I saw some similar posts but not working.
After installed nvidia driver(download from nvidia website) I open the nvidia-setting and overwrite conf to /etc/X11/xorg.conf(before I rewrite, my laptop can extend monitor. its normal).
And I remove /etc/X11/xorg.conf before backup and then only laptop monitor display, restore the conf then only the extend monitor display.
I don’t know how fixed it.
Please Help me,.
Many thanks.
PS: first time to use manjaro xfce.
inxi -Fxxz:
System: Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29
wm: xfwm dm: LightDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 82JW v: Lenovo Legion R70002021 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0L77769 WIN serial: <filter> UEFI: LENOVO v: HHCN11WW
date: 05/13/2021
Battery: ID-1: BAT0 charge: 82.0 Wh (98.0%) condition: 83.7/80.0 Wh (104.6%) volts: 16.9 min: 15.4
model: Celxpert L20C4PC1 serial: <filter> status: Unknown
CPU: Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 rev: 0 cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102254
Speed: 1198 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz): 1: 1198 2: 1196 3: 1198 4: 1198
5: 1197 6: 1196 7: 1198 8: 1198 9: 1197 10: 1197 11: 1197 12: 1197 13: 1262 14: 1207 15: 1197 16: 1197
Graphics: Device-1: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 460.84 bus-ID: 01:00.0
chip-ID: 10de:25e2
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne vendor: Lenovo driver: amdgpu v: kernel bus-ID: 06:00.0
chip-ID: 1002:1638
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3 chip-ID: 174f:2459
Display: x11 server: X.Org 1.20.11 compositor: xfwm4 driver: loaded: nvidia resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: GeForce RTX 3050 Laptop GPU/PCIe/SSE2 v: 4.6.0 NVIDIA 460.84 direct render: Yes
Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:2291
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A bus-ID: 06:00.5 chip-ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Realtek vendor: Lenovo driver: N/A port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:2 chip-ID: 0bda:4852
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: see --recommends
Drives: Local Storage: total: 942.7 GiB used: 12.24 GiB (1.3%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 36.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> temp: 33.9 C
Partition: ID-1: / size: 162.35 GiB used: 10.37 GiB (6.4%) fs: ext4 dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 300.4 MiB used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1
ID-3: /home size: 277.94 GiB used: 1.87 GiB (0.7%) fs: ext4 dev: /dev/nvme1n1p4
Swap: ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme1n1p3
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 342 Uptime: 45m Memory: 13.58 GiB used: 2.83 GiB (20.8%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 Packages: pacman: 1115 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.05
/etx/X11/xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 460.84
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
mhwd -li:
> > Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
xrandr(using /etc/X11/xorg.conf)
if not using /etc/X11/xorg.conf its different.
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 509mm x 286mm
1920x1080 60.00*+
1280x1024 75.02 60.02
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 59.94
DP-4 disconnected (normal left inverted right x axis y axis)
