After applying the latest update on 31-1-2023 my intel celeron N240 laptop boots but without a working monitor. It is detected but not working. An external monitor is working as expected.
output of inxi:
Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=a81d12d0-2400-4f56-91dd-948ef50ca9d7 rw quiet apparmor=1
security=apparmor i915.modeset=1 video=eDP-1:e
drm.edid_firmware=eDP-1:edid/1366x768.bin udev.log_priority=3
Desktop: i3 v: 4.22 info: polybar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Hewlett-Packard product: HP 14 Notebook PC
v: 096E120000405F00050360180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 220F v: 57.58 serial: <superuser required>
UEFI-[Legacy]: Insyde v: F.44 date: 03/12/2018
ID-1: BAT1 charge: 28.6 Wh (88.8%) condition: 32.2/41.4 Wh (77.6%)
volts: 16.4 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: not charging
RAM: total: 7.66 GiB used: 2.46 GiB (32.2%)
Info: model: Intel Celeron N2840 bits: 64 type: MCP arch: Silvermont
level: v2 built: 2013-15 process: Intel 22nm family: 6 model-id: 0x37 (55)
stepping: 8 microcode: 0x838
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 570 high: 576 min/max: 500/2582 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 565 2: 576 bogomips: 8671
Flags: 3dnowprefetch acpi aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor movbe
msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni
popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
tsc_known_freq tsc_reliable vme xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-7
process: Intel 22nm built: 2012-13 ports: active: HDMI-A-1,eDP-1
empty: DP-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0f31 class-ID: 0300
Device-2: Realtek HP Truevision HD integrated webcam type: USB
driver: uvcvideo bus-ID: 1-4:4 chip-ID: 0bda:5776 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a driver:
X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1818 s-dpi: 97 s-size: 441x477mm (17.36x18.78")
s-diag: 650mm (25.58")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top-left
model: Samsung SyncMaster built: 2008 res: 1680x1050 hz: 60 dpi: 267
gamma: 1.2 size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
max: 1680x1050 min: 720x400
Monitor-2: eDP-1 pos: bottom-r model: BOE Display 0x0602 built: 2014
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:0f04 class-ID: 0403
API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active
tools: pacat,pactl,pavucontrol,pulsemixer
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 1000 bus-ID: 04:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:6 chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Local Storage: total: 176.99 GiB used: 24.94 GiB (14.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Plextor model: PX-128S3C
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1.04 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 57.75 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 119.24 GiB size: 116.81 GiB (97.96%)
used: 24.94 GiB (21.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: a81d12d0-2400-4f56-91dd-948ef50ca9d7
ID-2: /mnt/doc-server raw-size: N/A size: 228.16 GiB
used: 150.07 GiB (65.8%) fs: cifs dev: /dev/documents-server
ID-3: /mnt/media-server raw-size: N/A size: 931.51 GiB
used: 363.9 GiB (39.1%) fs: cifs dev: /dev/volume(sda1)
ID-4: /mnt/music-server raw-size: N/A size: 447.13 GiB
used: 409.98 GiB (91.7%) fs: cifs dev: /dev/patriot-burst
ID-5: /mnt/videos-server raw-size: N/A size: 233.25 GiB
used: 116.65 GiB (50.0%) fs: cifs dev: /dev/videos-server
ID-6: /mnt/videos2-server raw-size: N/A size: 228.16 GiB
used: 16.01 GiB (7.0%) fs: cifs dev: /dev/videos2-server
ID-1: /dev/sdb1 maj-min: 8:17 size: 57.75 GiB fs: ext4
label: \xce\x9b\xce\x97\xce\xa8\xce\x95\xce\x99\xce\xa3
uuid: 2a689970-092c-463b-8f0e-239225dec0c5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: MosArt Wireless Keyboard/Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 062a:4101 class-ID: 0301
Hub-2: 1-3:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-3.2:5 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 300mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Device-2: 1-3.3:6 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA
Device-3: 1-4:4 info: Realtek HP Truevision HD integrated webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0bda:5776 class-ID: 0e02 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 1 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 58.0 C mobo: N/A
Processes: 170 Uptime: 40m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1466 libs: 354 tools: pamac,paru,yay Shell: Bash v: 5.1.16
running-in: ranger inxi: 3.3.26
output of xrandr
Screen 0: minimum 320 x 200, current 1680 x 1818, maximum 16384 x 16384
eDP-1 connected 1366x768+157+1050 (normal left inverted right x axis y axis) 309mm x 173mm
1366x768 59.99*+ 40.02
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
VGA-1 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected primary 1680x1050+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1680x1050 59.95*+
1920x1080 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1920x1080i 60.00 50.00 59.94
1280x1024 75.02 60.02
1280x960 60.00
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
any help is welcome. thanks in advance
