Hi, after the latest update (multiple packages), maybe 2 hours later, I noticed that kde had freezed.
I restarted to just be sure. To my surprise, the display (DP) wasn’t showing 144hz anymore.
I tried to change the settings to 144hz again, but the option for it wasn’t there.
Then I tried to unplug my hdmi & DP displays, restart a few times. Nothing worked. Instead,
my HDMI display started flickering in dark blue/green shades, and after a few more times trying lower and higher hz than 60hz, both displays went dark - no signal.
I went into the root account (because the login screen works perfectly fine) and root also displays fine with 60hz preset. Here I deleted the kscreen folder, and my user account worked again.
How do I get 144hz to work again? Thanks in advance
DisplayPort-2 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 597mm x 336mm
EDID:
00ffffffffffff0006b3222701010101
321e0104b53c22783b9e20a8554ca026
0e5054bfef00714f81809500d1c00101
010101010101565e00a0a0a029503020
350055502100001c000000fd003090e6
e63c010a202020202020000000fc0056
473237410a20202020202020000000ff
004c434c4d51533033373233330a0190
020329f14e90111213040e0f1d1e1f14
05403f2309070783010000e305e001e6
060701737300e2006a59e7006aa0a067
501520350055502100001a6fc200a0a0
a055503020350055502100001a5aa000
a0a0a046503020350055502100001a00
00000000000000000000000000000000
00000000000000000000000000000032
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
subconnector: Native
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 98
supported: 98
non-desktop: 0
range: (0, 1)
2560x1440 59.95*+ 143.97 120.00 99.95
1920x1200 59.95
1920x1080 120.00 100.00 119.88 60.00 60.00 50.00 59.94
1600x1200 59.95
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x800 59.95
1152x864 75.00
1280x720 60.00 50.00 59.94
1440x576 50.00
1024x768 75.03 70.07 60.00
1440x480 60.00 59.94
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
HDMI-A-0 connected 1920x1080+0+180 (normal left inverted right x axis y axis) 531mm x 298mm
EDID:
00ffffffffffff0009d1327f45540000
2619010380351e782e9de1a654549f26
0d5054a56b80d1c0317c4568457c6168
617c953c3168023a801871382d40582c
4500132a2100001e000000ff00443946
3031393731534c300a20000000fd0018
780f8711000a202020202020000000fc
0042656e5120584c323431315a0a015b
020323f1509005040302011112131406
0715161f202309070765030c00100083
010000023a801871382d40582c450013
2a2100001f011d8018711c1620582c25
00132a2100009f011d007251d01e206e
285500132a2100001f8c0ad08a20e02d
10103e9600132a210000190000000000
000000000000000000000000000000c7
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 103
supported: 103
non-desktop: 0
range: (0, 1)
1920x1080 60.00*+ 50.00 59.94 24.00 23.98
1680x1050 60.00
1280x1024 75.02
1280x800 60.00
1152x864 75.00
1024x768 119.99 75.03 60.00
832x624 74.55
800x600 119.97 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
[nyvs@voyager ~]$ neofetch
██████████████████ ████████ nyvs@voyager
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: MS-7C37 1.0
████████ ████████ Kernel: 5.10.60-1-MANJARO
████████ ████████ ████████ Uptime: 23 mins
████████ ████████ ████████ Packages: 1344 (pacman)
████████ ████████ ████████ Shell: bash 5.1.8
████████ ████████ ████████ Resolution: 2560x1440, 1920x1080
████████ ████████ ████████ DE: Plasma 5.22.4
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ Theme: Breath2 2021 Dark [Plasma], Breath-Dark [GTK2/3]
████████ ████████ ████████ Icons: Papirus-Dark [Plasma], Papirus-Dark [GTK2/3]
████████ ████████ ████████ Terminal: yakuake
CPU: AMD Ryzen 9 3900X (24) @ 3.800GHz
GPU: AMD ATI Radeon RX 6800/6800 XT / 6900 XT
Memory: 2494MiB / 32094MiB
[nyvs@voyager ~]$ sudo pamac checkupdates
[sudo] password for nyvs:
Your system is up-to-date.
[nyvs@voyager ~]$
