]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.200" (uid=1000 pid=1401 comm="/usr/bin/pipewire-media-session ") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.13" (uid=0 pid=612 comm="/usr/lib/bluetooth/bluetoothd ")
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:65
1月 05 13:08:44 doraemon-xps kernel: rfkill: input handler enabled
1月 05 13:08:44 doraemon-xps kernel: rfkill: input handler disabled
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:80
1月 05 13:08:44 doraemon-xps systemd[1]: Starting Load/Save RF Kill Switch Status...
1月 05 13:08:44 doraemon-xps systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
1月 05 13:08:44 doraemon-xps audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps kernel: audit: type=1131 audit(1641359324.391:375): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps kernel: Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:71
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:69
1月 05 13:08:44 doraemon-xps dbus-daemon[505]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.1' (uid=0 pid=507 comm="/usr/bin/NetworkManager --no-daemon ")
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:74
1月 05 13:08:44 doraemon-xps upowerd[938]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-9
1月 05 13:08:44 doraemon-xps upowerd[938]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4
1月 05 13:08:44 doraemon-xps systemd[1214]: Stopped target Bluetooth.
1月 05 13:08:44 doraemon-xps kernel: audit: type=1130 audit(1641359324.584:376): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps kernel: audit: type=1130 audit(1641359324.601:377): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:72
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:70
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:75
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:79
1月 05 13:08:44 doraemon-xps mtp-probe[61730]: checking bus 1, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7"
1月 05 13:08:44 doraemon-xps systemd[1]: Stopped target Bluetooth Support.
1月 05 13:08:44 doraemon-xps mtp-probe[61730]: bus: 1, device: 10 was not an MTP device
1月 05 13:08:44 doraemon-xps systemd[1]: Starting Network Manager Script Dispatcher Service...
1月 05 13:08:44 doraemon-xps dbus-daemon[505]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
1月 05 13:08:44 doraemon-xps systemd[1]: Started Load/Save RF Kill Switch Status.
1月 05 13:08:44 doraemon-xps wpa_supplicant[776]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
1月 05 13:08:44 doraemon-xps systemd[1214]: Reached target Bluetooth.
1月 05 13:08:44 doraemon-xps systemd[1]: Started Network Manager Script Dispatcher Service.
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:87
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got pause for 13:66
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:78
1月 05 13:08:44 doraemon-xps wpa_supplicant[776]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:68
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:67
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:65
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:80
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:71
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:69
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:74
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:72
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:70
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:75
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:79
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:87
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 13:66
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) systemd-logind: got resume for 226:1
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) AIGLX: Resuming AIGLX clients after VT switch
1月 05 13:08:44 doraemon-xps tlp[61713]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
1月 05 13:08:44 doraemon-xps tlp[61713]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
1月 05 13:08:44 doraemon-xps tlp[61713]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
1月 05 13:08:44 doraemon-xps tlp[61713]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) modeset(0): EDID vendor "SHP", prod id 5238
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) modeset(0): Printing DDC gathered Modelines:
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (II) modeset(0): Modeline "3840x2160"x0.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 -hsync -vsync (133.3 kHz eP)
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Player registered: sender=:1.200 path=/media_player1
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/ldac
1月 05 13:08:44 doraemon-xps kernel: audit: type=1130 audit(1641359324.831:378): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps kernel: audit: type=1131 audit(1641359324.831:379): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSink/aptx_hd
1月 05 13:08:44 doraemon-xps systemd[1]: systemd-hybrid-sleep.service: Deactivated successfully.
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_hd
1月 05 13:08:44 doraemon-xps systemd[1]: Finished Hybrid Suspend+Hibernate.
1月 05 13:08:44 doraemon-xps systemd[1]: systemd-hybrid-sleep.service: Consumed 30.871s CPU time.
1月 05 13:08:44 doraemon-xps systemd[1]: Reached target Hybrid Suspend+Hibernate.
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aac
1月 05 13:08:44 doraemon-xps systemd[1]: Stopped target Sleep.
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSink/sbc
1月 05 13:08:44 doraemon-xps systemd[1]: Stopped target Hybrid Suspend+Hibernate.
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/sbc
1月 05 13:08:44 doraemon-xps systemd-logind[512]: Operation 'sleep' finished.
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSink/sbc_xq
1月 05 13:08:44 doraemon-xps NetworkManager[507]: <info> [1641359324.8395] manager: sleep: wake requested (sleeping: yes enabled: yes)
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/sbc_xq
1月 05 13:08:44 doraemon-xps systemd-logind[512]: Suspending...
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/faststream
1月 05 13:08:44 doraemon-xps NetworkManager[507]: <info> [1641359324.8409] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/faststream_duplex
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_1
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_0
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
1月 05 13:08:44 doraemon-xps bluetoothd[612]: Endpoint registered: sender=:1.200 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
1月 05 13:08:44 doraemon-xps ModemManager[566]: <info> [sleep-monitor] system is resuming
1月 05 13:08:44 doraemon-xps systemd[1]: Reached target Sleep.
1月 05 13:08:44 doraemon-xps gsd-power[1532]: Unable to inhibit suspend: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
1月 05 13:08:44 doraemon-xps gsd-media-keys[1531]: Unable to inhibit suspend: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
1月 05 13:08:44 doraemon-xps ModemManager[566]: <info> [sleep-monitor] system is about to suspend
1月 05 13:08:44 doraemon-xps systemd[1]: Starting System Suspend...
1月 05 13:08:44 doraemon-xps ModemManager[566]: <warn> [sleep-monitor] inhibit failed: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
1月 05 13:08:44 doraemon-xps NetworkManager[507]: <info> [1641359324.9266] device (wlp2s0): set-hw-addr: set MAC address to 7A:94:19:92:B2:BA (scanning)
1月 05 13:08:44 doraemon-xps dbus-daemon[505]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.226' (uid=972 pid=61752 comm="/usr/lib/colord-sane ")
1月 05 13:08:44 doraemon-xps dbus-daemon[505]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
1月 05 13:08:44 doraemon-xps /usr/lib/gdm-x-session[1233]: (EE) NVIDIA(GPU-0): Failed to query object info.
1月 05 13:08:45 doraemon-xps systemd-sleep[61883]: Entering sleep state 'suspend'...
1月 05 13:08:45 doraemon-xps kernel: PM: suspend entry (deep)
1月 05 13:08:45 doraemon-xps kernel: Filesystems sync: 0.002 seconds
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.2110] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.2113] manager: NetworkManager state is now DISCONNECTED
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.2114] manager: sleep: sleep requested (sleeping: no enabled: yes)
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.2115] device (wlp2s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
1月 05 13:08:45 doraemon-xps upowerd[938]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-7
1月 05 13:08:45 doraemon-xps mtp-probe[61929]: checking bus 1, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7"
1月 05 13:08:45 doraemon-xps mtp-probe[61929]: bus: 1, device: 10 was not an MTP device
1月 05 13:08:45 doraemon-xps dbus-daemon[505]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.230' (uid=972 pid=61928 comm="/usr/lib/colord-sane ")
1月 05 13:08:45 doraemon-xps dbus-daemon[505]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.2893] device (wlp2s0): set-hw-addr: reset MAC address to 9C:B6:D0:BA:4B:BB (unmanage)
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.5623] device (p2p-dev-wlp2s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
1月 05 13:08:45 doraemon-xps NetworkManager[507]: <info> [1641359325.5639] manager: NetworkManager state is now ASLEEP
1月 05 13:08:45 doraemon-xps wpa_supplicant[776]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
1月 05 13:08:45 doraemon-xps wpa_supplicant[776]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
1月 05 13:08:47 doraemon-xps ModemManager[566]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0': not supported by any plugin
1月 05 13:08:49 doraemon-xps audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:49 doraemon-xps systemd[1]: systemd-rfkill.service: Deactivated successfully.
1月 05 13:08:49 doraemon-xps kernel: audit: type=1131 audit(1641359329.584:380): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:55 doraemon-xps systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
1月 05 13:08:55 doraemon-xps audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:55 doraemon-xps kernel: audit: type=1131 audit(1641359335.161:381): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
1月 05 13:08:59 doraemon-xps gnome-shell[2571]: [0105/130859.495551:WARNING:exception_snapshot_linux.cc(427)] Unhandled signal -1
1月 05 13:08:59 doraemon-xps gnome-shell[2571]: [0105/130859.535914:ERROR:http_transport_libcurl.cc(470)] curl_easy_perform: Couldn't resolve host name (6)
1月 05 13:08:59 doraemon-xps visual-studio-code.desktop[61950]: /dev/fd/3: 沒有此一檔案或目錄
1月 05 13:08:59 doraemon-xps visual-studio-code.desktop[61949]: Server response:
1月 05 13:08:59 doraemon-xps visual-studio-code.desktop[19087]: [19087:0105/130859.741189:ERROR:gpu_process_host.cc(1007)] GPU process exited unexpectedly: exit_code=512
1月 05 13:09:09 doraemon-xps gsd-power[1532]: Error setting property 'PowerSaveMode' on interface org.gnome.Mutter.DisplayConfig: 已達逾時時間 (g-io-error-quark, 24)
1月 05 13:09:38 doraemon-xps audit[61966]: NETFILTER_CFG table=nat:11 family=2 entries=1 op=nft_unregister_rule pid=61966 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps audit[61966]: SYSCALL arch=c000003e syscall=46 success=yes exit=216 a0=3 a1=7fffff1b22c0 a2=0 a3=7fffff1b22ac items=0 ppid=57215 pid=61966 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps audit: PROCTITLE proctitle=69707461626C6573002D74006E6174002D44004F5554505554002D6A007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps kernel: audit: type=1325 audit(1641359378.701:382): table=nat:11 family=2 entries=1 op=nft_unregister_rule pid=61966 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps kernel: audit: type=1300 audit(1641359378.701:382): arch=c000003e syscall=46 success=yes exit=216 a0=3 a1=7fffff1b22c0 a2=0 a3=7fffff1b22ac items=0 ppid=57215 pid=61966 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps kernel: audit: type=1327 audit(1641359378.701:382): proctitle=69707461626C6573002D74006E6174002D44004F5554505554002D6A007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps audit[61967]: NETFILTER_CFG table=nat:12 family=2 entries=1 op=nft_unregister_rule pid=61967 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps audit[61967]: SYSCALL arch=c000003e syscall=46 success=yes exit=220 a0=3 a1=7ffffd3c7600 a2=0 a3=7ffffd3c75ec items=0 ppid=57215 pid=61967 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps audit: PROCTITLE proctitle=69707461626C6573002D74006E6174002D4400505245524F5554494E47002D6A007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps audit[61968]: NETFILTER_CFG table=nat:13 family=2 entries=6 op=nft_unregister_rule pid=61968 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps audit[61968]: SYSCALL arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7fffd93f6600 a2=0 a3=7fffd93f65ec items=0 ppid=57215 pid=61968 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps audit: PROCTITLE proctitle=69707461626C6573002D74006E6174002D46007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps audit[61969]: NETFILTER_CFG table=nat:14 family=2 entries=1 op=nft_unregister_chain pid=61969 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps audit[61969]: SYSCALL arch=c000003e syscall=46 success=yes exit=104 a0=3 a1=7ffd2fc5c970 a2=0 a3=7ffd2fc5c95c items=0 ppid=57215 pid=61969 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps audit: PROCTITLE proctitle=69707461626C6573002D74006E6174002D58007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps kernel: audit: type=1325 audit(1641359378.704:383): table=nat:12 family=2 entries=1 op=nft_unregister_rule pid=61967 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps kernel: audit: type=1300 audit(1641359378.704:383): arch=c000003e syscall=46 success=yes exit=220 a0=3 a1=7ffffd3c7600 a2=0 a3=7ffffd3c75ec items=0 ppid=57215 pid=61967 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps kernel: audit: type=1327 audit(1641359378.704:383): proctitle=69707461626C6573002D74006E6174002D4400505245524F5554494E47002D6A007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps kernel: audit: type=1325 audit(1641359378.704:384): table=nat:13 family=2 entries=6 op=nft_unregister_rule pid=61968 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps kernel: audit: type=1300 audit(1641359378.704:384): arch=c000003e syscall=46 success=yes exit=96 a0=3 a1=7fffd93f6600 a2=0 a3=7fffd93f65ec items=0 ppid=57215 pid=61968 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=5 comm="iptables" exe="/usr/bin/xtables-nft-multi" subj==unconfined key=(null)
1月 05 13:09:38 doraemon-xps kernel: audit: type=1327 audit(1641359378.704:384): proctitle=69707461626C6573002D74006E6174002D46007373687574746C652D3132333030
1月 05 13:09:38 doraemon-xps kernel: audit: type=1325 audit(1641359378.704:385): table=nat:14 family=2 entries=1 op=nft_unregister_chain pid=61969 subj==unconfined comm="iptables"
1月 05 13:09:38 doraemon-xps sudo[57204]: pam_unix(sudo:session): session closed for user root
1月 05 13:09:38 doraemon-xps audit[57204]: USER_END pid=57204 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
1月 05 13:09:38 doraemon-xps audit[57204]: CRED_DISP pid=57204 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
1月 05 13:38:24 doraemon-xps kernel: pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
1月 05 13:38:24 doraemon-xps kernel: pcieport 0000:00:1d.6: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
1月 05 13:38:24 doraemon-xps kernel: pcieport 0000:00:1d.6: device [8086:a11e] error status/mask=00000001/00002000
1月 05 13:38:24 doraemon-xps kernel: pcieport 0000:00:1d.6: [ 0] RxErr (First)
1月 05 13:38:26 doraemon-xps systemd-logind[512]: Lid opened.
1月 05 13:38:30 doraemon-xps tlp[62485]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
1月 05 13:38:30 doraemon-xps tlp[62485]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
1月 05 13:38:30 doraemon-xps tlp[62489]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
1月 05 13:38:30 doraemon-xps tlp[62489]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
1月 05 13:38:30 doraemon-xps tlp[62485]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
1月 05 13:38:30 doraemon-xps tlp[62485]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
1月 05 13:38:30 doraemon-xps tlp[62489]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
1月 05 13:38:30 doraemon-xps tlp[62489]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
1月 05 13:38:30 doraemon-xps kernel: ata2: SATA link down (SStatus 4 SControl 300)
1月 05 13:38:32 doraemon-xps kernel: dell_wmi: Unknown key with type 0x0012 and code 0x0000 pressed
1月 05 13:38:33 doraemon-xps tlp[62616]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
1月 05 13:38:33 doraemon-xps tlp[62616]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
1月 05 13:38:33 doraemon-xps tlp[62616]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
1月 05 13:38:33 doraemon-xps tlp[62616]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
